Unfortunately, I still can't use rsb on a Mac (M2).
Chris Johns
chrisj at rtems.org
Tue Jun 11 03:57:03 UTC 2024
On 11/6/2024 1:29 pm, Heinz Junkes wrote:
> Hi,
> All the stuff seems to be there:
> junkes at Zarquon ~ % ls -l /Library/Frameworks/Python.framework/Versions/3.12/
> total 31296
> lrwxrwxr-x 1 root admin 18 Mar 12 09:09 Headers -> include/python3.12
> -rwxrwxr-x 1 root admin 16020240 Feb 6 23:15 Python
> drwxrwxr-x 5 root admin 160 Feb 6 23:10 Resources
> drwxrwxr-x 3 root admin 96 Feb 6 23:15 _CodeSignature
> drwxrwxr-x 21 root admin 672 May 16 21:27 bin
> drwxrwxr-x 3 root admin 96 Feb 6 23:10 etc
> drwxrwxr-x 3 root admin 96 Feb 6 23:10 include
> drwxrwxr-x 36 root admin 1152 Mar 12 09:09 lib
> drwxrwxr-x 4 root admin 128 Feb 6 23:10 share
Yes. The issue has been worked around in previous RSB builds with a patch
however the patch was removed for GDB 14.2 build. Joel?
The GDB bug is https://sourceware.org/bugzilla/show_bug.cgi?id=29070 and on
discord Amar has found a python but (https://bugs.python.org/issue16848) which
is closed however the --ldflags reported still have the invalid path. It is not
clear if this is a GDB or Python problem.
