EPICS and tftp file system
Miroslaw Dach miroslaw.dach at gmail.com
Wed Feb 14 20:54:49 UTC 2024
Hi Andrew,
Thanks for your e-mail.
>TFTP is normally only used for reading, and it doesn’t surprise me if
writing isn’t supported since there is no user authentication involved.
I thought that setting the parameter RTEMS_FILESYSTEM_READ_WRITE in the
function call below would do the job:
  if (mount_and_make_target_path(devname,
                               "/TFTP/",
                               RTEMS_FILESYSTEM_TYPE_TFTPFS,
                               RTEMS_FILESYSTEM_READ_WRITE,
                               NULL))
I am able to write the file using tftp from my linux system. When I examine
the tftp log file then I do not see any attempt from the RTEMS system to
request the file to be written so I suspect that it is a certain
configuration in EPICS/RTEMS missing?
>It should be possible to enable NFSv2 in Rocky Linux 8, it still works on
RHEL-8 but you do have to change one or two files in the server’s /etc area
to do that. Red Hat don’t actually offer support for v2 any more, but they
haven’t actively removed the code for it, just disabled it by default.
Our IT guys tried and they said that NFS V2 can not be used on RL8. This
surprises me since it is fine on RHEL-8 according to your statement and
also:
https://epics.anl.gov/tech-talk/2022/msg00267.php
Best Regards
Mirek
śr., 14 lut 2024 o 11:02 Johnson, Andrew N. <anj at anl.gov> napisał(a):
> Hi Mirek,
> V2 will be removed from the upstream kernel.org Linux kernel at some
> point soon and then it will be much harder to continue using, but I don’t
> think that has happened just yet. Plan for that eventuality…
> - Andrew
> Complicity is easy, Simplexity takes real work
> On Feb 14, 2024, at 2:23 PM, Miroslaw Dach <miroslaw.dach at gmail.com>
> wrote:
> Hello,
> I have two types of the EPICS and RTEMS 4.10 and RTEMS5 bases systems.
> They all use the nfs v2 mount points on the Linus remote host. We current
> mirage in our lab to the newer version of the LINUX os (Rocky Linux 8)
> which seems to not support NFS V2. Since I can not migrate to the RTEMS6
> and EPICS 7 with some legacy systems due to the drivers incompatibilities
> I explored the TFTPFS instead of the NFSFS. All works fine when reading
> files through tftp. I can't however write files using the tftp.
> The tftpfs is set as following:
> *EPICS_R7.07/base/modules/libcom/RTEMS/posix/rtems_init.c *
> *initialize_remote_filesystem(char **argv, int hasLocalFilesystem){ *
> *  if (mount_and_make_target_path(devname,
>  "/TFTP/",                                RTEMS_FILESYSTEM_TYPE_TFTPFS,
>            NULL))        perror("mount_and_make_target_path"); *
> When I try to write a file I get a following error:
> *dbl > S0817PVs.txt st.cmd line 60: Can't open "S0817PVs.txt": I/O error.*
> I do not see anything in the tftp log file that the EPICS iocs server even
> tries to send a request to save a file. It looks like it is
> something internal in EPICS/RTEMS .
> Does anybody have any advice?
> Best Regards
> Mirek
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20240214/9f03120a/attachment-0001.htm>
