rsb failure on rtems-m68k target
Robert W
rbtwas at gmail.com
Thu Jan 23 19:09:31 UTC 2025
Sorry, forgot to add host info:
Ubuntu 22.04, on an aspire e 15 laptop.
Robert W.
On Thu, Jan 23, 2025 at 11:50 AM Robert W <rbtwas at gmail.com> wrote:
> Returning to the RTEMS world after many years of being distracted elsewhere:
> rtems 5.3:
> My notes for this attempt:
> package: expat-2.1.0-x86_64-linux-gnu-1
> building: expat-2.1.0-x86_64-linux-gnu-1
> sizes: expat-2.1.0-x86_64-linux-gnu-1: 7.452MB (installed: 1.417MB)
> cleaning: expat-2.1.0-x86_64-linux-gnu-1
> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
> config: tools/rtems-gdb-9.1-1.cfg
> error: shell macro failed:
> /opt/rtems/rtems.20250122.1801.rsb53/rtems-source-builder-5.3/source-builder/sb/rtems-build-dep
> -c gcc -l : 2: error: no library (-l) provided
> Build FAILED
> Build Set: Time 0:00:24.753955
> Build FAILED
> <sb-set-builder --prefix=/opt/rtems/rtems53.20250122.1811 5/rtems-m68k.bset>
> notes:
> -<--force> and <--trace> seem to do nothing
> -I tried a different bset (5/rtems-spart.bset) and I get the same error
> rtems 6.1:
> My notes from this attempt/s
> ../source-builder/sb-set-builder
> --prefix=/opt/rtems/rtems-6.1.build.20250123.0004 6/rtems-m68k
> FAIL!
> downloading: sources/mpc-1.3.1.tar.gz - 755.4kB of 755.4kB (100%)
> building: m68k-rtems6-gcc-13.3.0-newlib-1b3dcfd-x86_64-linux-gnu-1
> error: building m68k-rtems6-gcc-13.3.0-newlib-1b3dcfd-x86_64-linux-gnu-1
> Build FAILED
> See error report:
> rsb-report-m68k-rtems6-gcc-13.3.0-newlib-1b3dcfd-x86_64-linux-gnu-1.txt
> Note: In some cases the error appears only in
> the complete build log (see --log option)
> Build Set: Time 0:13:06.950281
> Build Set: Time 0:13:06.952708
> Build FAILED
> Help appreciated.
> Robert W.
