EPICS and tftp file system
Frank Kühndel frank.kuehndel at embedded-brains.de
Thu Feb 15 10:25:59 UTC 2024
Hello Miroslaw,
On 2/14/24 21:54, Miroslaw Dach wrote:
> Thanks for your e-mail.
>> TFTP is normally only used for reading, and it doesn’t surprise me if
> writing isn’t supported since there is no user authentication involved.
> I thought that setting the parameter RTEMS_FILESYSTEM_READ_WRITE in the
> function call below would do the job:
>    if (mount_and_make_target_path(devname,
>                                 "/TFTP/",
>                                 RTEMS_FILESYSTEM_TYPE_TFTPFS,
>                                 RTEMS_FILESYSTEM_READ_WRITE,
>                                 NULL))
> I am able to write the file using tftp from my linux system. When I examine
> the tftp log file then I do not see any attempt from the RTEMS system to
> request the file to be written so I suspect that it is a certain
> configuration in EPICS/RTEMS missing?
I have no idea of EPICS. I just want to mention that RTEMS tftpfs is
able to write to the server – at least in current RTEMS 6:
https://docs.rtems.org/branches/master/filesystem/trivial_ftp.html
Greetings,
fk
embedded brains GmbH & Co. KG
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone:  +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
Registernummer: HRA 117265
