Status of phycore_mpc5554 with latest RTEMS
Fri Feb 14 14:17:42 UTC 2014
Are you running the tests on the real hw or on a simulator?
The RPMs might not be using the suggested versions of the tools. There
is currently a disconnect between the RPM maintainer and RTEMS core
developers, and most of the developers are building their own tools
using the RSB [1]. I think the biggest issue there is that there may
be some difference in the version of newlib being used. You might try
to build a powerpc toolset with RSB and see if you get the same bad
result.
I think there have been some changes to the thread life-cycle due to
some need to rewrite thread dispatch critical sections for SMP, so
perhaps the task delete in sp02 does not get completed in time...
[1] http://wiki.rtems.org/wiki/index.php/RSB
-Gedare
On Fri, Feb 14, 2014 at 8:40 AM, Peter Dufault <dufault at hda.com> wrote:
> This is with GIT updated last night and the latest compiler tools downloaded from "yum", but not built.  Are those tools OK?  They just came down the other day:
> [dufault at flipper sptests]$ powerpc-rtems4.11-gcc --version
> powerpc-rtems4.11-gcc (GCC) 4.8.2 20131016 (RTEMS gcc-4.8.2-4.el6/newlib-1.20.0-30.el6)
> Copyright (C) 2013 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions.  There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> Status of tests:
> samples/hello: OK
> sp01:
> optimization on: rtems_clock_set() or _get() not working, exits because task TA1 thinks 35 seconds have elapsed.
> Optimization off: Works properly.
> sp02:
> Optimization off:
> -- Default number of classic tasks (4): Exits trying to start task 3.  I assume because the first task deleted itself it should work OK.  I assume the Init task and the Idle task don't count against the maximum number of tasks or this would never work.
> *** TEST 2 ***
> INIT - rtems_task_wake_after - yielding processor
> PREEMPT - rtems_task_delete - deleting self
> rtems_task_create of TA3 FAILED -- expected (RTEMS_SUCCESSFUL) got (RTEMS_TOO_MANY)
> -- (Since I'm running out of time and to see what happens) Increase number of tasks to 6: Fails when _Thread_Start_multitasking() returns.
> I only have a little time each day to look at this so I'll look some more tomorrow.
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
> rtems-devel mailing list
> rtems-devel at rtems.org
