Linker Set Based Initialization
Joel Sherrill
joel at rtems.org
Tue Dec 8 15:45:58 UTC 2015
On Tue, Dec 8, 2015 at 9:09 AM, Sebastian Huber <
> On 08/12/15 16:03, Joel Sherrill wrote:
>> What BSPs/architectures have you tested?
> I temporarily moved the splinkersets01 test to the samples/ticker and
> tested that all BSPs build and link this test.
> I executed the splinkersets01 test on sis, psim and
> arm_realview_pbx_a9_qemu.
>> Is this something that breaks on a per BSP basis? or per architecture
>> basis?
>> I am assuming that since it is linker based, each BSP could have broken
>> linkcmds.
>> Is that right?
> It breaks on a per linker command file basis. Since all the maintained
> BSPs use a linkercmds.base, which shouldn't be a big issue.
That means a LOT of the BSPs are broken. You have defined maintained in
your own way.
There are only a handful of architectures with linkcmds.base in them:
./or1k/shared/startup/linkcmds.base
./arm/shared/startup/linkcmds.base
./m68k/shared/startup/linkcmds.base
./powerpc/tqm8xx/startup/linkcmds.base
./powerpc/gen5200/startup/linkcmds.base
./powerpc/shared/startup/linkcmds.base
./sparc/shared/startup/linkcmds.base
I am not sure how many BSPs within arm, m68k, or powerpc actually use the
linkcmds.base.
By my count, 13 of 94 BSP families have linkcmds.base.
> For requirements on the linker command file, see new chapter in user
> manual. However BSPs should not deal with this in copy and paste linker
> command files and instead use a linkercmds.base file.
So 85% of the BSP families don't use linkcmds.base and by the above
statement,
they must immediately be migrated to linkcmds.base.
Unless you have a plan to address this problem, I am on the side of
rejecting the
part of this patch that changes the initialization. And the issue must be
addressed
before this can be merged.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151208/18ebaa85/attachment.html>
