Rust on RTEMS
Thu Jan 11 00:49:59 UTC 2024
On Sun, Jan 7, 2024 at 2:22 AM Karel Gardas <karel.gardas at centrum.cz> wrote:
> On 12/22/23 18:36, Joel Sherrill wrote:
> > It's not a huge secret. :)
> > https://activities.esa.int/4000140242
> > <https://activities.esa.int/4000140242> shows an ~EU175 project was awarded
> > to DLR.   From there, Jan Sommer is the only person at DLR who has mentioned
> > this.
> > I understand wanting someone at DLR to make a statement but the activity
> > is clear.  I assume many of our projects for NASA are just as easily tracked
> > down if someone knew where to look. Personally, I do not know where to look
> > for that.
> Side note: currently working with Rust on bare-metal M4 for some
> industry equipment using Embassy[1] and from this I kind of get feeling
> and kind of understand why Rust community is not that interested in
> integrating with established C-based RTOSes even those open-sourced. So
> my conclusion on this is that if RTEMS community would like to see Rust
> running on RTEMS, then the push needs to come from the community itself.
> What is IMHO positive is that due to RTEMS libs support, IMHO Rust
> should be able to run in 'std' manner.
Is there anything to add/update to https://devel.rtems.org/ticket/4182
regarding the topic?
> Cheers,
> Karel
> [1]: https://embassy.dev/
> users mailing list
> users at rtems.org
