[PATCH rtems-tools] tester/report: Apply test excludes to fatal-error
Kinsey Moore kinsey.moore at oarcorp.com
Thu Aug 17 12:43:05 UTC 2023
On Wed, Aug 16, 2023 at 9:47 PM Chris Johns <chrisj at rtems.org> wrote:
> On 17/8/2023 7:36 am, Kinsey Moore wrote:
> > Before the fatal-error test result type was introduced, minimum.exe was
> > classified as an invalid test since it lacked a proper test header and
> > trailer. This applies the test exclusions to all test states to avoid
> > this happening again in the future.
> I do not think this right. What state are you seeing?
The minimum test fails with a fatal error:
    "*** FATAL ***",
    "fatal source: 0 (INTERNAL_ERROR_CORE)",
    "fatal code: 5 (INTERNAL_ERROR_THREAD_EXITTED)",
    "RTEMS version: 6.0.0.c76c98c344d803fa80361884c4cc79f0b3607ec8",
    "RTEMS tools: 12.3.1 20230626 (RTEMS 6, RSB
8e568b2ca3489d6bfa48e1d29618ea9b48a5b408, Newlib 4c7d0df)",
    "executing thread ID: 0x09010001",
As far as I'm aware, this is a normal exit for minimum since it does
nothing which includes not properly exiting the test by allowing Init() to
return.
> While we cannot determine the pass state because there is no end message
> we can
> determine if the test has timed out or is too long and they should be a
> fail.
This is not timing out or taking too long as per the above. I could move
the check to cover just the invalid/fatal-error checks instead of all of
them if you prefer.
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230817/258669c3/attachment.htm>
