PowerPC/e500: how is FDT access supposed to work?
Daniel Wohllebe
daniel.wohllebe at nepdrive.de
Sun Jul 7 08:41:09 UTC 2024
Hello Sebastian,
thank you for your response. I found out that the problem was me
including the FDT-address incorrectly in the boot-command.
For anybody who may also stumble upon this future, I will give a small
outline of what to check for:
On the U-Boot commandline, we can see the environment via printenv...
=> printenv
bootcmd=test -n "$qemu_kernel_addr" && bootm $qemu_kernel_addr -
$fdtcontroladdr
ethaddr=52:52:52:52:52:52
fdtcontroladdr=7a6de90
stderr=serial at 4500
stdin=serial at 4500
stdout=serial at 4500
We can see the env-variable holding the address of the FDT, $fdtcontroladdr.
I used the bootm command to boot but did so with the wrong arguments.
What I need to use to boot (with my application loaded to 0x2000000) is...
=> bootm 0x2000000 - $fdtcontroladdr
## Booting kernel from Legacy Image at 02000000 ...
Image Name: RTEMS
Created: 2024-06-26 9:32:37 UTC
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 2279513 Bytes = 2.2 MiB
Load Address: 00004000
Entry Point: 00004000
Verifying Checksum ... OK
## Flattened Device Tree blob at 07a6de90
Booting using the fdt blob at 0x7a6de90
Uncompressing Kernel Image
Loading Device Tree to 03efc000, end 03ffefff ... OK
Kind Regards,
Daniel Wohllebe
