[PATCH] [RTEMS TESTER] Add new OpenRISC/or1ksim BSP script using qemu
Sun Sep 7 22:40:32 UTC 2014
On 7/09/2014 4:25 pm, Hesham Moustafa wrote:
> The test results improved a little bit from yesterday. Here are the results:
> Passed:   365
> Failed:     6
> Timeouts: 130
> Invalid:    2
> Total:    503
> Average test time: 0:00:22.877361
> Testing time     : 3:11:47.312905
> The full log file is attached.
If you run one of the timed out tests, say fsdosfsname01.exe from the
command line does it complete and if so how long ?
