[PATCH 1/4] score: Add Resource Handler
    Gedare Bloom
    gedare at rtems.org
    Mon Jun  2 13:51:29 UTC 2014
On Mon, Jun 2, 2014 at 9:50 AM, Sebastian Huber
> On 2014-06-02 15:47, Gedare Bloom wrote:
>> On Mon, Jun 2, 2014 at 4:35 AM, Sebastian Huber
>>> >On 2014-05-28 23:48, Gedare Bloom wrote:
>>>>>> >>> >+ * @brief Returns true if this is the most recent resource of
>>>>>> >>> > the node,
>>>>>> >>> >and
>>>>>> >>> >+ * false otherwise.
>>>>>> >>> >+ * Resources are organized in last in first out order (LIFO).
>>>>>> >>> >+ * @param[in] node The node containing the resource.
>>>>>> >>> >+ * @param[in] resource The resource in question.
>>>>>> >>> >+RTEMS_INLINE_ROUTINE bool
>>>>>> >>> > _Resource_Is_most_recent_resource_of_node(
>>>>>> >>> >+  const Resource_Node    *node,
>>>>>> >>> >+  const Resource_Control *resource
>>>> >>At first this function name confused me when I saw it used. I'm not
>>>> >>sure if a better name exists but it may be worth considering. Also,
>>>> >>this whole Resource handler is a bit odd compared to other data
>>>> >>structures in RTEMS, in that the interface functions take a Node first
>>>> >>and a Control second. Usually the Control comes first.
>>> >The first parameter is usually the this object.  So for the
>>> >_Resource_Node_*() functions this is a node.  The term "recent" implies
>>> >temporal order and thus is well defined.  If we use "first", "last",
>>> > "top"
>>> >or whatever then we would have to explicitly specify the order which
>>> > makes
>>> >the name even longer.
>> OK. Is _Resource_Is_most_recently_used() ok? This has a clear parallel
>> with well-known language like LRU.
> What about _Resource_Is_most_recently_obtained()?
Yes, that is probably more clear.
-Gedare
