[GSOC] RTEMS File Systems Related Hierarchy
Sebastian Huber
Fri Aug 3 07:05:56 UTC 2012
Hello,
On 08/02/2012 10:50 PM, Xiaochen Pan wrote:
> Hello,
> I read the doc on File Systems development:
> http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.10.2/share/rtems/pdf/filesystem.pdf
for the current Git master this document is out-dated. You should look
directly in the source files.
http://git.rtems.org/rtems.git/tree/cpukit/libcsupport/include/rtems/libio.h
http://git.rtems.org/rtems.git/tree/cpukit/libcsupport/include/rtems/libio_.h
If you want to add a new file system, you have to implement the operations
(rtems_filesystem_operations_table) and node handlers
(rtems_filesystem_file_handlers_r).
For generic path evaluation see rtems_filesystem_eval_path_generic(). It
should be pretty easy now to add a new file system to RTEMS.
File systems using block devices should access them via the Bdbuf:
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__rtems__bdbuf.html
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
