PowerPC/e500: how is FDT access supposed to work?
Chris Johns
chrisj at rtems.org
Tue Jul 9 01:18:08 UTC 2024
On 7/7/2024 6:41 pm, Daniel Wohllebe wrote:
> Hello Sebastian,
> thank you for your response. I found out that the problem was me including the
> FDT-address incorrectly in the boot-command.
> For anybody who may also stumble upon this future, I will give a small outline
> of what to check for:
Thank you for the feedback. Would updating the User manual help?
> On the U-Boot commandline, we can see the environment via printenv...
> => printenv
> bootcmd=test -n "$qemu_kernel_addr" && bootm $qemu_kernel_addr - $fdtcontroladdr
> ethaddr=52:52:52:52:52:52
> fdtcontroladdr=7a6de90
> stderr=serial at 4500
> stdin=serial at 4500
> stdout=serial at 4500
> We can see the env-variable holding the address of the FDT, $fdtcontroladdr.
> I used the bootm command to boot but did so with the wrong arguments. What I
> need to use to boot (with my application loaded to 0x2000000) is...
> => bootm 0x2000000 - $fdtcontroladdr
> ## Booting kernel from Legacy Image at 02000000 ...
> Image Name: RTEMS
> Created: 2024-06-26 9:32:37 UTC
> Image Type: PowerPC Linux Kernel Image (gzip compressed)
> Data Size: 2279513 Bytes = 2.2 MiB
> Load Address: 00004000
> Entry Point: 00004000
> Verifying Checksum ... OK
> ## Flattened Device Tree blob at 07a6de90
> Booting using the fdt blob at 0x7a6de90
> Uncompressing Kernel Image
> Loading Device Tree to 03efc000, end 03ffefff ... OK
> Kind Regards,
> Daniel Wohllebe
> users mailing list
> users at rtems.org
