Unfortunately, I still can't use rsb on a Mac (M2).
Tue Jun 11 03:11:54 UTC 2024
On 11/6/2024 10:39 am, Joel Sherrill wrote:
> On Mon, Jun 10, 2024, 7:26 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 11/6/2024 7:00 am, Heinz Junkes wrote:
>     > Hi.
>     > That seems to be the root cause of the problem:
>     > configure:21663: checking whether to use python
>     > configure:21665: result: /usr/local/bin/python3.12
>     > configure:21869: checking for python
>     > configure:21892: /usr/bin/cc -O2 -pipe -fbracket-depth=1024
>     -I/Volumes/Epics/LONG_ISLAND/RTEMS_ARM_libBsd_stack/rsb/rtems/build/tmp/sb-501/tools/rtems-default-tools/Volumes/Epics/LONG_ISLAND/RTEMS_ARM_libBsd_stack/rtems/6/include -I/Volumes/Epics/LONG_ISLAND/RTEMS_ARM_libBsd_stack/rsb/rtems/build/tmp/sb-501-internal/include -o conftest -g -O2     -I/Volumes/Epics/LONG_ISLAND/RTEMS_ARM_libBsd_stack/rsb/rtems/build/tmp/sb-501-internal/include -I/Library/Frameworks/Python.framework/Versions/3.12/include/python3.12 -I/Library/Frameworks/Python.framework/Versions/3.12/include/python3.12  -L/Volumes/Epics/LONG_ISLAND/RTEMS_ARM_libBsd_stack/rsb/rtems/build/tmp/sb-501-internal/lib conftest.c -L/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/config-3.12-darwin -lpython3.12 -ldl -framework CoreFoundation -Wl,-stack_size,1000000 -framework CoreFoundation Python.framework/Versions/3.12/Python -lncurses -lm  >&5
>     > clang: error: no such file or directory:
>     'Python.framework/Versions/3.12/Python'
>     > configure:21892: $? = 1
>     > configure: failed program was:
> Is this from missing the development package for Python?
No, it is new. On my set up the venv is being passed to GDB's configure as the
path python is installed in. I hacked the build script to make the python
executable as the documentation says and it still fails to build.
