How to get a stack trace in RTEMS
Sebastian Huber
Wed Jun 26 09:24:58 UTC 2024
Hello Stanislav,
On 26.06.24 11:15, Stanislav Pankevich wrote:
> Dear RTEMS community,
> My colleague George cannot register to post to this forum, getting 403
> when subscribing at https://lists.rtems.org/mailman/listinfo/users
> <https://lists.rtems.org/mailman/listinfo/users>. I am posting this
> question on his behalf.
> We are currently seeing an RTEMS_FATAL_SOURCE_EXCEPTION right at the
> start of execution and can debug the program once the exception handler
> has been reached. From here we can inspect the call stack however we
> only see the trace that led to the final function call (void
> bsp_reset(void) while loop) that handles the exception, not the trace
> that caused the exception. We would like to implement an exception
> handler that prints the trace that caused the exception to be triggered.
> Is this something that is already implemented in RTEMS? We have
> developed an RTEMS port to the Zynq UltraScale+ MPSoC Cortex R5 RPU
> running in lockstep. Code execution is from the shared DDR4 memory with
> a 256MB region allocated.
I have some improvements for this BSP in my patch queue. It adds support
for the split mode for example.
> What we want is to have the actual stack trace to be printed to the console.
> Here is an example of what we have now in GDB:
> bsp_reset at 0x0017b062
> (.../rtems/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c:40)
> _User_extensions_Iterate at 0x00186854
> (.../rtems/cpukit/score/src/userextiterate.c:194)
> _User_extensions_Fatal at 0x00183108
> (.../rtems/cpukit/include/rtems/score/userextimpl.h:467)
> _Terminate at 0x00183108 (.../rtems/cpukit/score/src/interr.c:55)
> rtems_fatal at 0x0018adc2 (.../rtems/cpukit/include/rtems/fatal.h:160)
> _ARM_Exception_default at 0x0018adc2
> (.../rtems/cpukit/score/cpu/arm/arm-exception-default.c:37)
> save_more_context at 0x00186cfc
> (.../rtems/cpukit/score/cpu/arm/armv4-exception-default.S:176)
> This is currently what is printed on the serial port:
> *** FATAL ***
> fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
> R0 = 0x00000056 R8 = 0x00ac8aec
> R1 = 0xf000e3a0 R9 = 0x00ac8a5c
> R2 = 0x00000020 R10 = 0x00000000
> R3 = 0x00000020 R11 = 0x00000000
> R4 = 0x00000056 R12 = 0x010e6630
> R5 = 0x010e67c0 SP = 0x010e65d4
> R6 = 0x010e6698 LR = 0x001854ae
> R7 = 0x001867f5 PC = 0x001854ae
> CPSR = 0x200f01f7 VEC = 0x00000004
> RTEMS version: 6.0.0.62f15c07482dd953663143554e78b4bf287ccb83
> RTEMS tools: 12.2.1 20230224 (RTEMS 6, RSB
> 4c73a76c802588d3864c64ee4dd48a84b953201a, Newlib 17ac400)
Getting stack traces on arm is not that easy since you need a
description of the stack frames. You can try to use the unwinder from
libgcc:
static _Unwind_Reason_Code trace(_Unwind_Context *ctx, void *arg)
(void)arg;
printk("%08" PRIuPTR "\n", (uintptr_t)_Unwind_GetIP(ctx));
return _URC_NO_REASON;
static void f(int i);
static void h(int i)
f(i + 1);
if (i > 10) {
_Unwind_Backtrace(trace, NULL);
} else {
h(i + 1);
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
