[PATCH] rbtree: Formatting.
Sun May 13 17:39:56 UTC 2012
Fix formatting in red-black tree code to make it more consistent with
the style of other supercore code.
 cpukit/score/include/rtems/score/rbtree.h  |   74 ++++++------
 cpukit/score/inline/rtems/score/rbtree.inl |  176 ++++++++++++----------------
 cpukit/score/src/rbtree.c                  |   26 +---
 cpukit/score/src/rbtreeextract.c           |  139 +++++++++++------------
 cpukit/score/src/rbtreefind.c              |   57 ++++++----
 cpukit/score/src/rbtreefindheader.c        |   34 ++----
 cpukit/score/src/rbtreeget.c               |   36 ++----
 cpukit/score/src/rbtreeinsert.c            |  107 +++++++----------
 8 files changed, 282 insertions(+), 367 deletions(-)
diff --git a/cpukit/score/include/rtems/score/rbtree.h b/cpukit/score/include/rtems/score/rbtree.h
index 82bdb6d..271e2fa 100644
--- a/cpukit/score/include/rtems/score/rbtree.h
+++ b/cpukit/score/include/rtems/score/rbtree.h
@@ -186,9 +186,16 @@ RBTree_Node name = RBTREE_NODE_INITIALIZER_EMPTY(name)
  *  @brief Initialize a RBTree Header
- *  This routine initializes @a the_rbtree structure to manage the
+ *  This routine initializes a red-black tree to manage the
  *  contiguous array of @a number_nodes nodes which starts at
- *  @a starting_address.  Each node is of @a node_size bytes.
+ *  @a starting_address. Each node is of @a node_size bytes.
+ * @param[in] the_rbtree The red-black tree.
+ * @param[in] compare_function Node comparison handler.
+ * @param[in] starting_address Base of array of nodes.
+ * @param[in] number_nodes Count of nodes in array.
+ * @param[in] node_size Size of each node.
+ * @param[in] is_unique True if nodes with the same key are not allowed.
 void _RBTree_Initialize(
   RBTree_Control          *the_rbtree,
@@ -217,12 +224,22 @@ RBTree_Node *_RBTree_Get(
   RBTree_Direction dir
+/** @brief Find the node with given key in the tree
+ *  This function returns a pointer to the node in @a the_rbtree
+ *  having key equal to key of @a the_node if it exists,
+ *  and NULL if not. @a the_node has to be made up before a search.
+ *  If the tree is stable duplicate keys act as FIFO.
+RBTree_Node *_RBTree_Find_unprotected(
+  RBTree_Control *the_rbtree,
+  RBTree_Node *the_node
- * @brief Find the node with given key in the tree
+ * @copydoc _RBTree_Find_unprotected()
- *  This function returns a pointer to the node with key equal to a key
- *  of @a the_node if it exists in the Red-Black Tree @a the_rbtree,
- *  and NULL if not.
+ * This function disables interrupts to protect the operation.
 RBTree_Node *_RBTree_Find(
@@ -240,17 +257,15 @@ RBTree_Control *_RBTree_Find_header(
- * @brief Insert a Node (unprotected)
+ * @brief Inserts a node into a red-black tree.
- *  This routine inserts @a the_node on the Red-Black Tree @a the_rbtree.
+ * @param[in] the_node The node to insert.
- *  @retval 0 Successfully inserted.
- *  @retval -1 NULL @a the_node.
- *  @retval RBTree_Node* if one with equal value to @a the_node 's key exists
- *          in an unique @a the_rbtree.
- *  @note It does NOT disable interrupts to ensure the atomicity
- *        of the extract operation.
+ *  @retval 0 if successfully inserted.
+ *  @retval a node that compares equal to @a the_node if it exists and
+ *          the_rbtree->is_unique is true
+ *  @retval -1 otherwise.
 RBTree_Node *_RBTree_Insert_unprotected(
@@ -258,31 +273,20 @@ RBTree_Node *_RBTree_Insert_unprotected(
- *  @brief Insert a node on a rbtree
- *  This routine inserts @a the_node on the tree @a the_rbtree.
+ *  @copydoc _RBTree_Insert_unprotected()
- *  @note It disables interrupts to ensure the atomicity
 RBTree_Node *_RBTree_Insert(
- * @brief Extract a Node (unprotected)
- *  This routine extracts (removes) @a the_node from @a the_rbtree.
+ * @brief Extracts (removes) a node from a red-black tree.
+ * @param[in] the_node The node to extract.
 void _RBTree_Extract_unprotected(
@@ -290,12 +294,9 @@ void _RBTree_Extract_unprotected(
- *  @brief Delete a node from the rbtree
- *  This routine deletes @a the_node from @a the_rbtree.
+ *  @copydoc _RBTree_Extract_unprotected()
- *  @note It disables interrupts to ensure the atomicity of the
- *  append operation.
 void _RBTree_Extract(
@@ -370,4 +371,3 @@ void _RBTree_Iterate_unprotected(
 #endif
-/* end of include file */
diff --git a/cpukit/score/inline/rtems/score/rbtree.inl b/cpukit/score/inline/rtems/score/rbtree.inl
index c5187a0..a183668 100644
--- a/cpukit/score/inline/rtems/score/rbtree.inl
+++ b/cpukit/score/inline/rtems/score/rbtree.inl
@@ -46,8 +46,8 @@ RTEMS_INLINE_ROUTINE RBTree_Direction _RBTree_Opposite_direction(
 RTEMS_INLINE_ROUTINE void _RBTree_Set_off_rbtree(
-    RBTree_Node *node
+  RBTree_Node *node
   node->parent = node->child[RBT_LEFT] = node->child[RBT_RIGHT] = NULL;
@@ -58,10 +58,10 @@ RTEMS_INLINE_ROUTINE void _RBTree_Set_off_rbtree(
  *  off rbtree if the parent and child fields are set to NULL.
 RTEMS_INLINE_ROUTINE bool _RBTree_Is_node_off_rbtree(
-    const RBTree_Node *node
+  const RBTree_Node *node
-  return (node->parent == NULL) && (node->child[RBT_LEFT] == NULL) && (node->child[RBT_RIGHT] == NULL);
+  return !node->parent && !node->child[RBT_LEFT] && !node->child[RBT_RIGHT];
 /** @brief Are Two Nodes Equal
@@ -70,9 +70,9 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Is_node_off_rbtree(
  *  and false otherwise.
 RTEMS_INLINE_ROUTINE bool _RBTree_Are_nodes_equal(
-    const RBTree_Node *left,
-    const RBTree_Node *right
+  const RBTree_Node *left,
+  const RBTree_Node *right
   return left == right;
@@ -82,10 +82,10 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Are_nodes_equal(
  *  This function returns true if @a the_rbtree is NULL and false otherwise.
 RTEMS_INLINE_ROUTINE bool _RBTree_Is_null(
-    const RBTree_Control *the_rbtree
+  const RBTree_Control *the_rbtree
-  return (the_rbtree == NULL);
+  return the_rbtree == NULL;
 /** @brief Is the RBTree Node Pointer NULL
@@ -93,13 +93,12 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Is_null(
  *  This function returns true if @a the_node is NULL and false otherwise.
 RTEMS_INLINE_ROUTINE bool _RBTree_Is_null_node(
-    const RBTree_Node *the_node
+  const RBTree_Node *the_node
-  return (the_node == NULL);
+  return the_node == NULL;
 /** @brief Return pointer to RBTree's root node
  *  This function returns a pointer to the root node of @a the_rbtree.
@@ -132,7 +131,9 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Parent(
-  if (!the_node->parent->parent) return NULL;
+  if ( !the_node->parent->parent ) {
+    return NULL;
   return the_node->parent;
@@ -180,7 +181,7 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Is_empty(
-  return (the_rbtree->root == NULL);
+  return the_rbtree->root == NULL;
 /** @brief Is this the First Node on the RBTree
@@ -188,7 +189,6 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Is_empty(
  *  This function returns true if @a the_node is the first node on
  *  @a the_rbtree and false otherwise. @a dir specifies whether first means
  *  minimum (0) or maximum (1).
 RTEMS_INLINE_ROUTINE bool _RBTree_Is_first(
   const RBTree_Control *the_rbtree,
@@ -196,7 +196,7 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Is_first(
-  return (the_node == _RBTree_First(the_rbtree, dir));
+  return the_node == _RBTree_First(the_rbtree, dir);
 /** @brief Is this node red?
@@ -204,10 +204,10 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Is_first(
  *  This function returns true if @a the_node is red and false otherwise.
 RTEMS_INLINE_ROUTINE bool _RBTree_Is_red(
-  return (the_node && the_node->color == RBT_RED);
+  return the_node && the_node->color == RBT_RED;
@@ -215,14 +215,16 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Is_red(
  *  This function returns true if there is only one node on @a the_rbtree and
  *  false otherwise.
 RTEMS_INLINE_ROUTINE bool _RBTree_Has_only_one_node(
-  if(!the_rbtree) return NULL; /* TODO: expected behavior? */
-  return (the_rbtree->root->child[RBT_LEFT] == NULL && the_rbtree->root->child[RBT_RIGHT] == NULL);
+  RBTree_Node *root = the_rbtree->root;
+  if ( !the_rbtree || !root ) {
+    return false;
+  return !root->child[RBT_LEFT] && !root->child[RBT_RIGHT];
 /** @brief Is this Node the RBTree root
@@ -235,7 +237,7 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Is_root(
-  return (the_node == _RBTree_Root(the_rbtree));
+  return the_node == _RBTree_Root(the_rbtree);
 /** @brief Initialize this RBTree as Empty
@@ -243,10 +245,10 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Is_root(
  *  This routine initializes @a the_rbtree to contain zero nodes.
 RTEMS_INLINE_ROUTINE void _RBTree_Initialize_empty(
-    RBTree_Control          *the_rbtree,
-    RBTree_Compare_function  compare_function,
-    bool                     is_unique
+  RBTree_Compare_function  compare_function,
+  bool                     is_unique
   the_rbtree->permanent_null   = NULL;
   the_rbtree->root             = NULL;
@@ -260,17 +262,15 @@ RTEMS_INLINE_ROUTINE void _RBTree_Initialize_empty(
  *  This function returns a pointer to the grandparent of @a the_node if it
  *  exists, and NULL if not.
 RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Grandparent(
-  if(!the_node) return NULL;
-  if(!(the_node->parent)) return NULL;
-  if(!(the_node->parent->parent)) return NULL;
-  if(!(the_node->parent->parent->parent)) return NULL;
-  return(the_node->parent->parent);
+  RBTree_Node *p, *g;
+  p = _RBTree_Parent( the_node );
+  g = _RBTree_Parent( p );
+  return g;
 /** @brief Return a pointer to node's sibling
@@ -282,11 +282,12 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Sibling(
+  RBTree_Node *p = _RBTree_Parent( the_node );
+  if ( !p ) {
+    return NULL;
-  if(the_node == the_node->parent->child[RBT_LEFT])
+  if ( the_node == the_node->parent->child[RBT_LEFT] )
     return the_node->parent->child[RBT_RIGHT];
   else
     return the_node->parent->child[RBT_LEFT];
@@ -301,10 +302,9 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Parent_sibling(
-  if(_RBTree_Grandparent(the_node) == NULL) return NULL;
-  return _RBTree_Sibling(the_node->parent);
+  return _RBTree_Sibling( p );
 /** @brief Find the RBTree_Control header given a node in the tree
@@ -313,13 +313,17 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Parent_sibling(
  *  Tree containing @a the_node if it exists, and NULL if not.
 RTEMS_INLINE_ROUTINE RBTree_Control *_RBTree_Find_header_unprotected(
-    RBTree_Node *the_node
-  while(the_node->parent) the_node = the_node->parent;
-  return (RBTree_Control*)the_node;
+  RBTree_Node *p;
+  if ( !the_node ) {
+    return NULL;
+  while ( ( p = _RBTree_Parent(the_node) ) ) {
+    the_node = p;
+  return (RBTree_Control*) the_node->parent;
 RTEMS_INLINE_ROUTINE bool _RBTree_Is_equal( int compare_result )
@@ -327,53 +331,16 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Is_equal( int compare_result )
   return compare_result == 0;
-RTEMS_INLINE_ROUTINE bool _RBTree_Is_greater(
-  int compare_result
+RTEMS_INLINE_ROUTINE bool _RBTree_Is_greater( int compare_result )
   return compare_result > 0;
-RTEMS_INLINE_ROUTINE bool _RBTree_Is_lesser(
+RTEMS_INLINE_ROUTINE bool _RBTree_Is_lesser( int compare_result )
   return compare_result < 0;
-/** @brief Find the node with given key in the tree
- *  This function returns a pointer to the node in @a the_rbtree
- *  having key equal to key of  @a the_node if it exists,
- *  and NULL if not. @a the_node has to be made up before a search.
- *  @note If the tree is not unique and contains duplicate keys, the set
- *        of duplicate keys acts as FIFO.
-RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Find_unprotected(
-  RBTree_Node* iter_node = the_rbtree->root;
-  RBTree_Node* found = NULL;
-  int compare_result;
-  while (iter_node) {
-    compare_result = the_rbtree->compare_function(the_node, iter_node);
-    if ( _RBTree_Is_equal( compare_result ) ) {
-      found = iter_node;
-      if ( the_rbtree->is_unique )
-        break;
-    RBTree_Direction dir =
-      (RBTree_Direction) _RBTree_Is_greater( compare_result );
-    iter_node = iter_node->child[dir];
-  } /* while(iter_node) */
-  return found;
  * @brief Returns the predecessor of a node.
@@ -444,12 +411,12 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Successor(
  *  @note This routine may return NULL if the RBTree is empty.
 RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Get_unprotected(
+  RBTree_Direction dir
   RBTree_Node *the_node = the_rbtree->first[dir];
-  _RBTree_Extract_unprotected(the_rbtree, the_node);
+  _RBTree_Extract_unprotected( the_rbtree, the_node );
   return the_node;
@@ -459,19 +426,24 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Get_unprotected(
  *  @a the_node with its child\[@a dir\].
 RTEMS_INLINE_ROUTINE void _RBTree_Rotate(
-    RBTree_Node *the_node,
+  RBTree_Node *the_node,
   RBTree_Node *c;
-  if (the_node == NULL) return;
-  if (the_node->child[_RBTree_Opposite_direction(dir)] == NULL) return;
+    return;
+  if ( !the_node->child[_RBTree_Opposite_direction(dir)] ) {
+    return;
   c = the_node->child[_RBTree_Opposite_direction(dir)];
   the_node->child[_RBTree_Opposite_direction(dir)] = c->child[dir];
-  if (c->child[dir])
+  if ( c->child[dir] ) {
     c->child[dir]->parent = the_node;
   c->child[dir] = the_node;
@@ -487,9 +459,9 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Is_unique(
-  return( the_rbtree && the_rbtree->is_unique );
+  return the_rbtree && the_rbtree->is_unique;
 #endif
diff --git a/cpukit/score/src/rbtree.c b/cpukit/score/src/rbtree.c
index 48ea2a0..a953d7d 100644
--- a/cpukit/score/src/rbtree.c
+++ b/cpukit/score/src/rbtree.c
@@ -15,20 +15,6 @@
 #include <rtems/score/rbtree.h>
 #include <rtems/score/isr.h>
- *  _RBTree_Initialize
- *  This kernel routine initializes a Red-Black Tree.
- *  Input parameters:
- *    the_rbtree        - pointer to rbtree header
- *    starting_address - starting address of first node
- *    number_nodes     - number of nodes in rbtree
- *    node_size        - size of node in bytes
- *  Output parameters:  NONE
@@ -41,17 +27,17 @@ void _RBTree_Initialize(
   size_t      count;
   RBTree_Node *next;
-  /* TODO: Error message? */
-  if (!the_rbtree) return;
+  if ( !the_rbtree ) {
+    return;
   /* could do sanity checks here */
-  _RBTree_Initialize_empty(the_rbtree, compare_function, is_unique);
+  _RBTree_Initialize_empty( the_rbtree, compare_function, is_unique );
   count = number_nodes;
   next  = starting_address;
   while ( count-- ) {
-    _RBTree_Insert_unprotected(the_rbtree, next);
-    next           = (RBTree_Node *)
-                        _Addresses_Add_offset( (void *) next, node_size );
+    _RBTree_Insert_unprotected( the_rbtree, next );
+    next = (RBTree_Node *) _Addresses_Add_offset( (void *) next, node_size );
diff --git a/cpukit/score/src/rbtreeextract.c b/cpukit/score/src/rbtreeextract.c
index 3079f10..336d3ba 100644
--- a/cpukit/score/src/rbtreeextract.c
+++ b/cpukit/score/src/rbtreeextract.c
@@ -1,5 +1,12 @@
+ * @ingroup ScoreRBTree
+ * @brief _RBTree_Extract_unprotected and _RBTree_Extract
- *  Copyright (c) 2010 Gedare Bloom.
+ *  Copyright (c) 2010-2012 Gedare Bloom.
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
@@ -10,58 +17,56 @@
 #include "config.h"
 #endif
-#include <rtems/system.h>
-#include <rtems/score/address.h>
-/** @brief  Validate and fix-up tree properties after deleting a node
- *  This routine is called on a black node, @a the_node, after its deletion.
- *  This function maintains the properties of the red-black tree.
+ * Validate and fix-up tree properties after deleting a node
+ * This routine is called on a black node, the_node, after its deletion.
+ * This function maintains the properties of the red-black tree.
-static void _RBTree_Extract_validate_unprotected(
+static void _RBTree_Extract_validate(
   RBTree_Node *parent, *sibling;
   RBTree_Direction dir;
   parent = the_node->parent;
-  if(!parent->parent) return;
+  if( !parent->parent ) {
+    return;
   sibling = _RBTree_Sibling(the_node);
   /* continue to correct tree as long as the_node is black and not the root */
-  while (!_RBTree_Is_red(the_node) && parent->parent) {
+  while ( !_RBTree_Is_red( the_node ) && parent->parent ) {
     /* if sibling is red, switch parent (black) and sibling colors,
      * then rotate parent left, making the sibling be the_node's grandparent.
      * Now the_node has a black sibling and red parent. After rotation,
      * update sibling pointer.
-    if (_RBTree_Is_red(sibling)) {
+    if ( _RBTree_Is_red( sibling ) ) {
       parent->color = RBT_RED;
       sibling->color = RBT_BLACK;
       dir = the_node != parent->child[0];
-      _RBTree_Rotate(parent, dir);
-      sibling = parent->child[_RBTree_Opposite_direction(dir)];
+      _RBTree_Rotate( parent, dir );
+      sibling = parent->child[_RBTree_Opposite_direction( dir )];
     /* sibling is black, see if both of its children are also black. */
-    if (!_RBTree_Is_red(sibling->child[RBT_RIGHT]) &&
-        !_RBTree_Is_red(sibling->child[RBT_LEFT])) {
+    if ( !_RBTree_Is_red( sibling->child[RBT_RIGHT] )
+         && !_RBTree_Is_red( sibling->child[RBT_LEFT] )
         sibling->color = RBT_RED;
-        if (_RBTree_Is_red(parent)) {
+        if ( _RBTree_Is_red( parent ) ) {
           parent->color = RBT_BLACK;
           break;
         the_node = parent; /* done if parent is red */
-        sibling = _RBTree_Sibling(the_node);
+        sibling = _RBTree_Sibling( the_node );
     } else {
       /* at least one of sibling's children is red. we now proceed in two
        * cases, either the_node is to the left or the right of the parent.
@@ -70,52 +75,51 @@ static void _RBTree_Extract_validate_unprotected(
        * Then switch the sibling and parent colors, and rotate through parent.
-      if (!_RBTree_Is_red(sibling->child[_RBTree_Opposite_direction(dir)])) {
+      if (
+          !_RBTree_Is_red( sibling->child[_RBTree_Opposite_direction( dir )] )
         sibling->child[dir]->color = RBT_BLACK;
-        _RBTree_Rotate(sibling, _RBTree_Opposite_direction(dir));
+        _RBTree_Rotate( sibling, _RBTree_Opposite_direction( dir ) );
       sibling->color = parent->color;
-      sibling->child[_RBTree_Opposite_direction(dir)]->color = RBT_BLACK;
+      sibling->child[_RBTree_Opposite_direction( dir )]->color = RBT_BLACK;
       break; /* done */
   } /* while */
-  if(!the_node->parent->parent) the_node->color = RBT_BLACK;
+    the_node->color = RBT_BLACK;
-/** @brief Extract a Node (unprotected)
   RBTree_Node *leaf, *target;
   RBTree_Color victim_color;
-  if (!the_node) return;
+    return;
   /* check if min needs to be updated */
-  if (the_node == the_rbtree->first[RBT_LEFT]) {
+  if ( the_node == the_rbtree->first[RBT_LEFT] ) {
     RBTree_Node *next;
-    next = _RBTree_Successor_unprotected(the_node);
+    next = _RBTree_Successor_unprotected( the_node );
     the_rbtree->first[RBT_LEFT] = next;
   /* Check if max needs to be updated. min=max for 1 element trees so
    * do not use else if here. */
-  if (the_node == the_rbtree->first[RBT_RIGHT]) {
+  if ( the_node == the_rbtree->first[RBT_RIGHT] ) {
     RBTree_Node *previous;
-    previous = _RBTree_Predecessor_unprotected(the_node);
+    previous = _RBTree_Predecessor_unprotected( the_node );
     the_rbtree->first[RBT_RIGHT] = previous;
@@ -125,10 +129,11 @@ void _RBTree_Extract_unprotected(
    * and replace the_node with the target node. This maintains the binary
    * search tree property, but may violate the red-black properties.
-  if (the_node->child[RBT_LEFT] && the_node->child[RBT_RIGHT]) {
+  if ( the_node->child[RBT_LEFT] && the_node->child[RBT_RIGHT] ) {
     target = the_node->child[RBT_LEFT]; /* find max in node->child[RBT_LEFT] */
-    while (target->child[RBT_RIGHT]) target = target->child[RBT_RIGHT];
+    while ( target->child[RBT_RIGHT] ) {
+      target = target->child[RBT_RIGHT];
     /* if the target node has a child, need to move it up the tree into
      * target's position (target is the right child of target->parent)
@@ -137,11 +142,11 @@ void _RBTree_Extract_unprotected(
      * For now we store the color of the node being deleted in victim_color.
     leaf = target->child[RBT_LEFT];
-    if(leaf) {
+    if ( leaf ) {
       leaf->parent = target->parent;
     } else {
       /* fix the tree here if the child is a null leaf. */
-      _RBTree_Extract_validate_unprotected(target);
+      _RBTree_Extract_validate( target );
     victim_color = target->color;
     dir = target != target->parent->child[0];
@@ -153,16 +158,17 @@ void _RBTree_Extract_unprotected(
     /* set target's new children to the original node's children */
     target->child[RBT_RIGHT] = the_node->child[RBT_RIGHT];
-    if (the_node->child[RBT_RIGHT])
+    if ( the_node->child[RBT_RIGHT] ) {
       the_node->child[RBT_RIGHT]->parent = target;
     target->child[RBT_LEFT] = the_node->child[RBT_LEFT];
-    if (the_node->child[RBT_LEFT])
+    if ( the_node->child[RBT_LEFT] ) {
       the_node->child[RBT_LEFT]->parent = target;
     /* finally, update the parent node and recolor. target has completely
      * replaced the_node, and target's child has moved up the tree if needed.
-     * the_node is no longer part of the tree, although it has valid pointers
-     * still.
+     * the_node is no longer part of the tree, although it has valid pointers.
     target->parent = the_node->parent;
     target->color = the_node->color;
@@ -178,7 +184,7 @@ void _RBTree_Extract_unprotected(
       leaf->parent = the_node->parent;
     } else {
-      _RBTree_Extract_validate_unprotected(the_node);
+      _RBTree_Extract_validate( the_node );
     victim_color = the_node->color;
@@ -192,34 +198,21 @@ void _RBTree_Extract_unprotected(
    *   1. Deleted a red node, its child must be black. Nothing must be done.
    *   2. Deleted a black node, its child must be red. Paint child black.
-  if (victim_color == RBT_BLACK) { /* eliminate case 1 */
-    if (leaf) {
+  if ( victim_color == RBT_BLACK ) { /* eliminate case 1 */
+    if ( leaf ) {
       leaf->color = RBT_BLACK; /* case 2 */
   /* Wipe the_node */
-  _RBTree_Set_off_rbtree(the_node);
+  _RBTree_Set_off_rbtree( the_node );
   /* set root to black, if it exists */
-  if (the_rbtree->root) the_rbtree->root->color = RBT_BLACK;
+  if ( the_rbtree->root ) {
+    the_rbtree->root->color = RBT_BLACK;
- *  _RBTree_Extract
- *  This kernel routine deletes the given node from a rbtree.
- *    node - pointer to node in rbtree to be deleted
- *  INTERRUPT LATENCY:
- *    only case
@@ -228,6 +221,6 @@ void _RBTree_Extract(
   ISR_Level level;
   _ISR_Disable( level );
-    _RBTree_Extract_unprotected( the_rbtree, the_node );
   _ISR_Enable( level );
diff --git a/cpukit/score/src/rbtreefind.c b/cpukit/score/src/rbtreefind.c
index 07cbb3f..643b2ff 100644
--- a/cpukit/score/src/rbtreefind.c
+++ b/cpukit/score/src/rbtreefind.c
@@ -1,5 +1,13 @@
+ * @file
+ * @brief _RBTree_Find_unprotected and _RBTree_Find.
@@ -10,29 +18,33 @@
 #include "config.h"
 #endif
- *  _RBTree_Find
- *  This kernel routine returns a pointer to the rbtree node containing the
- *  given key within the given tree, if it exists, or NULL otherwise.
- *    the_rbtree - pointer to rbtree control
- *    search_node - node with the key to search for
- *    return_node - pointer to control header of rbtree
- *    NULL   - if there is no control header available (the node is not part
- *    of a tree)
- *    only case
+  RBTree_Node* iter_node = the_rbtree->root;
+  RBTree_Node* found = NULL;
+  RBTree_Direction dir;
+  int compare_result;
+  while ( iter_node ) {
+    compare_result = the_rbtree->compare_function( the_node, iter_node );
+    if ( _RBTree_Is_equal( compare_result ) ) {
+      found = iter_node;
+      if ( !the_rbtree->is_unique )
+        break;
+    dir = (RBTree_Direction)_RBTree_Is_greater( compare_result );
+    iter_node = iter_node->child[dir];
+  return found;
@@ -42,9 +54,8 @@ RBTree_Node *_RBTree_Find(
   ISR_Level          level;
   RBTree_Node *return_node;
-  return_node = NULL;
-      return_node = _RBTree_Find_unprotected( the_rbtree, search_node );
+  return_node = _RBTree_Find_unprotected( the_rbtree, search_node );
   return return_node;
diff --git a/cpukit/score/src/rbtreefindheader.c b/cpukit/score/src/rbtreefindheader.c
index 99b0387..4178d6d 100644
--- a/cpukit/score/src/rbtreefindheader.c
+++ b/cpukit/score/src/rbtreefindheader.c
@@ -1,5 +1,12 @@
+ * @brief _RBTree_Find_header
@@ -10,39 +17,18 @@
 #include "config.h"
 #endif
- *  _RBTree_Find_header
- *  This kernel routine returns a pointer to the rbtree header of the tree
- *  containing the given node.
- *    the_node - pointer to rbtree node
- *    return_header - pointer to control header of rbtree
- *    of a tree)
- *    only case
-  ISR_Level          level;
+  ISR_Level level;
   RBTree_Control *return_header;
-  return_header = NULL;
-      return_header = _RBTree_Find_header_unprotected( the_node );
+  return_header = _RBTree_Find_header_unprotected( the_node );
   return return_header;
diff --git a/cpukit/score/src/rbtreeget.c b/cpukit/score/src/rbtreeget.c
index 81e9161..47453c2 100644
--- a/cpukit/score/src/rbtreeget.c
+++ b/cpukit/score/src/rbtreeget.c
@@ -1,5 +1,13 @@
+ * @file
+ * @brief _RBTree_Get
@@ -10,41 +18,19 @@
 #include "config.h"
 #endif
- *  _RBTree_Get
- *  This kernel routine returns a pointer to a node taken from the
- *  given rbtree.
- *    dir - specifies min (0) or max (1)
- *    return_node - pointer to node in rbtree allocated
- *    NULL   - if no nodes available
- *    only case
-  ISR_Level          level;
+  ISR_Level level;
-      return_node = _RBTree_Get_unprotected( the_rbtree, dir );
+  return_node = _RBTree_Get_unprotected( the_rbtree, dir );
   return return_node;
diff --git a/cpukit/score/src/rbtreeinsert.c b/cpukit/score/src/rbtreeinsert.c
index 57a36b8..9c889bd 100644
--- a/cpukit/score/src/rbtreeinsert.c
+++ b/cpukit/score/src/rbtreeinsert.c
@@ -1,3 +1,10 @@
+ * @brief _RBTree_Insert_unprotected and _RBTree_Insert
@@ -10,34 +17,31 @@
 #include "config.h"
 #endif
-/** @brief Validate and fix-up tree properties for a new insert/colored node
+ * Validate and fix-up tree properties for a newly inserted/colored node.
- *  This routine checks and fixes the Red-Black Tree properties based on
- *  @a the_node being just added to the tree.
+ * Checks and fixes the red-black tree properties based on the_node being
+ * just added to the tree as a leaf with the color red.
- *  @note It does NOT disable interrupts to ensure the atomicity of the
+ * Note: the insert root case is handled already so no special care is needed.
-static void _RBTree_Validate_insert_unprotected(
+static void _RBTree_Insert_validate(
-  RBTree_Node *u,*g;
+  RBTree_Node *u, *g;
-  /* note: the insert root case is handled already */
   /* if the parent is black, nothing needs to be done
    * otherwise may need to loop a few times */
-  while (_RBTree_Is_red(_RBTree_Parent(the_node))) {
-    u = _RBTree_Parent_sibling(the_node);
+  while ( _RBTree_Is_red( _RBTree_Parent( the_node ) ) ) {
+    u = _RBTree_Parent_sibling( the_node );
     g = the_node->parent->parent;
     /* if uncle is red, repaint uncle/parent black and grandparent red */
-    if(_RBTree_Is_red(u)) {
+    if( _RBTree_Is_red( u ) ) {
       the_node->parent->color = RBT_BLACK;
       u->color = RBT_BLACK;
       g->color = RBT_RED;
@@ -47,45 +51,38 @@ static void _RBTree_Validate_insert_unprotected(
       RBTree_Direction pdir = the_node->parent != g->child[0];
       /* ensure node is on the same branch direction as parent */
-      if (dir != pdir) {
-        _RBTree_Rotate(the_node->parent, pdir);
+      if ( dir != pdir ) {
+        _RBTree_Rotate( the_node->parent, pdir );
         the_node = the_node->child[pdir];
       g->color = RBT_RED;
       /* now rotate grandparent in the other branch direction (toward uncle) */
-      _RBTree_Rotate(g, (1-pdir));
+      _RBTree_Rotate( g, ( _RBTree_Opposite_direction( pdir ) ) );
+  /* if the_node is now the root recolor it black */
-/** @brief Insert a Node (unprotected)
- *  @retval RBTree_Node* if one with equal key to the key of @a the_node exists
-  if(!the_node) return (RBTree_Node*)-1;
+    return (RBTree_Node*)-1;
   RBTree_Node *iter_node = the_rbtree->root;
   int compare_result;
-  if (!iter_node) { /* special case: first node inserted */
+  if ( !iter_node ) {
+    /* special case: first node inserted */
     the_rbtree->root = the_node;
     the_rbtree->first[0] = the_rbtree->first[1] = the_node;
@@ -93,12 +90,13 @@ RBTree_Node *_RBTree_Insert_unprotected(
     the_node->child[RBT_LEFT] = the_node->child[RBT_RIGHT] = NULL;
   } else {
     /* typical binary search tree insert, descend tree to leaf and insert */
-      if ( the_rbtree->is_unique && _RBTree_Is_equal( compare_result ) )
+      if ( the_rbtree->is_unique && _RBTree_Is_equal( compare_result ) ) {
         return iter_node;
       RBTree_Direction dir = !_RBTree_Is_lesser( compare_result );
-      if (!iter_node->child[dir]) {
+      if ( !iter_node->child[dir] ) {
         the_node->color = RBT_RED;
         iter_node->child[dir] = the_node;
@@ -106,10 +104,10 @@ RBTree_Node *_RBTree_Insert_unprotected(
         /* update min/max */
             the_node,
-            _RBTree_First(the_rbtree, dir)
+            _RBTree_First( the_rbtree, dir )
-        if ( (!dir && _RBTree_Is_lesser(compare_result)) ||
-              (dir && _RBTree_Is_greater(compare_result)) ) {
+        if ( ( !dir && _RBTree_Is_lesser( compare_result ) ) ||
+              ( dir && _RBTree_Is_greater( compare_result ) ) ) {
           the_rbtree->first[dir] = the_node;
         break;
@@ -120,28 +118,11 @@ RBTree_Node *_RBTree_Insert_unprotected(
     /* verify red-black properties */
-    _RBTree_Validate_insert_unprotected(the_node);
+    _RBTree_Insert_validate( the_node );
   return (RBTree_Node*)0;
- *  _RBTree_Insert
- *  This kernel routine inserts a given node after a specified node
- *  a requested rbtree.
- *    tree - pointer to RBTree Control for tree to insert to
- *    node       - pointer to node to be inserted
- *    only case
   RBTree_Control *tree,
   RBTree_Node *node
1.7.1
