[PATCH] [RSB] Add support for building rtems-or1k tool-chain.
Chris Johns
chrisj at rtems.org
Mon May 26 00:36:48 UTC 2014
On 25/05/2014 10:12 am, Hesham ALMatary wrote:
> From: Hesham AL-Matary <heshamelmatary at gmail.com>
> Configuration files get the following releases:
> - binutils-2.24
> - newlib-2.1.0
> - gcc-4.8.2
> - gdb-7.7
> Patches are mix of OpenRISC original patches and other
> additions to build the previous releases for RTEMS.
Thanks. We are look forward to get this into the tool set.
> rtems/config/4.11/rtems-or1k.bset | 26 ++++++
> rtems/config/tools/rtems-binutils-2.24-or1k.cfg | 25 ++++++
> .../tools/rtems-gcc-4.8.2-newlib-2.1.0-or1k.cfg | 39 +++++++++
> rtems/config/tools/rtems-gdb-7.7-or1k.cfg | 28 +++++++
> source-builder/config/gdb-7-7-or1k.cfg | 95 ++++++++++++++++++++++
> 5 files changed, 213 insertions(+)
> create mode 100644 rtems/config/4.11/rtems-or1k.bset
> create mode 100644 rtems/config/tools/rtems-binutils-2.24-or1k.cfg
> create mode 100644 rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-or1k.cfg
> create mode 100644 rtems/config/tools/rtems-gdb-7.7-or1k.cfg
> create mode 100644 source-builder/config/gdb-7-7-or1k.cfg
> diff --git a/rtems/config/4.11/rtems-or1k.bset b/rtems/config/4.11/rtems-or1k.bset
> new file mode 100644
> index 0000000..dbc95e7
> --- /dev/null
> +++ b/rtems/config/4.11/rtems-or1k.bset
> @@ -0,0 +1,26 @@
> +# Tools Set for RTEMS or1k 4.11 Stable
> +%define release 1
> +%define rtems_arch or1k
> +# The RTEMS 4.11 BSP to build and test
> +%define rtems_bsps all
> +# The RTEMS 4.11 base defines.
> +%include rtems-4.11-base.bset
> +# Tools configuration.
> +4.11/rtems-autotools
> +devel/expat-2.1.0-1
> +tools/rtems-binutils-2.24-or1k
> +tools/rtems-gcc-4.8.2-newlib-2.1.0-or1k
> +tools/rtems-gdb-7.7-or1k
> diff --git a/rtems/config/tools/rtems-binutils-2.24-or1k.cfg b/rtems/config/tools/rtems-binutils-2.24-or1k.cfg
> index 0000000..d1e352a
> --- /dev/null
> +++ b/rtems/config/tools/rtems-binutils-2.24-or1k.cfg
> @@ -0,0 +1,25 @@
> +# Binutils 2.24.
> +%include %{_configdir}/checks.cfg
> +%include %{_configdir}/base.cfg
> +%define binutils_version 2.24
> +# Enable deterministic archives by default. This will be the default
> +# there all tools using this binutils will create deterministic
> +# archives.
> +%define with_deterministic_archives 1
> +# or1k patches
> +%patch add binutils -p1 https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/binutils-2.24-or1k-rtems.diff
If you move this to the bset file can you use rtems-binutils-2.24.cfg ?
Build set files support %source and %patch. This localises architecture
specific patches to that architecture.
> +# The binutils build instructions. We use 2.xx Release 1.
> +%include %{_configdir}/binutils-2-1.cfg
> diff --git a/rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-or1k.cfg b/rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-or1k.cfg
> index 0000000..be4b7cc
> --- /dev/null
> +++ b/rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-or1k.cfg
Same here ?
> @@ -0,0 +1,39 @@
> +# GCC 4.8.2., Newlib-2.1.0
> +%include %{_configdir}/versions.cfg
> +%define newlib_version 2.1.0
> +%define gcc_version 4.8.2
> +%define mpfr_version 3.0.1
> +%define mpc_version 0.8.2
> +%define gmp_version 5.0.5
> +%define with_threads 1
> +%define with_plugin 0
> +%ifn %{defined with_iconv}
> +%define with_iconv 1
> +%endif
> +# Chris's patch to use the POSIX thread model for C++.
> +%patch add gcc %{rtems_gcc_patches}/gcc-rtems-thread-model-posix-1.diff
> +# or1k patch for gcc-4.8.2
> +%patch add gcc -p1 https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gcc-4.8.2-or1k-rtems-29-4-2014.diff
> +# newlib-2.1.0 or1k patch
> +%patch add newlib -p1 https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/newlib-cvs-or1k-rtems-29-4-2014.diff
> +# The gcc/newlib build instructions. We use 4.8 Release 1.
> +%include %{_configdir}/gcc-4.8-1.cfg
> diff --git a/rtems/config/tools/rtems-gdb-7.7-or1k.cfg b/rtems/config/tools/rtems-gdb-7.7-or1k.cfg
> index 0000000..676e250
> --- /dev/null
> +++ b/rtems/config/tools/rtems-gdb-7.7-or1k.cfg
> @@ -0,0 +1,28 @@
> +# GDB 7.7.
> +%define gdb_version 7.7
> +# Clean up the sim-arange inline code so it builds.
> +%patch add gdb %{rtems_gdb_patches}/gdb-sim-arange-inline.diff
> +%patch add gdb %{rtems_gdb_patches}/gdb-sim-cgen-inline.diff
> +# or1k patch
> +%patch add gdb -p1 https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gdb-7.7-or1k-rtems.diff
> +%if %{_build_os} == freebsd
> + %patch add gdb -p0 %{rtems_gdb_patches}/patch-gdb-python-python-config.py
> +%endif
> +# The gdb build instructions. We use 7.xx Release 1.
> +%include %{_configdir}/gdb-7-7-or1k.cfg
> diff --git a/source-builder/config/gdb-7-7-or1k.cfg b/source-builder/config/gdb-7-7-or1k.cfg
> index 0000000..04d748f
> --- /dev/null
> +++ b/source-builder/config/gdb-7-7-or1k.cfg
Just looking at this file I cannot see what has changed ? Why do we need
a special gdb build script ?
> @@ -0,0 +1,95 @@
> +# GDB 7.xx Version 1.
> +# This configuration file configure's, make's and install's gdb.
> +# Select Snapshot Macro Maps
> +%select gdb-snapshot
> +%select expat-snapshot
> +# The description.
> +Name: %{_target}-gdb-%{gdb_version}-%{release}
> +Summary: GDB v%{gdb_version} for target %{_target} on host %{_host}
> +Version: %{gdb_version}
> +Release: %{release}
> +URL: http://www.gnu.org/software/gdb/
> +BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
> +# Source
> +%source set gdb http://ftp.gnu.org/gnu/gdb/gdb-%{gdb_version}.tar.bz2
> +# Prepare the source code.
> +%prep
> + build_top=$(pwd)
> + source_dir_gdb="gdb-%{gdb_version}"
> + %source setup gdb -q -n gdb-%{gdb_version}
> + %patch setup gdb -p1
> + cd ${build_top}
> +%build
> + build_top=$(pwd)
> + %{build_directory}
> + mkdir -p ${build_dir}
> + cd ${build_dir}
> + %{host_build_flags}
> + if test "%{_build}" != "%{_host}" ; then
> + GDB_LIBS_STATIC="-lexpat"
> + else
> + GDB_LIBS="%{_forced_static}"
> + fi
> + LIBS_STATIC=${GDB_LIBS_STATIC} \
> + LIBS=${GDB_LIBS} \
> + ../${source_dir_gdb}/configure \
> + --build=%{_build} --host=%{_host} \
> + --target=%{_target} \
> + --verbose --disable-nls \
> + --without-included-gettext \
> + --disable-win32-registry \
> + --disable-werror \
> + --disable-sim \
> + --with-expat \
> + --without-python \
> + --prefix=%{_prefix} --bindir=%{_bindir} \
> + --exec-prefix=%{_exec_prefix} \
> + --includedir=%{_includedir} --libdir=%{_libdir} \
> + --mandir=%{_mandir} --infodir=%{_infodir}
> + %{__make} %{?_smp_mflags} all
> + cd ${build_top}
> +%install
> + build_top=$(pwd)
> + %{__rmdir} $SB_BUILD_ROOT
> + cd ${build_dir}
> + %{__make} DESTDIR=$SB_BUILD_ROOT install
> + # Dropped in FSF-binutils-2.9.5, but Cygwin still ships it.
> + %{__rmdir} $SB_BUILD_ROOT%{_infodir}/configure.info*
> + %{__rmfile} $SB_BUILD_ROOT%{_infodir}/dir
> + touch $SB_BUILD_ROOT%{_infodir}/dir
> + cd ${build_top}
