Add statistic to rtems_disk_device and bdbuf
Sebastian Huber
Thu May 24 13:54:24 UTC 2012
Hi Xiang,
thanks for your first proposal. I would call the statistics
rtems_bdbuf_stats
rtems_disk_stats
to keep the name a bit shorter.
On 05/23/2012 12:50 PM, Xiang Cui wrote:
> Hi
> I want to add new struct to the rtems_disk_device and bdbuf. All of
> them are counters for read/write and cache hit number. This is a very
> basic ideal now. These change will help to measure the IO performance
> and uncover the bdbuf state.
> All these statistics will be updated in bdbuf, I think.
> The changes in bdbuf.h and diskdevs.h may like this.
> diff --git a/cpukit/libblock/include/rtems/bdbuf.h
> b/cpukit/libblock/include/rtems/bdbuf.h
> index 134a0ce..25ad374 100644
> --- a/cpukit/libblock/include/rtems/bdbuf.h
> +++ b/cpukit/libblock/include/rtems/bdbuf.h
> @@ -292,6 +292,18 @@ typedef enum
> } rtems_bdbuf_buf_state;
> +* @brief Statistic for bdbuf.
> +typedef struct {
> + unsigned swapout_execute_count; /**< counter for swapout execute */
> + unsigned recycle_count; /**< counter for the recycle */
> + unsigned total_write_count; /**< counter for the total write action */
> + unsigned total_read_count; /**< counter for the total read action */
> + unsigned total_write_hit; /**< counter for the total write hit */
How can a write miss occur?
> + unsigned total_read_hit; /**< counter for the total read hit */
> +} rtems_bdbuf_statistic;
Please use uint32_t or similar instead of unsigned to get at least 32-bits.
> * Forward reference to the block.
> struct rtems_bdbuf_group;
> @@ -644,6 +656,14 @@ rtems_bdbuf_purge_dev (const rtems_disk_device *dd);
> rtems_status_code
> rtems_bdbuf_set_block_size (rtems_disk_device *dd, uint32_t block_size);
> +* @brief Return the statistic for bdbuf.
> +* @return pointer to rtems_bdbuf_statistic.
> +const rtems_bdbuf_statistic *rtems_bdbuf_get_statistic(void);
This is problematic since the statistics change with time. Better is to return
a snapshot
void rtems_bdbuf_get_statistic(rtems_bdbuf_stats *stats);
with a proper cache lock/unlock inside.
> #ifdef __cplusplus
> diff --git a/cpukit/libblock/include/rtems/diskdevs.h
> b/cpukit/libblock/include/rtems/diskdevs.h
> index 2e3f753..e969894 100644
> --- a/cpukit/libblock/include/rtems/diskdevs.h
> +++ b/cpukit/libblock/include/rtems/diskdevs.h
> @@ -55,6 +55,30 @@ typedef int (*rtems_block_device_ioctl)(
> + * @brief Statistic to count the write and read number for bdbuf.
> + * These statistics counted by block size.
> +typedef struct {
> + * @brief counter for write number since the disk device was created
> + unsigned write_count;
> + * @brief counter for read number since the disk device was created
> + unsigned read_count;
> + * @brief counter for write hit in bdbuf
> + unsigned write_hit;
> + * @brief counter for read hit in bdbuf
> + unsigned read_hit;
> +} rtems_disk_device_statistic;
> * @brief Description of a disk device (logical and physical disks).
> * An array of pointer tables to rtems_disk_device structures is maintained.
> @@ -153,6 +177,13 @@ struct rtems_disk_device {
> * releases this disk.
> bool deleted;
> + * @brief statistic for disk device. The logical disks have the same
> + * pointer to these physical disk.
> + rtems_disk_device_statistic *statistic;
Why should physical and logical disk share the statistics? The physical and
logical disks are from the cache point of view separate entities.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
