RTEMS Build System (used to be: globaledf)
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Jun 24 13:27:39 UTC 2013
Thanks Cynthia for covering that. I was on my phone and
getting much typed correctly was painful. Autocorrect and
code just don't go together. :)
One time saving addition to this.. you can run bootstrap from
any directory with a configure.ac. It will then do everything
from that point down. For you, this would mean only
bootstrapping cpukit. This will be a lot faster.
--joel
On 6/22/2013 1:44 PM, Rempel, Cynthia wrote:
> Hi,
> When adding files to the RTEMS build system you need to make changes to the following files:
> 1. configure.ac (this could be cpukit/configure.ac or another configure.ac depending on where you added the header)
> 2. Makefile.am (again this could be cpukit/Makefile.am or another Makefile.am depending on where you added the header)
> Then as Joel said run
> ./bootstrap -c && ./bootstrap -p && ./bootstrap
> ./bootstrap cleans the Makefile.in s
> ./bootstrap -p regenerates the preinstall.am s
> ./bootstrap generates the Makefile.in s
> This seems to work well... configuring with --enable-maintainer-mode may also be helpful...
> Hope this helps!
> Cindy
> ________________________________________
> From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] on behalf of Ralf Corsepius [ralf.corsepius at rtems.org]
> Sent: Friday, June 21, 2013 1:33 PM
> To: rtems-devel at rtems.org
> Subject: Re: globaledf
> On 06/21/2013 09:38 PM, Joel Sherrill wrote:
>> You have added a .h file. You need to run bootstrap -p and bootstrap in cpukit.
> Wrong - This does not apply, when having configure the source tree in
> maintainer-mode.
> Once having configured the build-tree it will regenerate and update the
> Makefile.in.
> Bootstrap is only necessary once after a fresh git checkout!
> It would not be necessary if RTEMS carried the auto-tool generated files
> in git - but I guess hell will freeze, before some people around here
> will comprehend this.
> Ralf
> rtems-devel mailing list
