[PATCH] Configuration documentation changes throughout
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Apr 10 14:05:02 UTC 2013
On 4/10/2013 8:33 AM, Gedare Bloom wrote:
> Looks good. Later we might want to specify actual ranges with valid
> min and max or set notation of possible values.
Agreed.
It looks like Sebastian addressed most, if not all, of what was on my
review list.
I am sure there are still improvements to be made but this should
be committed.
--joel
> On Apr 10, 2013 8:44 AM, "Sebastian Huber"
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> doc/user/conf.t | 366
> 1 files changed, 166 insertions(+), 200 deletions(-)
> diff --git a/doc/user/conf.t b/doc/user/conf.t
> index a1aabd4..1e52dcf 100644
> --- a/doc/user/conf.t
> +++ b/doc/user/conf.t
> @@ -71,7 +71,7 @@ expect that all systems can be easily configured
> using the
> avoid internal RTEMS configuration changes impacting applications.
> @c
> - at c === Philospohy ===
> + at c === Philosophy ===
> @c
> @section Default Value Selection Philosophy
> @@ -95,19 +95,16 @@ from the RTEMS Workspace.
> The @code{<rtems/confdefs.h>} mechanism calculates the size of
> the RTEMS
> Workspace automatically. It assumes that all tasks are floating
> point and
> -that all will be allocated the mininum stack space. This calculation
> +that all will be allocated the minimum stack space. This calculation
> includes the amount of memory that will be allocated for internal use
> by RTEMS. The automatic calculation may underestimate the workspace
> size truly needed by the application, in which case one can use the
> @code{CONFIGURE_MEMORY_OVERHEAD} macro to add a value to the
> estimate. See
> @ref{Configuring a System Specify Memory Overhead} for more details.
> - at c XXX - ************* REMOVE ME *************
> - at c The starting address of the RTEMS Workspace is determined
> - at c by the BSP and must be aligned on at least a four-byte boundary.
> - at c Failure to properly align the workspace will result in the
> - at c @code{@value{DIRPREFIX}fatal_error_occurred} directive being
> invoked
> - at c with the @code{@value{RPREFIX}INVALID_ADDRESS} error code.
> +The memory area for the RTEMS Workspace is determined by the BSP.
> In case the
> +RTEMS Workspace is too large for the available memory, then a
> fatal run-time
> +error occurs and the system terminates.
> The file @code{<rtems/confdefs.h>} will calculate the value of the
> @code{work_space_size} parameter of the Configuration Table. There
> @@ -147,9 +144,8 @@ automatic estimates of space required will in
> general change when:
> @item the target processor is changed.
> @end itemize
> -Failure to provide enough space in the RTEMS Workspace will result in
> -the @code{@value{DIRPREFIX}fatal_error_occurred} directive being
> invoked
> -with the appropriate error code.
> +Failure to provide enough space in the RTEMS Workspace may result
> in fatal
> +run-time errors terminating the system.
> @c
> @c === Potential Issues ===
> @@ -211,7 +207,7 @@ fifty (50) milliseconds is as follows:
> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 1
> #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
> - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 10, sizeof(struct
> USER_MESSAGE))
> + CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(20, sizeof(struct
> USER_MESSAGE))
> #define CONFIGURE_INIT
> #include <rtems/confdefs.h>
> @@ -279,7 +275,8 @@ other things, the application implicitly used
> the following defaults:
> @item All unspecified types of communications and synchronization
> objects
> in the Classic and POSIX Threads API have maximums of zero (0).
> - at item The filesystem will be the default filesystem which only
> supports device nodes.
> + at item The filesystem will be the default filesystem which is the
> In-Memory File
> +System (IMFS).
> @item The application will have the default number of priority
> levels.
> @@ -426,10 +423,10 @@ pool of memory for both RTEMS and
> application memory allocations.
> @code{CONFIGURE_OBJECTS_ALLOCATION_SIZE}
> @item DATA TYPE:
> -integer
> +Unsigned integer (@code{uint32_t}).
> @item RANGE:
> -undefined or positive
> +Positive.
> @item DEFAULT VALUE:
> If not defined and @code{CONFIGURE_OBJECTS_UNLIMITED} is defined, the
> @@ -474,10 +471,10 @@ parameters supported by
> @code{<rtems/confdefs.h>}.
> @code{CONFIGURE_MAXIMUM_TASKS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> The default for this field is 0.
> @@ -491,7 +488,7 @@ Tasks that can be concurrently active.
> @subheading NOTES:
> This object class can be configured in unlimited allocation mode.
> -This calculations for the required memory in the RTEMS Workspace
> +The calculations for the required memory in the RTEMS Workspace
> for tasks assume that each task has a minimum stack size and
> has floating point support enabled. The configuration parameter
> @code{CONFIGURE_EXTRA_TASK_STACKS} is used to specify task stack
> @@ -553,10 +550,10 @@ and this can save significant memory in a
> low RAM system.
> @code{CONFIGURE_MAXIMUM_TIMERS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -582,10 +579,10 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_SEMAPHORES}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -611,10 +608,10 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_MESSAGE_QUEUES}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -640,10 +637,10 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_BARRIERS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -669,10 +666,10 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_PERIODS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -698,10 +695,10 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_PARTITIONS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -727,10 +724,10 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_REGIONS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -756,10 +753,10 @@ None.
> @code{CONFIGURE_MAXIMUM_PORTS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -785,10 +782,10 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_USER_EXTENSIONS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -863,10 +860,10 @@ any initialization tasks or threads.
> @code{CONFIGURE_INIT_TASK_ENTRY_POINT}
> @item DATA TYPE:
> -rtems_task_entry
> +Task entry function pointer (@code{rtems_task_entry}).
> @item RANGE:
> -valid method pointer
> +Valid task entry function pointer.
> By default the value is @code{Init}.
> @@ -879,7 +876,7 @@ name) of the single initialization task
> defined by the Classic API
> Initialization Tasks Table.
> @subheading NOTES:
> -The user must implement the method @code{Init} or the method name
> provided
> +The user must implement the function @code{Init} or the function
> name provided
> in this configuration parameter.
> @c
> @@ -894,10 +891,10 @@ in this configuration parameter.
> @code{CONFIGURE_INIT_TASK_NAME}
> @item DATA TYPE:
> -rtems_name
> +RTEMS Name (@code{rtems_name}).
> @item RANGE:
> -any value
> +Any value.
> By default the value is @code{rtems_build_name( 'U', 'I', '1', '
> @@ -923,10 +920,10 @@ None.
> @code{CONFIGURE_INIT_TASK_STACK_SIZE}
> @item DATA TYPE:
> -integer
> +Unsigned integer (@code{size_t}).
> @item RANGE:
> -zero or positive
> +Zero or positive.
> By default value is the configured minimum stack size.
> @@ -955,10 +952,10 @@ for more information about
> @code{CONFIGURE_EXTRA_TASK_STACKS}.
> @code{CONFIGURE_INIT_TASK_PRIORITY}
> @item DATA TYPE:
> -rtems_task_priority
> +RTEMS Task Priority (@code{rtems_task_priority}).
> @item RANGE:
> -1 to CONFIGURE_MAXIMUM_PRIORITY
> +One (1) to CONFIGURE_MAXIMUM_PRIORITY.
> By default the value is one (1) which is the highest priority in the
> @@ -986,10 +983,10 @@ None.
> @item DATA TYPE:
> -rtems_attributes
> +RTEMS Attributes (@code{rtems_attribute}).
> @item RANGE:
> -valid task attribute sets
> +Valid task attribute sets.
> By default the tvalue is @code{RTEMS_DEFAULT_ATTRIBUTES}.
> @@ -1015,10 +1012,10 @@ None.
> @code{CONFIGURE_INIT_TASK_INITIAL_MODES}
> @item DATA TYPE:
> -rtems_mode
> +RTEMS Mode (@code{rtems_mode}).
> @item RANGE:
> -valid task mode sets
> +Valid task mode sets.
> By default the value is @code{RTEMS_NO_PREEMPT}.
> @@ -1045,10 +1042,10 @@ None.
> @code{CONFIGURE_INIT_TASK_ARGUMENTS}
> @item DATA TYPE:
> -rtems_task_argument
> +RTEMS Task Argument (@code{rtems_task_argument}).
> @item RANGE:
> -valid rtems_task_argument values
> +Complete range of the type.
> By default the value is 0.
> @@ -1114,10 +1111,10 @@ is enabled at configure time using the
> @code{--enable-posix} option.
> @code{CONFIGURE_MAXIMUM_POSIX_THREADS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -1158,10 +1155,10 @@ All POSIX threads have floating point enabled.
> @code{CONFIGURE_MAXIMUM_POSIX_MUTEXES}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -1187,10 +1184,10 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -1216,10 +1213,10 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_POSIX_KEYS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -1247,10 +1244,10 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_POSIX_TIMERS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -1276,10 +1273,10 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -1305,10 +1302,10 @@ None.
> @code{CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -1336,7 +1333,7 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> greater than or equal to
> @code{CONFIGURE_MAXIMUM_POSIX_MESSAGES_QUEUES}
> @@ -1369,10 +1366,10 @@ greater than or equal to
> @code{CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES}.
> @code{CONFIGURE_MAXIMUM_POSIX_SEMAPHORES}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -1398,10 +1395,10 @@ None.
> @code{CONFIGURE_MAXIMUM_POSIX_BARRIERS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -1427,10 +1424,10 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_POSIX_SPINLOCKS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -1456,10 +1453,10 @@ This object class can be configured in
> @code{CONFIGURE_MAXIMUM_POSIX_RWLOCKS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> @@ -1536,10 +1533,10 @@ any initialization tasks or threads.
> @code{CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT}
> @item DATA TYPE:
> -void *(*entry_point)(void *)
> +POSIX thread function pointer (@code{void *(*entry_point)(void *)}).
> @item RANGE:
> +Undefined or a valid POSIX thread function pointer.
> By default the value is @code{POSIX_Init}.
> @@ -1552,7 +1549,7 @@ By default the value is @code{POSIX_Init}.
> the POSIX API Initialization Threads Table.
> @subheading NOTES:
> -The user must implement the method @code{POSIX_Init} or the
> method name
> +The user must implement the function @code{POSIX_Init} or the
> function name
> provided in this configuration parameter.
> @c
> @@ -1567,10 +1564,10 @@ provided in this configuration parameter.
> @code{CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> By default value is twice the configured minimum stack size.
> @@ -1685,10 +1682,10 @@ run out of RTEMS Workspace.
> @code{CONFIGURE_MICROSECONDS_PER_TICK}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -non-zero positive values
> +Positive.
> When not defined, the clock tick quantum is configured to be 10,000
> @@ -1735,10 +1732,10 @@ a clock tick quantum.
> @item DATA TYPE:
> -integer
> @item RANGE:
> +Positive.
> If unspecified, this parameter defaults to fifty (50).
> @@ -1767,7 +1764,7 @@ driver is not configured.
> @code{CONFIGURE_MAXIMUM_PRIORITY}
> @item DATA TYPE:
> -integer
> +Unsigned integer (@code{uint8_t}).
> @item RANGE:
> Valid values for this configuration parameter must be one (1)
> less than
> @@ -1815,10 +1812,10 @@ to sixteen (16) can reduce memory usage by
> about three (3) kilobytes.
> @code{CONFIGURE_MINIMUM_TASK_STACK_SIZE}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -non-zero positive integer
> +Positive.
> When not defined by the application, this is set to the recommended
> @@ -1856,10 +1853,10 @@ risk of stack overflow without performing
> analysis on actual consumption.
> @code{CONFIGURE_INTERRUPT_STACK_SIZE}
> @item DATA TYPE:
> -integer
> @item RANGE:
> +Positive.
> If not specified, the interrupt stack will be of minimum size.
> @@ -1895,10 +1892,10 @@ from the RTEMS Workspace would be welcomed
> by the RTEMS Project.
> @item DATA TYPE:
> -integer
> @item RANGE:
> -Undefined or positive
> +Undefined or positive.
> When this is not defined, the default value is 0.
> @@ -1997,7 +1994,7 @@ overhead to each context switch.
> @code{CONFIGURE_INITIAL_EXTENSIONS}
> @item DATA TYPE:
> -List of @code{rtems_extensions_table} entries
> +List of user extension initializers (@code{rtems_extensions_table}).
> @item RANGE:
> Undefined or a list of one or more user extensions.
> @@ -2037,10 +2034,10 @@ so that stack overflows are detected in
> hardware.
> @code{CONFIGURE_TASK_STACK_ALLOCATOR_INIT}
> @item DATA TYPE:
> -method pointer
> +Function pointer.
> @item RANGE:
> -NULL or valid pointer to a method
> +Undefined, NULL or valid function pointer.
> The default value for this field is NULL which indicates that
> @@ -2076,14 +2073,14 @@ A correctly configured system must
> configure the following to be consistent:
> @code{CONFIGURE_TASK_STACK_ALLOCATOR}
> @item DATA TYPE:
> -method pointer
> +Function pointer.
> @item RANGE:
> -NULL or valid method pointer
> +Undefined or valid function pointer.
> -The default value for this field is NULL which indicates that
> -task stacks will be allocated from the RTEMS Workspace.
> +The default value for this field is @code{_Workspace_Allocate}
> which indicates
> +that task stacks will be allocated from the RTEMS Workspace.
> @end table
> @@ -2113,13 +2110,13 @@ A correctly configured system must
> @code{CONFIGURE_TASK_STACK_DEALLOCATOR}
> @item DATA TYPE:
> -method pointer
> +Function pointer.
> @item RANGE:
> -undefined or valid pointer
> +The default value for this field is @code{_Workspace_Free} which
> indicates that
> @end table
> @@ -2155,16 +2152,16 @@ the amount of memory reserved for Classic
> API Message Buffers.
> @table @b
> @item CONSTANT:
> - at code{CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE}
> + at code{CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(max_messages, size_per)}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Positive.
> -This macro is only used as input to
> +None.
> @end table
> @@ -2257,10 +2254,10 @@ and providing work-arounds when the memory
> estimated by
> @item DATA TYPE:
> -undefined or integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> The default value is 0.
> @@ -2307,36 +2304,6 @@ is providing their own complete set of
> configuration tables.
> None.
> @c
> - at c === CONFIGURE_EXECUTIVE_RAM_WORK_AREA ===
> - at c
> - at subsection Specify Location of RTEMS Workspace
> - at findex CONFIGURE_EXECUTIVE_RAM_WORK_AREA
> - at table @b
> - at item CONSTANT:
> - at code{CONFIGURE_EXECUTIVE_RAM_WORK_AREA}
> - at item DATA TYPE:
> -pointer
> - at item RANGE:
> - at item DEFAULT VALUE:
> -By default, this value is not defined indicating that the BSP is
> to determine
> -the location of the RTEMS Workspace.
> - at end table
> - at subheading DESCRIPTION:
> -This configuration parameter is the base address of the RTEMS
> Workspace.
> - at subheading NOTES:
> -The BSP is responsible for setting this address. It is highly
> unlikely
> -that an application could do this portably and reliably.
> - at c
> @c === C Library Support Configuration ===
> @c
> @section C Library Support Configuration
> @@ -2389,10 +2356,10 @@ None.
> @code{CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -Zero or positive
> +Zero or positive.
> If not defined, the default value is either zero (0) or three if
> @@ -2403,15 +2370,11 @@ I/O streams on @code{/dev/console}.
> @end table
> @subheading DESCRIPTION:
> -This configuration parameter is set to the maximum number of
> files that
> -can be concurrently open.
> +This configuration parameter is set to the maximum number of file
> like objects
> +that can be concurrently open.
> @subheading NOTES:
> -In addition to the actual file descriptor data structures, the RTEMS
> -Libio Support library requires a Classic API semaphore for each file
> -descriptor as well as one to manage the set. Thus this configuration
> -parameter implicitly impacts the configured number of Classic API
> -semaphores configured for the application.
> +None.
> @c
> @c === CONFIGURE_TERMIOS_DISABLED ===
> @@ -2457,13 +2420,13 @@ device driver.
> @code{CONFIGURE_NUMBER_OF_TERMIOS_PORTS}
> @item DATA TYPE:
> -integer
> +Unsigned integer.
> @item RANGE:
> -zero or positive integer
> +Zero or positive.
> -By default, this is set to 1 so a console port can be used.
> +By default, this is set to one (1) so a console port can be used.
> @end table
> @@ -2539,7 +2502,6 @@ Boolean feature macro.
> Defined or undefined.
> This value is not defined by default. If no other root file system
> configuration parameters are specified, the IMFS will be used as the
> root file system.
> @@ -2600,6 +2562,7 @@ space provided before RTEMS release 4.5.0.
> @table @b
> @item CONSTANT:
> + at code{CONFIGURE_APPLICATION_DISABLE_FILESYSTEM}
> @item DATA TYPE:
> @@ -2615,13 +2578,13 @@ root file system.
> @end table
> - at code{CONFIGURE_APPLICATION_DISABLE_FILESYSTEM}
> This configuration parameter is defined if the application dose not
> intend to use any kind of filesystem support. This include the device
> infrastructure necessary to support @code{printf()}.
> + at subheading NOTES:
> +None.
> @c
> @c === BSP Specific Settings ===
> @c
> @@ -2678,7 +2641,7 @@ Boolean feature macro.
> -This configuration is undefined by default.
> +This option is BSP specific.
> @end table
> @@ -2706,13 +2669,13 @@ knows how it allocates memory to the C
> Program Heap.
> @code{BSP_IDLE_TASK_BODY}
> @item DATA TYPE:
> -Pointer to method.
> +Function pointer.
> @item RANGE:
> -Null or pointer to method.
> -This is not defined by default.
> @end table
> @@ -2738,13 +2701,13 @@ components off to save power during
> extended periods of no task activity
> @code{BSP_IDLE_TASK_STACK_SIZE}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -undefined or positive integer
> @end table
> @@ -2779,13 +2742,13 @@ The order of precedence for configuring
> the IDLE task stack size is:
> @code{BSP_INITIAL_EXTENSION}
> @item DATA TYPE:
> @item RANGE:
> -Undefined or a list of one or more user extensions.
> +Undefined or a list of user extension initializers.
> -This value is not defined by default.
> @end table
> @@ -2809,10 +2772,13 @@ None.
> @code{BSP_INTERRUPT_STACK_SIZE}
> @item DATA TYPE:
> @item RANGE:
> @end table
> @@ -2836,26 +2802,25 @@ None.
> @code{BSP_MAXIMUM_DEVICES}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> -By default, this is not defined.
> @end table
> If @code{BSP_MAXIMUM_DEVICES} is defined by the BSP and
> @code{CONFIGURE_MAXIMUM_DEVICES} is not defined by the application,
> -then this BSP specific maximum device count will be used. This
> option
> -is specific to the device file system (devFS) and should not be
> confused
> -with the @code{CONFIGURE_MAXIMUM_DRIVERS} option.
> +then this BSP specific maximum device count will be used.
> @subheading NOTES:
> -This parameter only impacts the devFS and thus
> -is only used by @code{<rtems/confdefs.h>} when
> +This option is specific to the device file system (devFS) and
> should not be
> +confused with the @code{CONFIGURE_MAXIMUM_DRIVERS} option. This
> parameter only
> +impacts the devFS and thus is only used by
> @code{CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM} is specified.
> @c
> @@ -2876,7 +2841,7 @@ Boolean feature macro.
> @end table
> @@ -2901,13 +2866,13 @@ necessary for RTEMS but is often assumed
> by support libraries.
> @code{CONFIGURE_BSP_PREREQUISITE_DRIVERS}
> @item DATA TYPE:
> -array of device drivers
> +List of device driver initializers
> (@code{rtems_driver_address_table}).
> @item RANGE:
> -Undefined or array of device drivers
> +Undefined or array of device drivers.
> @end table
> @@ -2944,10 +2909,10 @@ supported by @code{<rtems/confdefs.h>}.
> @code{CONFIGURE_IDLE_TASK_BODY}
> @item DATA TYPE:
> -method pointer.
> +Function pointer.
> @item RANGE:
> -Undefined or method pointer.
> @@ -2955,7 +2920,7 @@ By default, this is not defined.
> @end table
> - at code{CONFIGURE_IDLE_TASK_BODY} is set to the method name
> corresponding
> + at code{CONFIGURE_IDLE_TASK_BODY} is set to the function name
> corresponding
> to the application specific IDLE thread body. If not specified, the
> BSP or RTEMS default IDLE thread body will be used.
> @@ -2974,10 +2939,10 @@ None.
> @code{CONFIGURE_IDLE_TASK_STACK_SIZE}
> @item DATA TYPE:
> -integer
> @item RANGE:
> If not specified, the IDLE task will have a stack of the configured
> @@ -3380,7 +3345,7 @@ Note that network device drivers are not
> configured in the Device Driver Table.
> @code{CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE}
> @item DATA TYPE:
> -Array of device drivers.
> @item RANGE:
> @@ -3413,10 +3378,10 @@ It is expected that there the application
> would only rarely need to do this.
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> By default, this is set to the number of device drivers configured
> @@ -3448,10 +3413,10 @@ are statically installed.
> @item DATA TYPE:
> -integer
> @item RANGE:
> -undefined or positive integer.
> +Positive.
> Unless @code{BSP_MAXIMUM_DEVICES} is set by the BSP, the default
> value
> @@ -3462,11 +3427,12 @@ value specified by the BSP.
> @code{CONFIGURE_MAXIMUM_DEVICES} is defined to the number of
> -individual devices that may be registered in the system.
> +individual devices that may be registered in the device file
> system (devFS).
> @subheading NOTES:
> should not be
> parameter only
> @c
> @@ -3478,7 +3444,7 @@ is only used by @code{<rtems/confdefs.h>} when
> @table @b
> @item CONSTANT:
> - at item @code{CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER}
> + at code{CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER}
> @item DATA TYPE:
> @@ -3919,10 +3885,10 @@ This has no impact unless RTEMS was
> configured and built using the
> @code{CONFIGURE_MP_NODE_NUMBER}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -positive integer
> +Positive.
> If not defined, it is set to @code{NODE_NUMBER} which is assumed
> to be
> @@ -3953,10 +3919,10 @@ differently based upon their node number.
> @code{CONFIGURE_MP_MAXIMUM_NODES}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -positive
> +Positive.
> The default is two (2).
> @@ -3982,10 +3948,10 @@ None.
> @code{CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> -positive
> +Positive.
> The default is 32.
> @@ -4012,10 +3978,10 @@ created with the @code{RTEMS_GLOBAL}
> attribute.
> @code{CONFIGURE_MP_MAXIMUM_PROXIES}
> @item DATA TYPE:
> -integer
> @item RANGE:
> The default is 32.
> @@ -4159,10 +4125,10 @@ run-time.
> @code{CONFIGURE_MAXIMUM_ADA_TASKS}
> @item DATA TYPE:
> -integer
> @item RANGE:
> By default, when @code{CONFIGURE_GNAT_RTEMS} is defined, this is
> set to 20.
> @@ -4188,10 +4154,10 @@ None.
> @findex CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
> @item DATA TYPE:
> -integer
> @item RANGE:
> -zero or positive
> +Zero or positive.
> By default, this is undefined which implies zero (0) @i{fake} Ada
> Tasks.
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130410/5761d501/attachment-0001.html>
