[PATCH rtems6 - v1 05/16] FIX: Add missing default case
Kinsey Moore kinsey.moore at oarcorp.com
Thu Jan 4 18:48:49 UTC 2024
All of the patches here need an issue reference. Beyond that, this patch is
good to go in. I'm still reviewing the remainder of the set and I'll leave
the renaming discussion to Aaron.
Kinsey
On Thu, Jan 4, 2024 at 12:35 PM <berndmoessner80 at gmail.com> wrote:
> From: Bernd Moessner <berndmoessner80 at gmail.com>
>  cpukit/dev/flash/flashdev.c | 2 ++
>  1 file changed, 2 insertions(+)
> diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
> index 27edead968..8bd3d11246 100644
> --- a/cpukit/dev/flash/flashdev.c
> +++ b/cpukit/dev/flash/flashdev.c
> @@ -390,6 +390,8 @@ static int rtems_flashdev_ioctl(
>      case RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE:
>        err = rtems_flashdev_ioctl_get_write_block_size( flash, arg );
>        break;
> +    default:
> +      err = EINVAL;
>    rtems_flashdev_release( flash );
> 2.34.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240104/6284c364/attachment.htm>
