Windows 11 - Compiling toolchain (5.3 and 6)
zhengxiaojun 17935334 at qq.com
Fri Oct 13 00:28:21 UTC 2023
在 2023/10/12 23:21, Sebastian Huber 写道:
> Hello Chris,
> some of our customers use WSL2 with Ubuntu, they reported no issues with
> the RSB build of RTEMS 6.
> If you want to build mingw tools, then I would build them on Linux with
> a mingw cross compiler.
I can not get arm-rtems-gcc in this way. The command is:
../source-builder/sb-set-builder --log=l-arm.txt
--host=x86_64-w64-mingw32 --prefix=/opt/rtems/6.1 6/rtems-arm
Is it right?
> Kind regards,
>      Sebastian
