RTEMS Project Repos in GitLab
Frank Kühndel frank.kuehndel at embedded-brains.de
Mon May 13 16:45:58 UTC 2024
Hello Chris,
I just did not managed to find git://git.rtems.org/rtems_waf.git on
gitlab. Has been moved too or will it stay were it was?
Thanks,
Frank
On 5/1/24 08:46, Chris Johns wrote:
> Hi RTEMS Community.
> This email explains the RTEMS Project and Repos in GitLab.
> GitLab is will be open and accounts can be created from 12PM EST / 5PM GM.
> Note, GitLab failed to automatically identify the RTOS/RTEMS licence and it
> incorrectly states it is Apache 2.0. It is not and no licences have changed. An
> issue is open to sort this out.
> GitLab lets you have repositories structured as projects. We have a top level
> namespace called RTEMS and our repositories reside under this namespace. Having
> everything under a single namespace lets us use a lot of cool GitLab features.
> The link ishttps://gitlab.rtems.org/rtems.
> We have some other namespaces alongside RTEMS such as Administration, Approvers
> and Architecture. The projects in the top level namespace are place holders for
> the groups we use across GitHub and groups let us control what users can do.
> The Administration project is used to run GitLab and the servers we have at OSL
> OSU. If you have found a bug or problem please raise an issue. If you have a
> feature or a good idea please raise an issue. If you know an answer to an issue
> that is open please answer.
> The Architecture project lets us define groups of users who can own and approve
> architecture specific parts of RTEMS. We have this at the top so architecture
> owners can manage CI runners.
> The top level RTEMS Project contains the following project groups:
>   1. Documentation - Our documentation.
>   2. Packages - The various packages we can build for RTEMS. Think of them
>      as 3rd party libraries
>   3. Pre-Qualification - The pre-qualification projects based on the
>      recent ESA funded work
>   4. RTOS - The real-time kernel, its examples and the release scripts
>   5. Tools - Our ecosystem tools such as the RSB, RTEMS Tools and the
>      SIS simulator
>   6. Programs - A place to organise activities similar or related to
>      Google Summer of Code
> Main Branch
> We have chosen this time to move from a master branch to main on all our repos.
> Leaving the git.rtems.org repos open while we worked on GitLab meant the project
> could continue to function as we deployed GitLab however we have had to make
> commits in the GitLab repos to add files like CODEOWNERS and to test the
> platform. The simplest solution for us is to roll any commits to git.rtems.org
> into the GitLab repos before we go live. If you have maintained any waiting to
> be merged on local branches in your repo you can rebase to the main branch. The
> following is an example of how to switch an RTEMS git.rtems.org repo you use to
> track RTEMS to RTEMS GitLab:
>   1. The procedure assumes your local master branch matches the git.rtems.org
>      master branch and any changes you have are on local branches.
>   2. Set the remote  origin to GitLab:
>       git remote set-url originssh://git@gitlab.rtems.org:2222/rtems/rtos/rtems.git
>   3. Fetch the GitLab repo:
>       git fetch
>   4. Check out the GitLab main branch:
>       git checkout main
>   5. We recommend you delete your local master branch:
>       git branch -D master
> The following is an example of how to switch an RTEMS git.rtems.org repo you
> have changed in you wish to post for review and merging to RTEMS GitLab:
>   2. Fork the GitLab repo to your user account. Open the project repo in GitLab
>      and click Fork, located top right. You will need to select a namespace
>      and it needs to be the one based on your user name. Select the namespace
>      drop down in the Project URL field and scroll down or enter your user name
>      and click on the entry.
>   3. Set the remote  origin to GitLab:
>       git remote set-url originssh://git@gitlab.rtems.org:2222/chris/rtems.git
>      Replace my user name with yours.
>   4. Fetch the GitLab repo:
>       git fetch
>   5. Check out the GitLab main branch:
>       git checkout main
>   6. We recommend you delete your local master branch:
> Merge Request Approvers
> Every merge request in RTEMS requires two approvers. Approvers are organized as
> members of subgroups within the top-level Approvers group
> https://gitlab.rtems.org/approvers.
> We have added initial CODEOWNERS files in GitLab that details which subgroups
> own and approve merge requests. There are some members of the community who need
> to be added to specific subgroups but we cannot add them until they have
> accounts. If you want to be a code owner and approver please raise an
> Administration issue. Anyone in the subgroup of “General Approver” is able to be
> one of the approvers of  merge requests. However, at least one approver must
> belong to a subgroup that is a code owner for a specific file or directory.
> Self-approval by the author of the merge request is not allowed.
> Please take a few minutes to look over the project structure. A project has its
> own issues so when you want to create a new issue please add it to the project
> it relates to. We can link issues across projects using Tags. The “RTEMS Issues
> in GitLab” email explains RTEMS’s issues in GitLab and how they have been
> imported from Trac.
> If you need help please join the #gitlab-support channel on our Discord server.
> You can find our invite link herehttps://www.rtems.org/discord. We will also
> respond to posts on this list when we have the time.
> Regards
> Chris Johns
> RTEMS GitLab Team
> users mailing list
> users at rtems.org
embedded brains GmbH & Co. KG
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone:  +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
Registernummer: HRA 117265
