building RTEMS 4.11 leon3 with floating point support?
Cudmore, Alan P. (GSFC-5820) alan.p.cudmore at nasa.gov
Mon Aug 31 10:47:15 UTC 2015
Having a floating point configuration of the BSP makes sense. I was able
to rebuild the BSP with the hardware floating point compiler option and it
works.
I did get a floating point exception in the FTP task and had to change the
FTP task create to enable floating point. Is it worth submitting a patch
to change that?
Thanks,
Alan
On 8/31/15, 2:40 AM, "Sebastian Huber"
>Hello Alan,
>I am not sure how Gaisler manages this in their RCC, but I think for
>standard RTEMS we need additional BSPs (e.g. via leon3_fp.cfg and
>ngmp_fp.cfg configuration files).
>On 17/08/15 17:29, Cudmore, Alan P. (GSFC-5820) wrote:
>> Hi,
>> We are currently trying to use the leon3 BSP for RTEMS 4.11.
>> We have used the 4.10 RCC/Gaisler tools with the Driver Manager in the
>> past, but we would like to be on 4.11 for the SMP support.
>> When I build the 4.11 leon3 BSP, I seem to only have soft-float
>> support. When I try to build with the ‹enable-multilib configure
>> switch, the build fails. Before I start trying to determine the cause
>> of the compile failure, I wanted to make sure I am enabling floating
>> point support for the LEON3 correctly.
>> Thanks,
>> Alan
>> devel mailing list
>> devel at rtems.org
>Sebastian Huber, embedded brains GmbH
>Address : Dornierstr. 4, D-82178 Puchheim, Germany
>Phone   : +49 89 189 47 41-16
>Fax     : +49 89 189 47 41-09
>E-Mail  : sebastian.huber at embedded-brains.de
>PGP     : Public key available on request.
>Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
