Unfortunately, I still can't use rsb on a Mac (M2).
Joel Sherrill
joel at rtems.org
Tue Jun 11 04:13:59 UTC 2024
On Mon, Jun 10, 2024, 10:57 PM Chris Johns <chrisj at rtems.org> wrote:
> On 11/6/2024 1:29 pm, Heinz Junkes wrote:
> > Hi,
> > All the stuff seems to be there:
> > junkes at Zarquon ~ % ls -l
> /Library/Frameworks/Python.framework/Versions/3.12/
> > total 31296
> > lrwxrwxr-x 1 root admin 18 Mar 12 09:09 Headers ->
> include/python3.12
> > -rwxrwxr-x 1 root admin 16020240 Feb 6 23:15 Python
> > drwxrwxr-x 5 root admin 160 Feb 6 23:10 Resources
> > drwxrwxr-x 3 root admin 96 Feb 6 23:15 _CodeSignature
> > drwxrwxr-x 21 root admin 672 May 16 21:27 bin
> > drwxrwxr-x 3 root admin 96 Feb 6 23:10 etc
> > drwxrwxr-x 3 root admin 96 Feb 6 23:10 include
> > drwxrwxr-x 36 root admin 1152 Mar 12 09:09 lib
> > drwxrwxr-x 4 root admin 128 Feb 6 23:10 share
> Yes. The issue has been worked around in previous RSB builds with a patch
> however the patch was removed for GDB 14.2 build. Joel?
I assumed the patch was no longer needed. I didn't review if it still
applied.
If it fixes your build issue, then I can review and approve the MR tomorrow
my time.
> The GDB bug is https://sourceware.org/bugzilla/show_bug.cgi?id=29070 and
> on
> discord Amar has found a python but (https://bugs.python.org/issue16848)
> which
> is closed however the --ldflags reported still have the invalid path. It
> is not
> clear if this is a GDB or Python problem.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20240610/b5875755/attachment.htm>
