[PATCH] Enable iconv code tables
Mon May 13 02:37:45 UTC 2013
Ralf Kirchner wrote:
> UTF8 support will get implemented backwards compatible and will
> have to get activated with a mount parameter explicitly.
> As long as you mount the FAT file system as you always
> used to, nothing will change and the encodings will not get linked in.
This does not make sense to me. Mounting and mount arguments are runtime
so this means the code would have to be linked in for the option to
work. Disabling at runtime would not remove the code.
