[PROJECTS] RTEMS project on ARM or kernel related.
Thu Feb 14 19:33:43 UTC 2013
On Thu, Feb 14, 2013 at 12:57 PM, Ritesh Harjani
<ritesh.harjani at gmail.com> wrote:
> Hi all,
> I have been working on ARM Multicore architecture from around 6-7
> months(still a newbie) and will be willing to contribute for ARM SMP support
> on RTEMS.
> Here is what I need help in:
> 1. I have raspberry pi + TI launchpad LM4F120 launchpad which uses ARM
> cortex M4 based architecture.
> here is the config for raspberry pi:
> http://en.wikipedia.org/wiki/Raspberry_Pi
> Can this SoC be useful for porting RTEMS onto that?
This is a good board, and Alan pointed out he has some basic support.
This board would not support SMP though.
> 2. Anyway the main question here is,
> I have time, interest  & resources. What I need is some support + guidance
> from you guys to start off this project.
> Can anyone of you please guide me as how should I start off this in more
> detail (but be focused on the topic: SMP support for ARM). Also any link
> rtems IRC server (I tried #rtems, but not much of help I got)
There was a GSOC project by Xi Yang last year that did an initial SMP
support for ARM. That code should be merged soon we hope. From there,
lots of projects are possible w.r.t. SMP. it depends what level you
want to work in: add support for more ARM CPUs to use SMP, improve SMP
capabiltiies like Atomic operations for ARM or implement an SMP
scheduler, and so on. The first thing to try to do I suppose is to
attempt to replicate Xi's work if possible.
The IRC channel is on the freenode irc server, then go to #rtems channel.
> 3. If the 2nd option is not the requirement of the community, is there any
> work on Memory management or anything to kernel related?
> I will be happy to take some project and start contributing.
I'm working to get a memory management framework in place. It is
rudimentary, but last year's GSOC we had a student who got the initial
framework to work on the PSIM simulator for PowerPC and Skyeye
simulator with Gumstix BSP. There will be plenty to do with this
framework, including to add more BSPs, generalize shared support for
CPUs, and work on improving the internal memory management interfaces.
-Gedare
> Thanks and Regards
> Ritesh
> rtems-devel mailing list
> rtems-devel at rtems.org
