Unfortunately, I still can't use rsb on a Mac (M2).
Heinz Junkes junkes at fhi-berlin.mpg.de
Tue Jun 11 03:29:01 UTC 2024
Hi,
All the stuff seems to be there:
junkes at Zarquon ~ % ls -l   /Library/Frameworks/Python.framework/Versions/3.12/
total 31296
lrwxrwxr-x   1 root  admin        18 Mar 12 09:09 Headers -> include/python3.12
-rwxrwxr-x   1 root  admin  16020240 Feb  6 23:15 Python
drwxrwxr-x   5 root  admin       160 Feb  6 23:10 Resources
drwxrwxr-x   3 root  admin        96 Feb  6 23:15 _CodeSignature
drwxrwxr-x  21 root  admin       672 May 16 21:27 bin
drwxrwxr-x   3 root  admin        96 Feb  6 23:10 etc
drwxrwxr-x   3 root  admin        96 Feb  6 23:10 include
drwxrwxr-x  36 root  admin      1152 Mar 12 09:09 lib
drwxrwxr-x   4 root  admin       128 Feb  6 23:10 share
Heinz
> On 11. Jun 2024, at 02:39, Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Jun 10, 2024, 7:26 PM Chris Johns <chrisj at rtems.org> wrote:
> On 11/6/2024 7:00 am, Heinz Junkes wrote:
> > Hi.
> > That seems to be the root cause of the problem:
> > configure:21663: checking whether to use python
> > configure:21665: result: /usr/local/bin/python3.12
> > configure:21869: checking for python
> > configure:21892: /usr/bin/cc -O2 -pipe -fbracket-depth=1024 -I/Volumes/Epics/LONG_ISLAND/RTEMS_ARM_libBsd_stack/rsb/rtems/build/tmp/sb-501/tools/rtems-default-tools/Volumes/Epics/LONG_ISLAND/RTEMS_ARM_libBsd_stack/rtems/6/include -I/Volumes/Epics/LONG_ISLAND/RTEMS_ARM_libBsd_stack/rsb/rtems/build/tmp/sb-501-internal/include -o conftest -g -O2     -I/Volumes/Epics/LONG_ISLAND/RTEMS_ARM_libBsd_stack/rsb/rtems/build/tmp/sb-501-internal/include -I/Library/Frameworks/Python.framework/Versions/3.12/include/python3.12 -I/Library/Frameworks/Python.framework/Versions/3.12/include/python3.12  -L/Volumes/Epics/LONG_ISLAND/RTEMS_ARM_libBsd_stack/rsb/rtems/build/tmp/sb-501-internal/lib conftest.c -L/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/config-3.12-darwin -lpython3.12 -ldl -framework CoreFoundation -Wl,-stack_size,1000000 -framework CoreFoundation Python.framework/Versions/3.12/Python -lncurses -lm  >&5
> > clang: error: no such file or directory: 'Python.framework/Versions/3.12/Python'
> > configure:21892: $? = 1
> > configure: failed program was:
> Is this from missing the development package for Python?
> Could you please raise an issue in gitlab for this and assign it to me?
> Chris
> users mailing list
> users at rtems.org
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20240611/1424403f/attachment.bin>
