Nios2 RSB Build Failure
Chris Johns
chrisj at rtems.org
Sun Jun 1 09:07:50 UTC 2014
On 1/06/2014 12:47 am, Joel Sherrill wrote:
> Hi
> nios2-rtems4.11 fails like this on rtbf64a. I don't think this is host
> OS dependent.
> + cd newlib-1.19.0
> /home2/work/joel/rtems-4.11-work/rtems-source-builder/rtems/build/nios2-rtems4.11-gcc-4.1-newlib-1.19.0-1/doit:
> line 89: cd: newlib-1.19.0: No such file or directory
> shell cmd failed: /bin/sh -ex
> error: building nios2-rtems4.11-gcc-4.1-newlib-1.19.0-1
> See error report: rsb-report-nios2-rtems4.11-gcc-4.1-newlib-1.19.0-1.txt
> Build Set: Time 0:01:29.210503
I have pushed a fix that I hope fixes your build. I however cannot build
this package on my recent MacOS because the cc has errors. I need to
look into this.
I know on FreeBSD which is also on clang, the old binutils does not
build as a 32bit app so I think we need to move to the latest binutils.
I have a separate set up working this way and it seems fine.
