building RTEMS 4.11 leon3 with floating point support?
Mon Aug 31 06:40:51 UTC 2015
Hello Alan,
I am not sure how Gaisler manages this in their RCC, but I think for
standard RTEMS we need additional BSPs (e.g. via leon3_fp.cfg and
ngmp_fp.cfg configuration files).
On 17/08/15 17:29, Cudmore, Alan P. (GSFC-5820) wrote:
> Hi,
> We are currently trying to use the leon3 BSP for RTEMS 4.11.
> We have used the 4.10 RCC/Gaisler tools with the Driver Manager in the
> past, but we would like to be on 4.11 for the SMP support.
> When I build the 4.11 leon3 BSP, I seem to only have soft-float
> support. When I try to build with the —enable-multilib configure
> switch, the build fails. Before I start trying to determine the cause
> of the compile failure, I wanted to make sure I am enabling floating
> point support for the LEON3 correctly.
> Thanks,
> Alan
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
