Noting C Methods Called from .S Re: Batch of Patches from Joel
Mon Oct 13 16:01:17 UTC 2014
On 10/13/2014 10:51 AM, Gedare Bloom wrote:
> On Mon, Oct 13, 2014 at 11:18 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> On 10/13/2014 9:48 AM, Gedare Bloom wrote:
>>> These 23 look good to me. -Gedare
>> Thanks. I know this many patches is a real pain but it
>> is unfortunately needed to get the warning count down.
>> The unique warning count has dropped from ~1750 to
>> ~800 in the past week. Of those ~800, there are still
>> 533 "no previous prototypes" left to look at.  I am
>> sticking to adding static or addressing .h files but we
>> still have to figure out what to do about C methods
>> that are only referenced from .S files. :)
> The prototypes can still go into a header file, which could even be
> included by the .S file (with appropriate guards) to expose the
> dependency.
That's an option.  The ASM guards could just disable almost the entire
file except file header by default. Obviously if we are adding it for the
first time, then no constants from the .h are needed.
But I am skipping these until the warning list is lower. Sticking to
easier ones.
> -Gedare
>> NOTE: For defaults for weak symbols, I am just adding
>> a prototype to the C file.
>> Committing. Thanks.
>> --joel
>>> On Mon, Oct 13, 2014 at 10:13 AM, Joel Sherrill
>>>> Hi
>>>> It was rainy here over the weekend and I hacked at warnings.
>>>> I have a branch with 80 patches pending. That is obviously
>>>> too much to send to devel in one batch. This is the first
>>>> batch of 23 and these are the more unique patches and
>>>> a couple of cases of "apply a pattern"
>>>> + Clean up, then remove mips/clock because it was not even compiled
>>>> + delete unused rtems_shell_cp_exit()
>>>> + PowerPC bootloader patch round 2 to address Gedare's comments
>>>> + add <bsp/bootcard.h> to files where that fixed warnings
>>>> + eliminate odd and unused debug methods from some m68k consoles
>>>> Beyond this, the next patch of patches will be the same old warning
>>>> removal tricks and clean up. Make things static, correct types, etc.
>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>> Support Available                (256) 722-9985
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
