[PATCH] build: Add PROGRAM_PREFIX option
Thu Aug 10 06:11:06 UTC 2023
On 10/8/2023 3:06 pm, Sebastian Huber wrote:
> On 10.08.23 03:13, Chris Johns wrote:
>> On 9/8/2023 7:12 pm, Sebastian Huber wrote:
>>> On 09.08.23 11:10, Cedric Berger wrote:
>>>> On 09.08.23 10:51, Sebastian Huber wrote:
>>>>> We could add some text to the option description:
>>>>> # Defines the program prefix of tools (compiler, assembler, linker).
>>>>> # This option may be used to build RTEMS with a vendor tool suite.
>>>>> # Please note that using tool suites not provided by the RTEMS Project
>>>>> # may not work as expected.
>>>> If the goal of that comment it to prevent "fielding support related
>>>> questions", I doubt that writing "may not work as expected" will have the
>>>> desired effect...
>>> I am open for alternative wordings.
>> # Defines the program prefix of tools (compiler, assembler, linker) used
>> # to build RTEMS. This option may be used to build RTEMS with a vendor
>> # tool suite. Please note, support issues related to using this option with
>> # vendor tool suites should be directed to the vendor of the tools.
> Sounds good, do you check it in?
I have not. Are you able to? If so please feel free to push the change as approved.
Thanks
