[PATCH] build: Add optional RTEMS_VERSION_VC_KEY
Tue Jul 25 22:08:48 UTC 2023
On 26/7/2023 4:27 am, Joel Sherrill wrote:
> On Tue, Jul 25, 2023 at 12:15 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>
> wrote:
>     On 25.07.23 19:09, Joel Sherrill wrote:
>     > On Tue, Jul 25, 2023 at 10:12 AM Sebastian Huber
>     <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>     >     Allow the user to set the version control key.
>     >       spec/build/cpukit/grp.yml             |  2 ++
>     >       spec/build/cpukit/optversionvckey.yml | 20 ++++++++++++++
>     >       wscript                               | 38 ++++++++++++++++-----------
>     >       3 files changed, 44 insertions(+), 16 deletions(-)
>     >       create mode 100644 spec/build/cpukit/optversionvckey.yml
>     >     diff --git a/spec/build/cpukit/grp.yml b/spec/build/cpukit/grp.yml
>     >     index e07e975d7d..fbeab45b5c 100644
>     >     --- a/spec/build/cpukit/grp.yml
>     >     +++ b/spec/build/cpukit/grp.yml
>     >     @@ -18,6 +18,8 @@ links:
>     >         uid: cpuopts
>     >       - role: build-dependency
>     >         uid: cfghdr
>     >     +- role: build-dependency
>     >     +  uid: optversionvckey
>     >         uid: libdebugger
>     >     diff --git a/spec/build/cpukit/optversionvckey.yml
>     >     b/spec/build/cpukit/optversionvckey.yml
>     >     new file mode 100644
>     >     index 0000000000..7197381342
>     >     --- /dev/null
>     >     +++ b/spec/build/cpukit/optversionvckey.yml
>     >     @@ -0,0 +1,20 @@
>     >     +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>     >     +actions:
>     >     +- get-string: null
>     >     +- env-assign: null
>     >     +build-type: option
>     >     +copyrights:
>     >     +- Copyright (C) 2022, 2023 embedded brains GmbH & Co. KG
>     >     +default:
>     >     +- enabled-by: true
>     >     +  value: ''
>     >     +description: |
>     >     +  If defined to a non-empty value, then the value will be used for
>     >     the version
>     >     +  control key returned by rtems_version() and
>     >     rtems_version_control_key(),
>     >     +  otherwise the value will be determined by the Git repository
>     >     containing the
>     >     +  waf top directory.
>     > And would this change for a release tarball?
>     Which RTEMS_VERSION_VC_KEY has a release tarball? What happens if you
>     unpack an release archive in an external Git repository?
> I don't know but think we should discuss it.
> Chris should speak up since the release scripts are his and this
> might be used by the distribution packaging he has made available.
I am not sure what the purpose of this change is. It would be good to understand
what it is for. The RTEMS_VERSION_VC_KEY could mean a number of things such as a
means to set the git hash in sources not in a git repo but that is guess.
