[RTEMS Tools 0/1] trace/wscript: Improve C++ standard selection
Cedric Berger cedric at precidata.com
Fri Jan 19 08:09:37 UTC 2024
Hello,
On 19.01.2024 08:55, Sebastian Huber wrote:
> On 19.01.24 07:58, Sebastian Huber wrote:
>> This patch fixes bugs #4908 and #4965 which were reported by RTMES
>> users.  The patch is from 19 May 2023 and was blocked due to missing
>> tests on macOS.  I have no macOS system for tests.  Would someone mind
>> testing this patch?  It would be nice to build the RTEMS Tools on modern
>> Linux systems with a standard LLVM package.
> I added a simple CI script to our Github fork of rtems-tools:
> https://github.com/embedded-brains/rtems-tools
> It seems that the current tools build with LLVM installed on
> ubuntu-latest event without the patch:
> https://github.com/embedded-brains/rtems-tools/actions/runs/7580906673
> It builds also with the patch:
> https://github.com/embedded-brains/rtems-tools/actions/runs/7580925618
> I installed LLVM on macOS using brew, however, the rtems-tools didn't
> pick it up. How can I build the rtems-tools on macOS with LLVM support?
I'm willing to spend some time testing stuff on macOS.
However, I don't really understand why you installed LLVM using brew:
people on MacOS usually use the standard XCode compiler from Apple,
which is itself based on LLVM.
What needs to be tested exactly?
Cedric
