Error with examples-v2
Joel Sherrill
Joel.Sherrill at OARcorp.com
Thu Apr 24 23:28:11 UTC 2014
If you don't do the make install step then neither will work.
On Apr 24, 2014 6:05 PM, Gedare Bloom <gedare at rtems.org> wrote:
You may be interested to read the README.waf and try to use that to build the examples instead of Make.
On Thu, Apr 24, 2014 at 5:20 PM, Federico Lenarduzzi <federico.lenarduzzi at tallertechnologies.com<mailto:federico.lenarduzzi at tallertechnologies.com>> wrote:
I already set RTEMS_MAKEFILE_PATH variable as you mentioned. Are you following the same tutorial? These steps are OK ?
Thanks for help me.
2014-04-24 18:05 GMT-03:00 Joel Sherrill <joel.sherrill at oarcorp.com<mailto:joel.sherrill at oarcorp.com>>:
On 4/24/2014 3:55 PM, Federico Lenarduzzi wrote:
Hi everybody, I'm trying compile the examples following this steps:
http://www.rtems.org/wiki/index.php/Example_Application_Compiling
If you did a "make install" on the build tree, then this is all that would be required.
export RTEMS_MAKEFILE_PATH=/home/admin/rtems/arm-rtems4.11/lpc1768
make
I probed for lpc1768 and lm3s6965 but with both configurations didn't work. Exist files which aren't generated.
admin at laptop ~/examples-v2 $ make
/home/admin/rtems/make/custom/lm3s69xx.inc:5: /home/admin/rtems/make/custom/default.cfg: No such file or directory
make: *** No rule to make target `/home/adm1/rtems/make/custom/default.cfg'. Stop.
Note: I use --prefix:/home/admin/rtems as installation point.
An alternative: "hardcode". In other words, paste the files missing into appropriate folders. After that, the errors disappeared. However, when I compile the hello world example, throws a new error.
admin at laptop ~/examples-v2/hello/hello_world_c $ make
make: *** No rule to make target `/test.o', needed by `/hello.exe'. Stop.
Any suggestion? Someone have or had problems with examples?
[http://www.tallertechnologies.com/templates/tallertechnologies/images/signature.png]<http://www.tallertechnologies.com>
Federico Lenarduzzi
Software Engineer
Taller Technologies Argentina
San Lorenzo 47, 3rd Floor, Office 5
Cordoba, Argentina
Phone: +54 351 4220701<tel:351%204220701>
Mobile: +54 358 4289083<tel:%2B54%20358%204289083>
Skype: federico.lenarduzzi1
[https://cdn1.iconfinder.com/data/icons/yooicons_set01_socialbookmarks/32/social_facebook_box_blue.png]<https://www.facebook.com/tallertechnologies> [https://cdn1.iconfinder.com/data/icons/yooicons_set01_socialbookmarks/32/social_linkedin_box_blue.png] <http://www.linkedin.com/company/taller-technologies>
joel.sherrill at OARcorp.com<mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
Support Available (256) 722-9985<tel:%28256%29%20722-9985>
Federico Lenarduzzi
Software Engineer
Cordoba, Argentina
Phone: +54 351 4220701<tel:%2B54%20351%204220701>
rtems-devel mailing list
rtems-devel at rtems.org<mailto:rtems-devel at rtems.org>
http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140424/4fa8cd8b/attachment-0001.html>
