Which IDE you guys use to develop and debug RTEMS
Mon Jul 16 07:59:25 UTC 2012
On 07/16/2012 09:53 AM, SAeeD wrote:
> Gedare, you mean you used "--enable-RTEMS-debug" option when configuring RTEMS
> in order to be able to debug RTEMS via GDB? Cause I want to debug RTEMS at C level.
> Or you use GDB to debug at Assembly level?
GDB can debug at C and assembly level.
> Sebastian, you mean I import operating system's code to TRACE32 software in
> order to use Lauterbach PowerTrace II debugger?
You only need the ELF-file.
> And about CDT plug-in for eclipse, can I use operating system's Makefile and
> configurations in the plug-in to make the operating system itself? Because so
> far, I've used CDT with my "make install" libraries in order to develop
> software for my specific BSP and not RTEMS itself.
What is the difference between the BSP and RTEMS?  It all ends up in one ELF-file
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
