Possible generic RSB issue
Thu Jan 15 19:49:55 UTC 2015
On 1/15/2015 1:47 PM, Gedare Bloom wrote:
> Did you update the binutils version number in the RSB build set? e.g.
> 4.11/rtems-moxie.bset
Yes. I switched it to git. But moxie is using 2.24.
I removed the old moxie tools from the install point and it is now using
the right as version. Checked by going into gcc build and doing:
./gcc/as --version
Still needs a gcc update I think but it is by this issue. :)
> -Gedare
> On Thu, Jan 15, 2015 at 2:38 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> Hi
>> I am trying to update the moxie tools and the previous version
>> of binutils used is incapable of building a current toolset.
>> Even when I take the install point out of my PATH, it appears that
>> that is used internally by the RSB and thus the as used to build
>> gcc is the one from the previous install.
>> I think generically this means that once you have a binutils installed,
>> the next tool build will use the old binutils and thus we are possibly
>> never building the updated toolset with the updated binutils.  In other
>> words, if binutils installed, then that is used instead of the one about
>> to be installed.
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> devel mailing list
>> devel at rtems.org
