rsb failure on rtems-m68k target
Joel Sherrill
joel at rtems.org
Thu Jan 23 19:17:42 UTC 2025
I think you are missing the Python development package for your host.
It should be named something like:
sudo apt-get install python3-dev
--joel
On Thu, Jan 23, 2025 at 1:09 PM Robert W <rbtwas at gmail.com> wrote:
> Sorry, forgot to add host info:
> Ubuntu 22.04, on an aspire e 15 laptop.
> Robert W.
> On Thu, Jan 23, 2025 at 11:50 AM Robert W <rbtwas at gmail.com> wrote:
> > Returning to the RTEMS world after many years of being distracted
> elsewhere:
> > rtems 5.3:
> > My notes for this attempt:
> > package: expat-2.1.0-x86_64-linux-gnu-1
> > building: expat-2.1.0-x86_64-linux-gnu-1
> > sizes: expat-2.1.0-x86_64-linux-gnu-1: 7.452MB (installed: 1.417MB)
> > cleaning: expat-2.1.0-x86_64-linux-gnu-1
> > reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
> > reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
> > config: tools/rtems-gdb-9.1-1.cfg
> > error: shell macro failed:
> /opt/rtems/rtems.20250122.1801.rsb53/rtems-source-builder-5.3/source-builder/sb/rtems-build-dep
> > -c gcc -l : 2: error: no library (-l) provided
> > Build FAILED
> > Build Set: Time 0:00:24.753955
> > Build FAILED
> > <sb-set-builder --prefix=/opt/rtems/rtems53.20250122.1811
> 5/rtems-m68k.bset>
> > notes:
> > -<--force> and <--trace> seem to do nothing
> > -I tried a different bset (5/rtems-spart.bset) and I get the
> same error
> > rtems 6.1:
> > My notes from this attempt/s
> > ../source-builder/sb-set-builder
> > --prefix=/opt/rtems/rtems-6.1.build.20250123.0004 6/rtems-m68k
> > FAIL!
> > downloading: sources/mpc-1.3.1.tar.gz - 755.4kB of 755.4kB (100%)
> > building: m68k-rtems6-gcc-13.3.0-newlib-1b3dcfd-x86_64-linux-gnu-1
> > error: building m68k-rtems6-gcc-13.3.0-newlib-1b3dcfd-x86_64-linux-gnu-1
> > Build FAILED
> > See error report:
> > rsb-report-m68k-rtems6-gcc-13.3.0-newlib-1b3dcfd-x86_64-linux-gnu-1.txt
> > Note: In some cases the error appears only in
> > the complete build log (see --log option)
> > Build Set: Time 0:13:06.950281
> > Build Set: Time 0:13:06.952708
> > Build FAILED
> > Help appreciated.
> > Robert W.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20250123/9ec35167/attachment.htm>
