RTEMS Project Repos in GitLab
Gedare Bloom
gedare at rtems.org
Mon May 13 21:31:55 UTC 2024
On Mon, May 13, 2024 at 10:46 AM Frank Kühndel
<frank.kuehndel at embedded-brains.de> wrote:
> Hello Chris,
> I just did not managed to find git://git.rtems.org/rtems_waf.git on
> gitlab. Has been moved too or will it stay were it was?
Thanks for bringing this up. https://gitlab.rtems.org/rtems/tools/rtems-waf
It should work checked out as either 'rtems-waf.git' or
'rtems_waf.git' now,
https://gitlab.rtems.org/administration/gitlab/-/issues/55
I guess someone should submit an Issue and MR for fixing the submodule link
> Thanks,
> Frank
> On 5/1/24 08:46, Chris Johns wrote:
> > Hi RTEMS Community.
> > This email explains the RTEMS Project and Repos in GitLab.
> > GitLab is will be open and accounts can be created from 12PM EST / 5PM GM.
> > Note, GitLab failed to automatically identify the RTOS/RTEMS licence and it
> > incorrectly states it is Apache 2.0. It is not and no licences have changed. An
> > issue is open to sort this out.
> > GitLab lets you have repositories structured as projects. We have a top level
> > namespace called RTEMS and our repositories reside under this namespace. Having
> > everything under a single namespace lets us use a lot of cool GitLab features.
> > The link ishttps://gitlab.rtems.org/rtems.
> > We have some other namespaces alongside RTEMS such as Administration, Approvers
> > and Architecture. The projects in the top level namespace are place holders for
> > the groups we use across GitHub and groups let us control what users can do.
> > The Administration project is used to run GitLab and the servers we have at OSL
> > OSU. If you have found a bug or problem please raise an issue. If you have a
> > feature or a good idea please raise an issue. If you know an answer to an issue
> > that is open please answer.
> > The Architecture project lets us define groups of users who can own and approve
> > architecture specific parts of RTEMS. We have this at the top so architecture
> > owners can manage CI runners.
> > The top level RTEMS Project contains the following project groups:
> > 1. Documentation - Our documentation.
> > 2. Packages - The various packages we can build for RTEMS. Think of them
> > as 3rd party libraries
> > 3. Pre-Qualification - The pre-qualification projects based on the
> > recent ESA funded work
> > 4. RTOS - The real-time kernel, its examples and the release scripts
> > 5. Tools - Our ecosystem tools such as the RSB, RTEMS Tools and the
> > SIS simulator
> > 6. Programs - A place to organise activities similar or related to
> > Google Summer of Code
> > Main Branch
> > We have chosen this time to move from a master branch to main on all our repos.
> > Leaving the git.rtems.org repos open while we worked on GitLab meant the project
> > could continue to function as we deployed GitLab however we have had to make
> > commits in the GitLab repos to add files like CODEOWNERS and to test the
> > platform. The simplest solution for us is to roll any commits to git.rtems.org
> > into the GitLab repos before we go live. If you have maintained any waiting to
> > be merged on local branches in your repo you can rebase to the main branch. The
> > following is an example of how to switch an RTEMS git.rtems.org repo you use to
> > track RTEMS to RTEMS GitLab:
> > 1. The procedure assumes your local master branch matches the git.rtems.org
> > master branch and any changes you have are on local branches.
> > 2. Set the remote origin to GitLab:
> > git remote set-url originssh://git@gitlab.rtems.org:2222/rtems/rtos/rtems.git
> > 3. Fetch the GitLab repo:
> > git fetch
> > 4. Check out the GitLab main branch:
> > git checkout main
> > 5. We recommend you delete your local master branch:
> > git branch -D master
> > The following is an example of how to switch an RTEMS git.rtems.org repo you
> > have changed in you wish to post for review and merging to RTEMS GitLab:
> > 2. Fork the GitLab repo to your user account. Open the project repo in GitLab
> > and click Fork, located top right. You will need to select a namespace
> > and it needs to be the one based on your user name. Select the namespace
> > drop down in the Project URL field and scroll down or enter your user name
> > and click on the entry.
> > 3. Set the remote origin to GitLab:
> > git remote set-url originssh://git@gitlab.rtems.org:2222/chris/rtems.git
> > Replace my user name with yours.
> > 4. Fetch the GitLab repo:
> > git fetch
> > 5. Check out the GitLab main branch:
> > git checkout main
> > 6. We recommend you delete your local master branch:
> > Merge Request Approvers
> > Every merge request in RTEMS requires two approvers. Approvers are organized as
> > members of subgroups within the top-level Approvers group
> > https://gitlab.rtems.org/approvers.
> > We have added initial CODEOWNERS files in GitLab that details which subgroups
> > own and approve merge requests. There are some members of the community who need
> > to be added to specific subgroups but we cannot add them until they have
> > accounts. If you want to be a code owner and approver please raise an
> > Administration issue. Anyone in the subgroup of “General Approver” is able to be
> > one of the approvers of merge requests. However, at least one approver must
> > belong to a subgroup that is a code owner for a specific file or directory.
> > Self-approval by the author of the merge request is not allowed.
> > Please take a few minutes to look over the project structure. A project has its
> > own issues so when you want to create a new issue please add it to the project
> > it relates to. We can link issues across projects using Tags. The “RTEMS Issues
> > in GitLab” email explains RTEMS’s issues in GitLab and how they have been
> > imported from Trac.
> > If you need help please join the #gitlab-support channel on our Discord server.
> > You can find our invite link herehttps://www.rtems.org/discord. We will also
> > respond to posts on this list when we have the time.
> > Regards
> > Chris Johns
> > RTEMS GitLab Team
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
> embedded brains GmbH & Co. KG
> Herr Frank KÜHNDEL
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: frank.kuehndel at embedded-brains.de
> phone: +49-89-18 94 741 - 23
> mobile: +49-176-15 22 06 - 11
> Registergericht: Amtsgericht München
> Registernummer: HRA 117265
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> users mailing list
> users at rtems.org
