A problem about _Objects_Open_u32 and _Objects_Close
Ashi
ashi08104 at gmail.com
Sun Aug 19 12:36:40 UTC 2012
Hi, all.
I have a problem about the _Objects_Open_u32 and _Objects_Close function
(e.g They are called in key create[0] and key delete[1]). I find the
description of _Objects_Open_u32() function says:
"This function places the_object control pointer and object name in the
-Local Pointer- and -Local Name Tables-, respectively. "
It seems that it is kind of registration operation, but when should I call
these Object Open and Close function? I feel I should call it just after
_Object_Allocate() is called. E.g. in key create[0], the
_Object_Allocate() is called in _POSIX_Keys_Allocate(). And I'm also
curious about what the -Local Pointer- and -Local Name Tables- is used for.
links:
[0]
https://github.com/ashi08104/rtems/blob/POSIX_Key_review/cpukit/posix/src/keycreate.c
[1]
https://github.com/ashi08104/rtems/blob/POSIX_Key_review/cpukit/posix/src/keydelete.c
Best wishes!
Zhongwei Yao
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120819/939f0153/attachment.html>
