[PATCH 48/52] samples/unlimited: Fix printf() warning and clean up
Wed Oct 8 20:27:40 UTC 2014
On 10/8/2014 3:20 PM, Gedare Bloom wrote:
> On Wed, Oct 8, 2014 at 3:16 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>>  testsuites/samples/unlimited/init.c   | 23 ++++++++++++++---------
>>  testsuites/samples/unlimited/system.h |  2 +-
>>  testsuites/samples/unlimited/test1.c  |  2 +-
>>  testsuites/samples/unlimited/test2.c  | 28 ++++++++++++++++------------
>>  testsuites/samples/unlimited/test3.c  |  2 +-
>>  5 files changed, 33 insertions(+), 24 deletions(-)
>> diff --git a/testsuites/samples/unlimited/init.c b/testsuites/samples/unlimited/init.c
>> index 06e0c3a..0fb5505 100644
>> --- a/testsuites/samples/unlimited/init.c
>> +++ b/testsuites/samples/unlimited/init.c
>> @@ -55,20 +55,21 @@ rtems_task Init(
>>  rtems_task test_task(
>>    rtems_task_argument my_number
>>    rtems_event_set out;
>> +  unsigned int    my_n = (unsigned int) my_number;
>> -  printf( "task %" PRIdrtems_task_argument " has started.\n",  my_number);
>> +  printf( "task %" PRIdrtems_task_argument " has started.\n",  my_n);
> Should this just be %u now, since you converted the my_number? ditto below.
Yeah. That's a good catch. Done.
>>    rtems_event_receive(1, RTEMS_WAIT | RTEMS_EVENT_ANY, 0, &out);
>> -  printf( "task %" PRIdrtems_task_argument " ending.\n",  my_number);
>> +  printf( "task %" PRIdrtems_task_argument " ending.\n",  my_n);
>>    rtems_task_delete(RTEMS_SELF);
>> -void destory_all_tasks(
>> +void destroy_all_tasks(
>>    const char *who
>> @@ -78,19 +79,23 @@ void destory_all_tasks(
>>     *  If the id is not zero, signal the task to delete.
>> -  for (task = 0; task < MAX_TASKS; task++)
>> -    if (task_id[task])
>> -      printf(" %s : signal task %08" PRIxrtems_id " to delete, ", who, task_id[task]);
>> +  for (task = 0; task < MAX_TASKS; task++) {
>> +    if (task_id[task]) {
>> +      printf(
>> +        " %s : signal task %08" PRIxrtems_id " to delete, ",
>> +         who,
>> +         task_id[task]
>>        fflush(stdout);
>>        rtems_event_send(task_id[task], 1);
>>        task_id[task] = 0;
>>  bool status_code_bad(
>>    rtems_status_code status_code
>>    if (status_code != RTEMS_SUCCESSFUL)
>> diff --git a/testsuites/samples/unlimited/system.h b/testsuites/samples/unlimited/system.h
>> index 911aa69..5da5d06 100644
>> --- a/testsuites/samples/unlimited/system.h
>> +++ b/testsuites/samples/unlimited/system.h
>> @@ -24,7 +24,7 @@ rtems_task test_task(
>>  void
>> -destory_all_tasks(
>> +destroy_all_tasks(
>>    const char *who
>> diff --git a/testsuites/samples/unlimited/test1.c b/testsuites/samples/unlimited/test1.c
>> index 9d90af0..f02857c 100644
>> --- a/testsuites/samples/unlimited/test1.c
>> +++ b/testsuites/samples/unlimited/test1.c
>> @@ -99,7 +99,7 @@ void test1()
>>      exit( 1 );
>> -  destory_all_tasks("TEST1");
>> +  destroy_all_tasks("TEST1");
>>    the_information->auto_extend = auto_extend;
>> diff --git a/testsuites/samples/unlimited/test2.c b/testsuites/samples/unlimited/test2.c
>> index 911451f..411a401 100644
>> --- a/testsuites/samples/unlimited/test2.c
>> +++ b/testsuites/samples/unlimited/test2.c
>> @@ -95,7 +95,7 @@ void test2()
>>      printf( " FAIL2 : not enough tasks created -\n"
>>              "         task created = %" PRIi32 ", required number = %i\n",
>>              task_count, (TASK_ALLOCATION_SIZE * 5) - TASK_INDEX_OFFSET);
>> -    destory_all_tasks("TEST2");
>> +    destroy_all_tasks("TEST2");
>>      exit( 1 );
>> @@ -112,7 +112,7 @@ void test2()
>>          printf( " FAIL2 : remove task has a 0 id -\n"
>>                  "         task number = %" PRIi32 "\n",
>>                  remove_task);
>>          exit( 1 );
>> @@ -122,7 +122,8 @@ void test2()
>>        removed_ids[task++] = task_id[remove_task];
>> -      printf(" TEST2 : block %" PRIi32 " remove, signal task %08" PRIxrtems_id ", ", block, task_id[remove_task]);
>> +      printf(" TEST2 : block %" PRIi32 " remove, signal task %08"
>> +               PRIxrtems_id ", ", block, task_id[remove_task]);
>>        rtems_event_send(task_id[remove_task], 1);
>>        task_id[remove_task] = 0;
>> @@ -144,7 +145,7 @@ void test2()
>>      if (id_slot == MAX_TASKS)
>>        printf( " FAIL2 : no free task id slot.\n");
>>        exit( 1 );
>> @@ -164,11 +165,12 @@ void test2()
>>        printf( " FAIL2 : re-creating a task -\n"
>>                id_slot);
>>        exit( 1 );
>> -    printf("number = %3" PRIi32 ", id = %08" PRIxrtems_id ", starting, ", task_count, task_id[id_slot]);
>> +    printf("number = %3" PRIi32 ", id = %08" PRIxrtems_id ", starting, ",
>> +           task_count, task_id[id_slot]);
>>      result = rtems_task_start(task_id[id_slot],
>>                                test_task,
>> @@ -179,7 +181,7 @@ void test2()
>>        printf( " FAIL : re-starting a task -\n"
>>                id_slot);
>>        exit( 1 );
>> @@ -190,7 +192,8 @@ void test2()
>>      NEXT_TASK_NAME(c1, c2, c3, c4);
>> -     *  Search the removed ids to see if it existed, clear the removed id when found
>> +     *  Search the removed ids to see if it existed, clear the removed id
>> +     *  when found
>>      for (remove_task = 0; remove_task < (TASK_ALLOCATION_SIZE * 2); remove_task++)
>> @@ -212,9 +215,10 @@ void test2()
>>        for (allocated_id = 0; allocated_id < MAX_TASKS; allocated_id++)
>>          if ((task_id[id_slot] == task_id[allocated_id]) && (id_slot != allocated_id))
>> -          printf( " FAIL2 : the new id is the same as an id already allocated -\n"
>> -                  "         task id = %08" PRIxrtems_id "\n",
>> -                  task_id[id_slot]);
>> +          printf(
>> +            " FAIL2 : the new id is the same as an id already allocated -\n"
>> +            "         task id = %08" PRIxrtems_id "\n",
>> +            task_id[id_slot]);
>>            exit( 1 );
>> @@ -227,7 +231,7 @@ void test2()
>>      task_count++;
>>    printf( " TEST2 : completed\n" );
>> diff --git a/testsuites/samples/unlimited/test3.c b/testsuites/samples/unlimited/test3.c
>> index 247d175..6330f3c 100644
>> --- a/testsuites/samples/unlimited/test3.c
>> +++ b/testsuites/samples/unlimited/test3.c
>> @@ -144,7 +144,7 @@ void test3()
>> -  destory_all_tasks("TEST3");
>> +  destroy_all_tasks("TEST3");
>>    printf( " TEST3 : completed\n" );
>> 1.9.3
>> devel mailing list
>> devel at rtems.org
