[PATCH] bsps/shared: Fix Coverity warning in MCP7940M
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Aug 2 06:16:58 UTC 2023
Coverity warns that (buf[...] & 0x7) can't be bigger than 7. This patch
removes the unnecessary comparison.
 bsps/shared/dev/rtc/mcp7940m.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/bsps/shared/dev/rtc/mcp7940m.c b/bsps/shared/dev/rtc/mcp7940m.c
index 78a4f21b58..1abc5faaad 100644
--- a/bsps/shared/dev/rtc/mcp7940m.c
+++ b/bsps/shared/dev/rtc/mcp7940m.c
@@ -312,9 +312,8 @@ static int mcp7940m_set_time(int minor, const rtems_time_of_day *time)
   if (rv == 0) {
-    /* Make sure weekday is in range. Otherwise it's not relevant. */
-    if (RTCWKDAY_WKDAY_GET(buf[REG_RTCWKDAY]) < 1 ||
-        RTCWKDAY_WKDAY_GET(buf[REG_RTCWKDAY]) > 7) {
+    /* Make sure weekday is not 0 (out of range). Otherwise it's not used. */
+    if (RTCWKDAY_WKDAY_GET(buf[REG_RTCWKDAY]) < 1) {
       buf[REG_RTCWKDAY] &= ~RTCWKDAY_WKDAY_MASK;
       buf[REG_RTCWKDAY] |= RTCWKDAY_WKDAY(1);
2.35.3
