building rtems-net-legacy failed
Tue May 28 16:26:00 UTC 2024
Hi
rtems-net-legacy only works with 6+. It was still included in the rtems
source tree in versions 5 and earlier. It is enable/disable networking
(e.g. --enable-networking when you configure RTEMS itself) and then do not
reference the legacy repository at all.
For 6, there is waf and no network stack in the rtems source tree. You
build and install RTEMS itself and then add on either libbsd, lwip, or
legacy.
./cpukit/include/rtems/test-info.h is where that file is in 6+. I didn't
check 5.
On Tue, May 28, 2024 at 10:59 AM John Howard <echosoft.llc at gmail.com> wrote:
> Hello.
> Thanks for the example configuring waf. I built v5.3 for Raspberry Pi
> using RSB after failing with waf.
> Legacy components are more likely to build using “legacy” RSB instead of
> WAF.
> I don’t know where you can find that missing test-info.h file. But you
> probably don’t need it at first build anyhow.
> Just comment out the request for it, or provide an empty file where
> expected, and repeat hacking out that “requirement” as needed until it
> builds something.
> — John
> On May 24, 2024, at 7:33 PM, Miroslaw Dach <miroslaw.dach at gmail.com>
> wrote:
> Hi All,
> I have tried first to build rtems-net-services.
> The configure faction:
> waf configure --prefix=/my_devl/rtems-5/5  --rtems-version=5
> --rtems-archs=powerpc --rtems-bsps=powerpc/mvme3100
> failed:
> Checking for library bsd                      : not found
> Checking for library networking               : not found
> Checking for library lwip                     : not found
> so I downloaded rtems-net-legacy, hoping the that I can build this way
> missing libnetworking.a
> The configuration command was successful :
> When I tried to build the project,
> waf build
> I got several times message that rtems/test-info.h is missing.
> ../../libtest/testbeginend.c:21:10: fatal error: rtems/test-info.h: No
> such file or directory
>  #include <rtems/test-info.h>
> Where to find rtems/test-info.h
> Thanks
> Best regards
> Mirek
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20240528/39ca06a1/attachment.htm>
