testing order for rtems-libbsd
Tue Jun 23 07:19:00 UTC 2015
On 23/06/15 08:28, Chris Johns wrote:
> On 23/06/2015 3:55 pm, Sebastian Huber wrote:
>> On 23/06/15 01:56, Joel Sherrill wrote:
>>> Hi
>>> I have it built now for pc386 but some tests run and others don't.
>>> Any suggestions on the order to run tests in from simplest to
>>> most complex?
>> The ones covered by a "make run_tests" should work (there is a known
>> issue with selectpollkqueue01).
> On the Zynq some test kill qemu then the init task is deleted. I have
> not looked into this yet.
I fixed this problem.
It would be nice to have some target to run the standard tests and check
the END OF message (no network environment, finite test run-time with
END OF message).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
