[PATCH] improved error checking in ticks per timeslice
Sun Feb 18 22:31:33 UTC 2024
On 18/2/2024 4:42 am, Gedare Bloom wrote:
> Is there a simple way we can add some checks for modification of
> generated files into a commit hook? And then, point to a documentation
> that helps explain where to go for more guidance depending on the code
> generation source?
We are moving to GitLab so I think avoiding git hooks is something we should
avoid at this point in time. And there are security issues with them. Could a
stage in a CI pipeline handle this? The PR would fail.
> I would use this for all rtems-central generated stuff, and also for
> 3rd party sources where there's an active upstream. I can add such a
> plan to follow #4663 Third-Party Sources Manifest
You would need to find a way to add these files to the repo. Separating the
mapping from the repo would create an external dependency I would prefer we do
not have.
