[PATCH] bsps/arm: replace CMSIS v4 with CMSIS v5 files
Karel Gardas karel at functional.vision
Fri Jul 14 08:55:16 UTC 2023
On 7/14/23 01:24, Joel Sherrill wrote:
> On Thu, Jul 13, 2023 at 4:11 PM Karel Gardas <karel at functional.vision>
> wrote:
>        Folks,
>     please take this patch as an attempt to renew old discussion or rather
>     start a new one focused solely on importing new ARM CMSIS code which is
>     (i) under Apache 2 license but (ii) without any NOTICE file.
> The absence of a NOTICE file is OK. If they had one, we would just have
> to pass it along.
> I recall the issue is that "You must cause any modified files to carry
> prominent
> notices stating that You changed the files"
OK, but this is even easier since I have not modified files at all. They
are just verbatim copy.
> My reading is that we would need to pass the NOTICE file along. I personally
> do not see that as a burden unless it contains more than credit or
> permissively
> license info.
OK! I think decision process itself of "unless it contains more than..."
may be seen as a burden. But, fortunately no NOTICE file there, hence no
issue...
>     The patch itself is clear replace of existing files with a new files,
>     plus required files added and old one not needed anymore removed.
>     The patch was very lightly tested by building several ARM BSPs
>     especially those affected by the change.
> Did you have any BSPs to actually test on? What ones can be tested
> for this?
Yes, I can run testsuite on 2 boards I have sitting idle here:
stm32h747i-disco and stm32h7b3i-dk where 747 would test both M7 and M4
variants. By comparing results from current tree and current tree +
patch we may see any unexpected breakage...
>     Thanks for any comments!
> I'm happy with the update and think it is OK license wise. Technically,
> it you
> trust it, I'm ok with it.
Cool! Thanks,
Karel
