Error with examples-v2
Fri Apr 25 00:54:31 UTC 2014
On Thu, Apr 24, 2014 at 7:28 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
>  If you don't do the make install step then neither will work.
Good point, and those wiki instructions don't explicitly say "make install".
> On Apr 24, 2014 6:05 PM, Gedare Bloom <gedare at rtems.org> wrote:
>  You may be interested to read the README.waf and try to use that to
> build the examples instead of Make.
> On Thu, Apr 24, 2014 at 5:20 PM, Federico Lenarduzzi <
> federico.lenarduzzi at tallertechnologies.com> wrote:
>> I already set RTEMS_MAKEFILE_PATH variable as you mentioned. Are you
>> following the same tutorial? These steps are OK ?
>> Thanks for help me.
>> 2014-04-24 18:05 GMT-03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>   On 4/24/2014 3:55 PM, Federico Lenarduzzi wrote:
>>>  Hi everybody, I'm trying compile the examples following this steps:
>>>  http://www.rtems.org/wiki/index.php/Example_Application_Compiling
>>>  If you did a "make install" on the build tree, then this is all that
>>> would be required.
>>> export RTEMS_MAKEFILE_PATH=/home/admin/rtems/arm-rtems4.11/lpc1768
>>> make
>>>  I probed for lpc1768 and lm3s6965 but with both configurations didn't
>>> work. Exist files which aren't generated.
>>>  *admin at laptop ~/examples-v2 $* make
>>> /home/admin/rtems/make/custom/lm3s69xx.inc:5:
>>> /home/admin/rtems/make/custom/default.cfg: No such file or directory
>>> make: *** No rule to make target
>>> `/home/adm1/rtems/make/custom/default.cfg'.  Stop.
>>> Note: I use --prefix:/home/admin/rtems as installation point.
>>> An alternative: "hardcode". In other words, paste the files missing into
>>> appropriate folders. After that, the errors disappeared. However, when I
>>> compile the hello world example, throws a new error.
>>>   *admin at laptop ~/examples-v2/hello/hello_world_c $* make
>>> make: *** No rule to make target `/test.o', needed by `/hello.exe'.
>>>  Stop.
>>>  Any suggestion? Someone have or had problems with examples?
>>>  <http://www.tallertechnologies.com>
>>>  *Federico Lenarduzzi*
>>> Software Engineer
>>>  Taller Technologies Argentina
>>> San Lorenzo 47, 3rd Floor, Office 5
>>> Cordoba, Argentina
>>> Phone: +54 351 4220701
>>> Mobile: +54 358 4289083
>>> Skype: federico.lenarduzzi1
>>>   <https://www.facebook.com/tallertechnologies> <http://www.linkedin.com/company/taller-technologies>
>>> Joel Sherrill, Ph.D.             Director of Research & Developmentjoel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
>> Software Engineer
>> Cordoba, Argentina
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140424/ce7f54d0/attachment-0001.html>
