EPICS and tftp file system
Miroslaw Dach
miroslaw.dach at gmail.com
Thu Feb 15 19:15:24 UTC 2024
Hi Frank,
Thank you for your feedback on that. It might be then the setup in EPICS.
Best Regards
Mirek
czw., 15 lut 2024 o 02:26 Frank Kühndel <frank.kuehndel at embedded-brains.de>
napisał(a):
> Hello Miroslaw,
> On 2/14/24 21:54, Miroslaw Dach wrote:
> > Thanks for your e-mail.
> >> TFTP is normally only used for reading, and it doesn’t surprise me if
> > writing isn’t supported since there is no user authentication involved.
> > I thought that setting the parameter RTEMS_FILESYSTEM_READ_WRITE in the
> > function call below would do the job:
> > if (mount_and_make_target_path(devname,
> > "/TFTP/",
> > RTEMS_FILESYSTEM_TYPE_TFTPFS,
> > RTEMS_FILESYSTEM_READ_WRITE,
> > NULL))
> > I am able to write the file using tftp from my linux system. When I
> examine
> > the tftp log file then I do not see any attempt from the RTEMS system to
> > request the file to be written so I suspect that it is a certain
> > configuration in EPICS/RTEMS missing?
> I have no idea of EPICS. I just want to mention that RTEMS tftpfs is
> able to write to the server – at least in current RTEMS 6:
> https://docs.rtems.org/branches/master/filesystem/trivial_ftp.html
> Greetings,
> fk
> embedded brains GmbH & Co. KG
> Herr Frank KÜHNDEL
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: frank.kuehndel at embedded-brains.de
> phone: +49-89-18 94 741 - 23
> mobile: +49-176-15 22 06 - 11
> Registergericht: Amtsgericht München
> Registernummer: HRA 117265
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/users/attachments/20240215/cb8be8fb/attachment.htm>
