[PATCH 1/2] cpukit: Add Epiphany architecture port
Hesham ALMatary heshamelmatary at gmail.com
Sat May 9 13:50:26 UTC 2015
On Fri, May 8, 2015 at 4:00 PM, Gedare Bloom <gedare at rtems.org> wrote:
> You should aim to write doxygen for the port-specific headers at least.
> On Thu, May 7, 2015 at 10:11 PM, Hesham ALMatary
> <heshamelmatary at gmail.com> wrote:
>>  cpukit/configure.ac                                |    1 +
>>  cpukit/librpc/src/xdr/xdr_float.c                  |    1 +
>>  cpukit/score/cpu/Makefile.am                       |    1 +
>>  cpukit/score/cpu/epiphany/Makefile.am              |   33 +
>>  cpukit/score/cpu/epiphany/cpu.c                    |   99 ++
>>  .../cpu/epiphany/epiphany-context-initialize.c     |   49 +
>>  .../score/cpu/epiphany/epiphany-context-switch.S   |  197 ++++
>>  .../cpu/epiphany/epiphany-exception-handler.S      |  290 +++++
>>  cpukit/score/cpu/epiphany/preinstall.am            |   53 +
>>  cpukit/score/cpu/epiphany/rtems/asm.h              |   97 ++
>>  cpukit/score/cpu/epiphany/rtems/score/cpu.h        | 1171 ++++++++++++++++++++
>>  cpukit/score/cpu/epiphany/rtems/score/cpu_asm.h    |   74 ++
>>  cpukit/score/cpu/epiphany/rtems/score/cpuatomic.h  |   14 +
>>  .../cpu/epiphany/rtems/score/epiphany-utility.h    |  180 +++
>>  cpukit/score/cpu/epiphany/rtems/score/epiphany.h   |   50 +
>>  cpukit/score/cpu/epiphany/rtems/score/types.h      |   55 +
>>  16 files changed, 2365 insertions(+)
>>  create mode 100644 cpukit/score/cpu/epiphany/Makefile.am
>>  create mode 100644 cpukit/score/cpu/epiphany/cpu.c
>>  create mode 100644 cpukit/score/cpu/epiphany/epiphany-context-initialize.c
>>  create mode 100644 cpukit/score/cpu/epiphany/epiphany-context-switch.S
>>  create mode 100644 cpukit/score/cpu/epiphany/epiphany-exception-handler.S
>>  create mode 100644 cpukit/score/cpu/epiphany/preinstall.am
>>  create mode 100644 cpukit/score/cpu/epiphany/rtems/asm.h
>>  create mode 100644 cpukit/score/cpu/epiphany/rtems/score/cpu.h
>>  create mode 100644 cpukit/score/cpu/epiphany/rtems/score/cpu_asm.h
>>  create mode 100644 cpukit/score/cpu/epiphany/rtems/score/cpuatomic.h
>>  create mode 100644 cpukit/score/cpu/epiphany/rtems/score/epiphany-utility.h
>>  create mode 100644 cpukit/score/cpu/epiphany/rtems/score/epiphany.h
>>  create mode 100644 cpukit/score/cpu/epiphany/rtems/score/types.h
>> diff --git a/cpukit/configure.ac b/cpukit/configure.ac
>> index 2b432f6..46942c9 100644
>> --- a/cpukit/configure.ac
>> +++ b/cpukit/configure.ac
>> @@ -453,6 +453,7 @@ score/cpu/Makefile
>>  score/cpu/arm/Makefile
>>  score/cpu/bfin/Makefile
>>  score/cpu/avr/Makefile
>> +score/cpu/epiphany/Makefile
>>  score/cpu/h8300/Makefile
>>  score/cpu/i386/Makefile
>>  score/cpu/lm32/Makefile
>> diff --git a/cpukit/librpc/src/xdr/xdr_float.c b/cpukit/librpc/src/xdr/xdr_float.c
>> index 925b294..ac8c46d 100644
>> --- a/cpukit/librpc/src/xdr/xdr_float.c
>> +++ b/cpukit/librpc/src/xdr/xdr_float.c
>> @@ -61,6 +61,7 @@ static char *rcsid = "$FreeBSD: src/lib/libc/xdr/xdr_float.c,v 1.7 1999/08/28 00
>>  #if defined(__alpha__) || \
>>      defined(_AM29K) || \
>>      defined(__arm__) || \
>> +    defined(__epiphany__) ||  defined(__EPIPHANY__) || \
>>      defined(__H8300__) || defined(__h8300__) || \
>>      defined(__hppa__) || \
>>      defined(__i386__) || \
>> diff --git a/cpukit/score/cpu/Makefile.am b/cpukit/score/cpu/Makefile.am
>> index 69abcd6..7279d38 100644
>> --- a/cpukit/score/cpu/Makefile.am
>> +++ b/cpukit/score/cpu/Makefile.am
>> @@ -4,6 +4,7 @@ DIST_SUBDIRS =
>>  DIST_SUBDIRS += arm
>>  DIST_SUBDIRS += avr
>>  DIST_SUBDIRS += bfin
>> +DIST_SUBDIRS += epiphany
>>  DIST_SUBDIRS += h8300
>>  DIST_SUBDIRS += i386
>>  DIST_SUBDIRS += lm32
>> diff --git a/cpukit/score/cpu/epiphany/Makefile.am b/cpukit/score/cpu/epiphany/Makefile.am
>> new file mode 100644
>> index 0000000..0df3376
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/Makefile.am
>> @@ -0,0 +1,33 @@
>> +include $(top_srcdir)/automake/compile.am
>> +CLEANFILES =
>> +DISTCLEANFILES =
>> +include_rtemsdir = $(includedir)/rtems
>> +include_rtems_HEADERS = rtems/asm.h
>> +include_rtems_scoredir = $(includedir)/rtems/score
>> +include_rtems_score_HEADERS =
>> +include_rtems_score_HEADERS += rtems/score/cpu.h
>> +include_rtems_score_HEADERS += rtems/score/cpuatomic.h
>> +include_rtems_score_HEADERS += rtems/score/cpu_asm.h
>> +include_rtems_score_HEADERS += rtems/score/types.h
>> +include_rtems_score_HEADERS += rtems/score/epiphany.h
>> +include_rtems_score_HEADERS += rtems/score/epiphany-utility.h
>> +noinst_LIBRARIES = libscorecpu.a
>> +libscorecpu_a_SOURCES  = cpu.c
>> +libscorecpu_a_SOURCES += epiphany-exception-handler.S
>> +libscorecpu_a_SOURCES += epiphany-context-switch.S
>> +libscorecpu_a_SOURCES += epiphany-context-initialize.c
> Remove extra blank line
>> +libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
>> +all-local: $(PREINSTALL_FILES)
>> +include $(srcdir)/preinstall.am
>> +include $(top_srcdir)/automake/local.am
>> diff --git a/cpukit/score/cpu/epiphany/cpu.c b/cpukit/score/cpu/epiphany/cpu.c
>> index 0000000..0558dbb
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/cpu.c
>> @@ -0,0 +1,99 @@
>> + *  Epiphany CPU Dependent Source
>> + *  COPYRIGHT (c) 2015 University of York.
>> + *  Hesham ALMatary <hmka501 at york.ac.uk>
> I'd prefer the Copyright on a single line, don't need all caps for
> COPYRIGHT, even though the OAR one is like that.
>> + *  COPYRIGHT (c) 1989-1999.
>> + *  On-Line Applications Research Corporation (OAR).
> I also question whether OAR actually holds a copyright on the contents
> here but that is a different matter.
>> + *  The license and distribution terms for this file may be
>> + *  found in the file LICENSE in this distribution or at
>> + *  http://www.rtems.com/license/LICENSE.
>> +#include <rtems/system.h>
>> +#include <rtems/score/isr.h>
>> +#include <rtems/score/wkspace.h>
>> +#include <bsp/linker-symbols.h>
>> +#include <rtems/score/cpu.h>
>> +void _init(void);
>> +void _fini(void);
>> +void _init(void)
>> +  /* Do nothing */
>> +void _fini(void)
>> +  /* Do nothing */
>> +void _CPU_Exception_frame_print (const CPU_Exception_frame *ctx)
>> +  /* Do nothing */
>> + * @brief Performs processor dependent initialization.
>> +void _CPU_Initialize(void)
>> +  /* Do nothing */
>> +void _CPU_ISR_Set_level(uint32_t level)
>> +  /* Do nothing */
>> +uint32_t  _CPU_ISR_Get_level( void )
>> +  /* Do nothing */
>> +  return 0;
>> +void _CPU_ISR_install_raw_handler(
>> +  uint32_t   vector,
>> +  proc_ptr    new_handler,
>> +  proc_ptr   *old_handler
>> +  /* Do nothing */
>> +void _CPU_ISR_install_vector(
>> +  uint32_t    vector,
>> +  /* Do nothing */
>> +void _CPU_Install_interrupt_stack( void )
>> +  /* Do nothing */
>> +CPU_Counter_ticks _CPU_Counter_read( void )
>> +  static CPU_Counter_ticks counter;
>> +  CPU_Counter_ticks snapshot;
>> +  snapshot = counter;
>> +  counter = snapshot + 1;
>> +  return snapshot;
>> +void *_CPU_Thread_Idle_body( uintptr_t ignored )
>> +  do {
>> +    asm volatile ("idle");
> Please use __asm__ __volatile__.
>> +  } while (1);
>> +  return (void *) 0;
> A general comment, perhaps this function should be declared with the
> 'no return' attribute (likely on every port.)
>> diff --git a/cpukit/score/cpu/epiphany/epiphany-context-initialize.c b/cpukit/score/cpu/epiphany/epiphany-context-initialize.c
>> index 0000000..f92c46e
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/epiphany-context-initialize.c
>> @@ -0,0 +1,49 @@
>> + * COPYRIGHT (c) 1989-2006
>> + * http://www.rtems.org/license/LICENSE.
>> +#ifdef HAVE_CONFIG_H
>> +  #include "config.h"
>> +#endif
>> +#include <string.h>
>> +#include <rtems/score/interr.h>
>> +void _CPU_Context_Initialize(
>> +  Context_Control *context,
>> +  void *stack_area_begin,
>> +  size_t stack_area_size,
>> +  uint32_t new_level,
>> +  void (*entry_point)( void ),
>> +  bool is_fp,
>> +  void *tls_area
>> +  uint32_t stack = ((uint32_t) stack_area_begin);
> We should prefer to use uintptr_t when casting pointers into integer types.
>> +  uint32_t sr, config, iret;
>> +  /* Account for red-zone */
>> +  uint32_t stack_high = stack + stack_area_size - 128;
> A macro for the 128 would be nice eg RED_ZONE_SIZE.
>> +  asm volatile ("movfs %0, status \n" : "=r" (sr):);
>> +  asm volatile ("movfs %0, config \n" : "=r" (config):);
> Is this config unused?
>> +  asm volatile ("movfs %0, iret \n" : "=r" (iret):);
>> +  memset(context, 0, sizeof(*context));
>> +  context->r[13] = stack_high;
>> +  context->r[11] = stack_high;
> I'd prefer to see the stores sorted, e.g. r[13] then r[11], unless the
> store order matters.
>> +  context->r[14] = (uint32_t) entry_point;
> Pointer cast.
>> +  context->status = sr;
>> +  context->iret = iret;
>> diff --git a/cpukit/score/cpu/epiphany/epiphany-context-switch.S b/cpukit/score/cpu/epiphany/epiphany-context-switch.S
>> index 0000000..3bb3bf3
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/epiphany-context-switch.S
>> @@ -0,0 +1,197 @@
>> +#endif
>> +#include <rtems/asm.h>
>> +.section .text,"ax";
> Put space after comma. Is the ; needed here? It's not used elsewhere.
>> +.align 4
>> +PUBLIC(_CPU_Context_switch)
>> +PUBLIC(_CPU_Context_restore)
>> +PUBLIC(_CPU_Context_restore_fp)
>> +PUBLIC(_CPU_Context_save_fp)
>> +PUBLIC(restore)
>> +SYM(_CPU_Context_switch):
>> +  /* Disable interrupts and store all registers */
> What does the ABI say about register use, what needs to be
> saved/restored here, and in the ISR handler? Does it really all need
> to be done, or is there room for optimization later?
It just defines which registers are callee/caller saved during
procedures calls, I prefered to dump all registers for the first
version of the support like with or1k, and leave optimization for
later.
>> +  gid
>> +  str r0,  [r0]
>> +  str r1,  [r0,1]
>> +  str r2,  [r0,2]
>> +  str r3,  [r0,3]
>> +  str r4,  [r0,4]
>> +  str r5,  [r0,5]
>> +  str r6,  [r0,6]
>> +  str r7,  [r0,7]
>> +  str r8,  [r0,8]
>> +  str r9,  [r0,9]
>> +  str r10, [r0,10]
>> +  str fp,  [r0,11]
>> +  str r12, [r0,12]
>> +  str sp,  [r0,13]
>> +  str lr,  [r0,14]
>> +  str r15, [r0,15]
>> +  str r16, [r0,16]
>> +  str r17, [r0,17]
>> +  str r18, [r0,18]
>> +  str r19, [r0,19]
>> +  str r20, [r0,20]
>> +  str r21, [r0,21]
>> +  str r22, [r0,22]
>> +  str r23, [r0,23]
>> +  str r24, [r0,24]
>> +  str r25, [r0,25]
>> +  str r26, [r0,26]
>> +  str r27, [r0,27]
>> +  str r28, [r0,28]
>> +  str r29, [r0,29]
>> +  str r30, [r0,30]
>> +  str r31, [r0,31]
>> +  str r32, [r0,32]
>> +  str r33, [r0,33]
>> +  str r34, [r0,34]
>> +  str r35, [r0,35]
>> +  str r36, [r0,36]
>> +  str r37, [r0,37]
>> +  str r38, [r0,38]
>> +  str r39, [r0,39]
>> +  str r40, [r0,40]
>> +  str r41, [r0,41]
>> +  str r42, [r0,42]
>> +  str r43, [r0,43]
>> +  str r44, [r0,44]
>> +  str r45, [r0,45]
>> +  str r46, [r0,46]
>> +  str r47, [r0,47]
>> +  str r48, [r0,48]
>> +  str r49, [r0,49]
>> +  str r50, [r0,50]
>> +  str r51, [r0,51]
>> +  str r52, [r0,52]
>> +  str r53, [r0,53]
>> +  str r54, [r0,54]
>> +  str r55, [r0,55]
>> +  str r56, [r0,56]
>> +  str r57, [r0,57]
>> +  str r58, [r0,58]
>> +  str r59, [r0,59]
>> +  str r60, [r0,60]
>> +  str r61, [r0,61]
>> +  str r62, [r0,62]
>> +  str r63, [r0,63]
>> +  /* Store status register */
>> +  movfs r27, status
>> +  str r27, [r0,64]
>> +  /* Store config register */
>> +  movfs r27, config
>> +  str r27, [r0,65]
>> +  /* Store interrupt return address register */
>> +  movfs r27, iret
>> +  str r27, [r0,66]
>> +SYM(restore):
>> +  /* r1 contains buffer address, skip it */
>> +  ldr r2,  [r1,2]
>> +  ldr r3,  [r1,3]
>> +  ldr r4,  [r1,4]
>> +  ldr r5,  [r1,5]
>> +  ldr r6,  [r1,6]
>> +  ldr r7,  [r1,7]
>> +  ldr r8,  [r1,8]
>> +  ldr r9,  [r1,9]
>> +  ldr r10, [r1,10]
>> +  ldr fp,  [r1,11]
>> +  ldr r12, [r1,12]
>> +  ldr sp,  [r1,13]
>> +  ldr lr,  [r1,14]
>> +  ldr r15, [r1,15]
>> +  ldr r16, [r1,16]
>> +  ldr r17, [r1,17]
>> +  ldr r18, [r1,18]
>> +  ldr r19, [r1,19]
>> +  ldr r20, [r1,20]
>> +  ldr r21, [r1,21]
>> +  ldr r22, [r1,22]
>> +  ldr r23, [r1,23]
>> +  ldr r24, [r1,24]
>> +  ldr r25, [r1,25]
>> +  ldr r26, [r1,26]
>> +  ldr r27, [r1,27]
>> +  ldr r32, [r1,32]
>> +  ldr r33, [r1,33]
>> +  ldr r34, [r1,34]
>> +  ldr r35, [r1,35]
>> +  ldr r36, [r1,36]
>> +  ldr r37, [r1,37]
>> +  ldr r38, [r1,38]
>> +  ldr r39, [r1,39]
>> +  ldr r40, [r1,40]
>> +  ldr r41, [r1,41]
>> +  ldr r42, [r1,42]
>> +  ldr r43, [r1,43]
>> +  ldr r44, [r1,44]
>> +  ldr r45, [r1,45]
>> +  ldr r46, [r1,46]
>> +  ldr r47, [r1,47]
>> +  ldr r48, [r1,48]
>> +  ldr r49, [r1,49]
>> +  ldr r50, [r1,50]
>> +  ldr r51, [r1,51]
>> +  ldr r52, [r1,52]
>> +  ldr r53, [r1,53]
>> +  ldr r54, [r1,54]
>> +  ldr r55, [r1,55]
>> +  ldr r56, [r1,56]
>> +  ldr r57, [r1,57]
>> +  ldr r58, [r1,58]
>> +  ldr r59, [r1,59]
>> +  ldr r60, [r1,60]
>> +  ldr r61, [r1,61]
>> +  ldr r62, [r1,62]
>> +  ldr r63, [r1,63]
>> +  /* Load status register */
>> +  ldr r0, [r1,64]
>> +  movts status, r0
>> +  /* Load config register */
>> +  ldr r0, [r1,65]
>> +  movts config, r0
>> +  /* Load interrupt return address register */
>> +  ldr r0,[r1,66]
>> +  movts iret, r0
>> +  ldr r0,[r1]
>> +  ldr r1,[r1,1]
>> +  /* Enable interrupts and return */
>> +  gie
>> +  jr lr
>> +SYM(_CPU_Context_restore):
>> +  mov     r1, r0
>> +  b       _restore
>> +  nop
>> +/* No FP support for Epiphany yet */
>> +SYM(_CPU_Context_restore_fp):
>> +  nop
>> + SYM(_CPU_Context_save_fp):
>> +  nop
>> diff --git a/cpukit/score/cpu/epiphany/epiphany-exception-handler.S b/cpukit/score/cpu/epiphany/epiphany-exception-handler.S
>> index 0000000..169329f
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/epiphany-exception-handler.S
>> @@ -0,0 +1,290 @@
>> + * @file
>> + * @ingroup ScoreCPU
>> + * @brief Epiphany exception support implementation.
>> +#include "config.h"
>> +#endif
>> +#include <rtems/score/percpu.h>
>> +.extern _bsp_start_vector_table_begin
>> +.extern __Thread_Dispatch
> See below about EXTERN macro.
>> +.section .text, "ax"
>> +.align 4
>> +.global _ISR_Handler;
>> +.type _ISR_Handler, %function;
> Again, it would be better to be consistent in using the terminating
> semi-colon. Also, shouldn't these be using the PUBLIC and SYM macros?
> Should you introduce a macro for this .type directive also?
>> +_ISR_Handler:
>> +  /* Reserve space for CPU_Exception_frame */
>> +  add sp, sp, #-280
> Define a macro for the size of the frame in the epiphany.h file.
>> +  str r0,[sp]
>> +  str r1,[sp,1]
>> +  str r2,[sp,2]
>> +  /* Save config register */
>> +  movfs r1,config
>> +  str r1, [sp,65]
> Is there a reason this is done here instead of later?
>> +  str r3,  [sp,3]
>> +  str r4,  [sp,4]
>> +  str r5,  [sp,5]
>> +  str r6,  [sp,6]
>> +  str r7,  [sp,7]
>> +  str r8,  [sp,8]
>> +  str r9,  [sp,9]
>> +  str r10, [sp,10]
>> +  str fp,  [sp,11]
>> +  str r12, [sp,12]
> You could probably save the sp here too instead of below.
>> +  str lr,  [sp,14]
>> +  str r15, [sp,15]
>> +  str r16, [sp,16]
>> +  str r17, [sp,17]
>> +  str r18, [sp,18]
>> +  str r19, [sp,19]
>> +  str r20, [sp,20]
>> +  str r21, [sp,21]
>> +  str r22, [sp,22]
>> +  str r23, [sp,23]
>> +  str r24, [sp,24]
>> +  str r25, [sp,25]
>> +  str r26, [sp,26]
>> +  str r27, [sp,27]
>> +  str r28, [sp,28]
>> +  str r29, [sp,29]
>> +  str r30, [sp,30]
>> +  str r31, [sp,31]
>> +  str r32, [sp,32]
>> +  str r33, [sp,33]
>> +  str r34, [sp,34]
>> +  str r35, [sp,35]
>> +  str r36, [sp,36]
>> +  str r37, [sp,37]
>> +  str r38, [sp,38]
>> +  str r39, [sp,39]
>> +  str r40, [sp,40]
>> +  str r41, [sp,41]
>> +  str r42, [sp,42]
>> +  str r43, [sp,43]
>> +  str r44, [sp,44]
>> +  str r45, [sp,45]
>> +  str r46, [sp,46]
>> +  str r47, [sp,47]
>> +  str r48, [sp,48]
>> +  str r49, [sp,49]
>> +  str r50, [sp,50]
>> +  str r51, [sp,51]
>> +  str r52, [sp,52]
>> +  str r53, [sp,53]
>> +  str r54, [sp,54]
>> +  str r55, [sp,55]
>> +  str r56, [sp,56]
>> +  str r57, [sp,57]
>> +  str r58, [sp,58]
>> +  str r59, [sp,59]
>> +  str r60, [sp,60]
>> +  str r61, [sp,61]
>> +  str r62, [sp,62]
>> +  str r63, [sp,63]
>> +  /* Save status register */
>> +  movfs r1,status
>> +  str r1, [sp,64]
>> +  /* Save interrupt return address register */
>> +  movfs r1,iret
>> +  str r1, [sp,66]
>> +  /* Save interrupted task stack pointer */
>> +  add r1, sp, #288
> Why 288 and not 280? Use a macro.
>> +  str r1,[sp,13]
>> +  mov  r18, %low(__Per_CPU_Information)
>> +  movt r18, %high(__Per_CPU_Information)
> why not just use r33 here instead of r18 and then having to
> save/restore from it?
>> +       add  r6, r18, #(PER_CPU_ISR_NEST_LEVEL)
>> +       add  r8, r18, #(PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL)
>> +  /* Increment nesting level and disable thread dispatch */
>> +  ldr  r5, [r6]
>> +  ldr  r7, [r8]
>> +  add  r5, r5, #1
>> +  add  r7, r7, #1
>> +  str  r5, [r6]
>> +  str  r7, [r8]
>> +  /* Keep sp (Exception frame address) in r32 - Callee saved */
>> +  mov  r32, sp
>> +  /* Keep __Per_CPU_Information address in r33 - Callee saved */
>> +  mov  r33, r18
>> +  /* Call the exception handler from vector table.
>> +   * First function arg for C handler is vector number,
>> +   * and the second is a pointer to exception frame.
>> +  mov  r0,  r62
>> +  mov  r1,  sp
>> +  mov  r27, r62
>> +  lsl  r27, r27, #2
>> +  mov  r26, %low(_bsp_start_vector_table_begin)
> Don't need %high()?
No because the address will not exceed 16 bits and it's always at
local cores (which is 32KB). The upper 16 bits are zeros.
>> +  movt r15, #0
>> +  add  r27, r27, r26
>> +  ldr  r27, [r27]
>> +  /* Do not switch stacks if we are in a nested interrupt. At
>> +   * this point r5 should be holding ISR_NEST_LEVEL value.
>> +  sub  r37, r5, #1
>> +  bgtu jump_to_c_handler
>> +  /* Switch to RTEMS dedicated interrupt stack */
>> +  add     sp, r18, #(PER_CPU_INTERRUPT_STACK_HIGH)
>> +  ldr     sp, [sp]
>> +jump_to_c_handler:
>> +  jalr r27
>> +  /* Switch back to the interrupted task stack */
>> +  mov  sp, r32
>> +  /* Get the address of __Per_CPU_Information */
>> +  mov r18, r33
>> +  /* Decrement nesting level and enable multitasking */
>> +  ldr     r5, [r6]
>> +  ldr     r7, [r8]
>> +  sub     r5, r5, #1
>> +  sub     r7, r7, #1
>> +  str     r5, [r6]
>> +  str     r7, [r8]
>> +  /* Check if _ISR_Nest_level > 0 */
>> +  sub     r37, r5, #0
>> +  bgtu    exception_frame_restore
>> +  /* Check if _Thread_Dispatch_disable_level > 0 */
>> +  sub     r37, r7, #0
>> +  /* Check if dispatch needed */
>> +  add     r31, r18, #(PER_CPU_DISPATCH_NEEDED)
>> +  ldr     r31, [r31]
>> +  sub     r35, r31, #0
>> +  beq     exception_frame_restore
>> +  mov     r35, %low(__Thread_Dispatch)
>> +  movt    r35, %high(__Thread_Dispatch)
>> +  jalr    r35
>> +exception_frame_restore:
>> +  ldr r1,  [sp,1]
>> +  ldr r3,  [sp,3]
>> +  ldr r4,  [sp,4]
>> +  ldr r5,  [sp,5]
>> +  ldr r6,  [sp,6]
>> +  ldr r7,  [sp,7]
>> +  ldr r8,  [sp,8]
>> +  ldr r9,  [sp,9]
>> +  ldr r10, [sp,10]
>> +  ldr fp,  [sp,11]
>> +  ldr r12, [sp,12]
>> +  ldr lr,  [sp,14]
>> +  ldr r15, [sp,15]
>> +  ldr r16, [sp,16]
>> +  ldr r17, [sp,17]
>> +  ldr r18, [sp,18]
>> +  ldr r19, [sp,19]
>> +  ldr r20, [sp,20]
>> +  ldr r21, [sp,21]
>> +  ldr r22, [sp,22]
>> +  ldr r23, [sp,23]
>> +  ldr r24, [sp,24]
>> +  ldr r25, [sp,25]
>> +  ldr r26, [sp,26]
>> +  ldr r27, [sp,27]
>> +  ldr r28, [sp,28]
>> +  ldr r29, [sp,29]
>> +  ldr r30, [sp,30]
>> +  ldr r31, [sp,31]
>> +  ldr r32, [sp,32]
>> +  ldr r34, [sp,34]
>> +  ldr r36, [sp,36]
>> +  ldr r38, [sp,38]
>> +  ldr r39, [sp,39]
>> +  ldr r40, [sp,40]
>> +  ldr r41, [sp,41]
>> +  ldr r42, [sp,42]
>> +  ldr r43, [sp,43]
>> +  ldr r44, [sp,44]
>> +  ldr r45, [sp,45]
>> +  ldr r46, [sp,46]
>> +  ldr r47, [sp,47]
>> +  ldr r48, [sp,48]
>> +  ldr r49, [sp,49]
>> +  ldr r50, [sp,50]
>> +  ldr r51, [sp,51]
>> +  ldr r52, [sp,52]
>> +  ldr r53, [sp,53]
>> +  ldr r54, [sp,54]
>> +  ldr r55, [sp,55]
>> +  ldr r56, [sp,56]
>> +  ldr r57, [sp,57]
>> +  ldr r58, [sp,58]
>> +  ldr r59, [sp,59]
>> +  ldr r60, [sp,60]
>> +  ldr r61, [sp,61]
>> +  ldr r62, [sp,62]
>> +  ldr r63, [sp,63]
>> +  /* Restore status register */
>> +  ldr r0,[sp,64]
>> +  movts status, r0
>> +  /* Restore config register */
>> +  ldr r0, [sp,65]
>> +  movts config, r0
>> +  /* Restore interrupt return address register */
>> +  ldr   r0, [sp,66]
>> +  movts iret, r0
>> +  /* Now buffer address held on r0 can be overwritten */
>> +  ldr r0,[sp]
>> +  ldr r2,[sp,2]
>> +  /* Unwind exception frame */
> Why not restore the interrupted sp from [sp, 13] where it was previously stored?
>> +  add sp, sp, #280
>> +  ldr r62, [sp, #4]
>> +  ldr r63, [sp, #8]
> Why doing this here? Weren't these already restored?
>> +  add sp, sp, #8
> I still don't know why the extra 8 bytes.
>> +  /* return from interrupt */
>> +  rti
>> diff --git a/cpukit/score/cpu/epiphany/preinstall.am b/cpukit/score/cpu/epiphany/preinstall.am
>> index 0000000..0250d12
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/preinstall.am
>> @@ -0,0 +1,52 @@
>> +## Automatically generated by ampolish3 - Do not edit
>> +if AMPOLISH3
>> +$(srcdir)/preinstall.am: Makefile.am
>> +       $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
>> +endif
>> +PREINSTALL_DIRS =
>> +DISTCLEANFILES += $(PREINSTALL_DIRS)
>> +all-am: $(PREINSTALL_FILES)
>> +PREINSTALL_FILES =
>> +CLEANFILES += $(PREINSTALL_FILES)
>> +$(PROJECT_INCLUDE)/rtems/$(dirstamp):
>> +       @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems
>> +       @: > $(PROJECT_INCLUDE)/rtems/$(dirstamp)
>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/$(dirstamp)
>> +$(PROJECT_INCLUDE)/rtems/asm.h: rtems/asm.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/asm.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/asm.h
>> +$(PROJECT_INCLUDE)/rtems/score/$(dirstamp):
>> +       @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems/score
>> +       @: > $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>> +$(PROJECT_INCLUDE)/rtems/score/cpu.h: rtems/score/cpu.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu.h
>> +$(PROJECT_INCLUDE)/rtems/score/cpuatomic.h: rtems/score/cpuatomic.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
>> +$(PROJECT_INCLUDE)/rtems/score/cpu_asm.h: rtems/score/cpu_asm.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu_asm.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu_asm.h
>> +$(PROJECT_INCLUDE)/rtems/score/types.h: rtems/score/types.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/types.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/types.h
>> +$(PROJECT_INCLUDE)/rtems/score/epiphany.h: rtems/score/epiphany.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/epiphany.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/epiphany.h
>> +$(PROJECT_INCLUDE)/rtems/score/epiphany-utility.h: rtems/score/epiphany-utility.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/epiphany-utility.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/epiphany-utility.h
>> diff --git a/cpukit/score/cpu/epiphany/rtems/asm.h b/cpukit/score/cpu/epiphany/rtems/asm.h
>> index 0000000..4ded5d9
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/rtems/asm.h
>> @@ -0,0 +1,97 @@
>> + * @file rtems/asm.h
>> + *  This include file attempts to address the problems
>> + *  caused by incompatible flavors of assemblers and
>> + *  toolsets.  It primarily addresses variations in the
>> + *  use of leading underscores on symbols and the requirement
>> + *  that register names be preceded by a %.
>> + *  NOTE: The spacing in the use of these macros
>> + *        is critical to them working as advertised.
>> + *  COPYRIGHT:
>> + *  This file is based on similar code found in newlib available
>> + *  from ftp.cygnus.com.  The file which was used had no copyright
>> + *  notice.  This file is freely distributable as long as the source
>> + *  of the file is noted.  This file is:
>> + *  COPYRIGHT (c) 1994-1997.
>> +#ifndef __EPIPHANY_ASM_H
>> +#define __EPIPHANY_ASM_H
>> + *  Indicate we are in an assembly file and get the basic CPU definitions.
>> +#ifndef ASM
>> +#define ASM
>> +#endif
>> +#include <rtems/score/cpuopts.h>
>> +#include <rtems/score/epiphany.h>
>> + *  Recent versions of GNU cpp define variables which indicate the
>> + *  need for underscores and percents.  If not using GNU cpp or
>> + *  the version does not support this, then you will obviously
>> + *  have to define these as appropriate.
>> +#ifndef __USER_LABEL_PREFIX__
>> +#define __USER_LABEL_PREFIX__ _
>> +#endif
>> +#ifndef __REGISTER_PREFIX__
>> +#define __REGISTER_PREFIX__
>> +#endif
>> +/* ANSI concatenation macros.  */
>> +#define CONCAT1(a, b) CONCAT2(a, b)
>> +#define CONCAT2(a, b) a ## b
>> +/* Use the right prefix for global labels.  */
>> +#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
>> +/* Use the right prefix for registers.  */
>> +#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
>> + *  define macros for all of the registers on this CPU
>> + *  EXAMPLE:     #define d0 REG (d0)
>> + *  Define macros to handle section beginning and ends.
>> +#define BEGIN_CODE_DCL .text
>> +#define END_CODE_DCL
>> +#define BEGIN_DATA_DCL .data
>> +#define END_DATA_DCL
>> +#define BEGIN_CODE .text
>> +#define END_CODE
>> +#define BEGIN_DATA
>> +#define END_DATA
>> +#define BEGIN_BSS
>> +#define END_BSS
>> +#define END
>> + *  Following must be tailor for a particular flavor of the C compiler.
>> + *  They may need to put underscores in front of the symbols.
>> +#define PUBLIC(sym) .global SYM (sym)
>> +#define EXTERN(sym) .global SYM (sym)
> Maybe you want to use '.extern SYM (sym)'? Then you can use this in
> your assembly.
>> +#endif
>> diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu.h b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
>> index 0000000..eb29b2a
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
>> @@ -0,0 +1,1171 @@
>> + * @file rtems/score/cpu.h
>> + *  This include file contains macros pertaining to the Opencores
>> + *  Epiphany processor family.
>> + *  This file adapted from no_cpu example of the RTEMS distribution.
>> + *  The body has been modified for the Opencores epiphany implementation by
>> + *  Chris Ziomkowski. <chris at asics.ws>
>> +#ifndef _EPIPHANY_CPU_H
>> +#define _EPIPHANY_CPU_H
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif
>> +#include <rtems/score/epiphany.h>            /* pick up machine definitions */
>> +#include <rtems/score/types.h>
>> +#ifndef ASM
>> +#include <rtems/bspIo.h>
>> +#include <stdint.h>
>> +#include <stdio.h> /* for printk */
>> +#endif
>> +/* conditional compilation parameters */
>> + *  Should the calls to _Thread_Enable_dispatch be inlined?
>> + *  If TRUE, then they are inlined.
>> + *  If FALSE, then a subroutine call is made.
>> + *  Basically this is an example of the classic trade-off of size
>> + *  versus speed.  Inlining the call (TRUE) typically increases the
>> + *  size of RTEMS while speeding up the enabling of dispatching.
>> + *  [NOTE: In general, the _Thread_Dispatch_disable_level will
>> + *  only be 0 or 1 unless you are in an interrupt handler and that
>> + *  interrupt handler invokes the executive.]  When not inlined
>> + *  something calls _Thread_Enable_dispatch which in turns calls
>> + *  _Thread_Dispatch.  If the enable dispatch is inlined, then
>> + *  one subroutine call is avoided entirely.]
>> +#define CPU_INLINE_ENABLE_DISPATCH       FALSE
>> + *  Should the body of the search loops in _Thread_queue_Enqueue_priority
>> + *  be unrolled one time?  In unrolled each iteration of the loop examines
>> + *  two "nodes" on the chain being searched.  Otherwise, only one node
>> + *  is examined per iteration.
>> + *  If TRUE, then the loops are unrolled.
>> + *  If FALSE, then the loops are not unrolled.
>> + *  The primary factor in making this decision is the cost of disabling
>> + *  and enabling interrupts (_ISR_Flash) versus the cost of rest of the
>> + *  body of the loop.  On some CPUs, the flash is more expensive than
>> + *  one iteration of the loop body.  In this case, it might be desirable
>> + *  to unroll the loop.  It is important to note that on some CPUs, this
>> + *  code is the longest interrupt disable period in RTEMS.  So it is
>> + *  necessary to strike a balance when setting this parameter.
>> +#define CPU_UNROLL_ENQUEUE_PRIORITY      TRUE
>> + *  Does RTEMS manage a dedicated interrupt stack in software?
>> + *  If TRUE, then a stack is allocated in _ISR_Handler_initialization.
>> + *  If FALSE, nothing is done.
>> + *  If the CPU supports a dedicated interrupt stack in hardware,
>> + *  then it is generally the responsibility of the BSP to allocate it
>> + *  and set it up.
>> + *  If the CPU does not support a dedicated interrupt stack, then
>> + *  the porter has two options: (1) execute interrupts on the
>> + *  stack of the interrupted task, and (2) have RTEMS manage a dedicated
>> + *  interrupt stack.
>> + *  If this is TRUE, CPU_ALLOCATE_INTERRUPT_STACK should also be TRUE.
>> + *  Only one of CPU_HAS_SOFTWARE_INTERRUPT_STACK and
>> + *  CPU_HAS_HARDWARE_INTERRUPT_STACK should be set to TRUE.  It is
>> + *  possible that both are FALSE for a particular CPU.  Although it
>> + *  is unclear what that would imply about the interrupt processing
>> + *  procedure on that CPU.
>> + *  Currently, for epiphany port, _ISR_Handler is responsible for switching to
>> + *  RTEMS dedicated interrupt task.
>> +#define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
>> + *  Does this CPU have hardware support for a dedicated interrupt stack?
>> + *  If TRUE, then it must be installed during initialization.
>> + *  If FALSE, then no installation is performed.
>> +#define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE
>> + *  Does RTEMS allocate a dedicated interrupt stack in the Interrupt Manager?
>> + *  If TRUE, then the memory is allocated during initialization.
>> + *  If FALSE, then the memory is allocated during initialization.
>> + *  This should be TRUE is CPU_HAS_SOFTWARE_INTERRUPT_STACK is TRUE
>> + *  or CPU_INSTALL_HARDWARE_INTERRUPT_STACK is TRUE.
>> +#define CPU_ALLOCATE_INTERRUPT_STACK TRUE
>> + *  Does the RTEMS invoke the user's ISR with the vector number and
>> + *  a pointer to the saved interrupt frame (1) or just the vector
>> + *  number (0)?
>> +#define CPU_ISR_PASSES_FRAME_POINTER 1
>> + *  Does the CPU have hardware floating point?
>> + *  If TRUE, then the RTEMS_FLOATING_POINT task attribute is supported.
>> + *  If FALSE, then the RTEMS_FLOATING_POINT task attribute is ignored.
>> + *  If there is a FP coprocessor such as the i387 or mc68881, then
>> + *  the answer is TRUE.
>> + *  The macro name "epiphany_HAS_FPU" should be made CPU specific.
>> + *  It indicates whether or not this CPU model has FP support.  For
>> + *  example, it would be possible to have an i386_nofp CPU model
>> + *  which set this to false to indicate that you have an i386 without
>> + *  an i387 and wish to leave floating point support out of RTEMS.
>> + *  The CPU_SOFTWARE_FP is used to indicate whether or not there
>> + *  is software implemented floating point that must be context
>> + *  switched.  The determination of whether or not this applies
>> + *  is very tool specific and the state saved/restored is also
>> + *  compiler specific.
>> + *  epiphany Specific Information:
>> + *  At this time there are no implementations of Epiphany that are
>> + *  expected to implement floating point.
>> +#define CPU_HARDWARE_FP     FALSE
>> +#define CPU_SOFTWARE_FP     FALSE
>> + *  Are all tasks RTEMS_FLOATING_POINT tasks implicitly?
>> + *  If TRUE, then the RTEMS_FLOATING_POINT task attribute is assumed.
>> + *  If FALSE, then the RTEMS_FLOATING_POINT task attribute is followed.
>> + *  If CPU_HARDWARE_FP is FALSE, then this should be FALSE as well.
>> +#define CPU_ALL_TASKS_ARE_FP     FALSE
>> + *  Should the IDLE task have a floating point context?
>> + *  If TRUE, then the IDLE task is created as a RTEMS_FLOATING_POINT task
>> + *  and it has a floating point context which is switched in and out.
>> + *  If FALSE, then the IDLE task does not have a floating point context.
>> + *  Setting this to TRUE negatively impacts the time required to preempt
>> + *  the IDLE task from an interrupt because the floating point context
>> + *  must be saved as part of the preemption.
>> +#define CPU_IDLE_TASK_IS_FP      FALSE
>> + *  Should the saving of the floating point registers be deferred
>> + *  until a context switch is made to another different floating point
>> + *  task?
>> + *  If TRUE, then the floating point context will not be stored until
>> + *  necessary.  It will remain in the floating point registers and not
>> + *  disturned until another floating point task is switched to.
>> + *  If FALSE, then the floating point context is saved when a floating
>> + *  point task is switched out and restored when the next floating point
>> + *  task is restored.  The state of the floating point registers between
>> + *  those two operations is not specified.
>> + *  If the floating point context does NOT have to be saved as part of
>> + *  interrupt dispatching, then it should be safe to set this to TRUE.
>> + *  Setting this flag to TRUE results in using a different algorithm
>> + *  for deciding when to save and restore the floating point context.
>> + *  The deferred FP switch algorithm minimizes the number of times
>> + *  the FP context is saved and restored.  The FP context is not saved
>> + *  until a context switch is made to another, different FP task.
>> + *  Thus in a system with only one FP task, the FP context will never
>> + *  be saved or restored.
>> +#define CPU_USE_DEFERRED_FP_SWITCH       FALSE
>> + *  Does this port provide a CPU dependent IDLE task implementation?
>> + *  If TRUE, then the routine _CPU_Thread_Idle_body
>> + *  must be provided and is the default IDLE thread body instead of
>> + *  _CPU_Thread_Idle_body.
>> + *  If FALSE, then use the generic IDLE thread body if the BSP does
>> + *  not provide one.
>> + *  This is intended to allow for supporting processors which have
>> + *  a low power or idle mode.  When the IDLE thread is executed, then
>> + *  the CPU can be powered down.
>> + *  The order of precedence for selecting the IDLE thread body is:
>> + *    1.  BSP provided
>> + *    2.  CPU dependent (if provided)
>> + *    3.  generic (if no BSP and no CPU dependent)
>> +#define CPU_PROVIDES_IDLE_THREAD_BODY    TRUE
>> + *  Does the stack grow up (toward higher addresses) or down
>> + *  (toward lower addresses)?
>> + *  If TRUE, then the grows upward.
>> + *  If FALSE, then the grows toward smaller addresses.
>> +#define CPU_STACK_GROWS_UP               FALSE
>> + *  The following is the variable attribute used to force alignment
>> + *  of critical RTEMS structures.  On some processors it may make
>> + *  sense to have these aligned on tighter boundaries than
>> + *  the minimum requirements of the compiler in order to have as
>> + *  much of the critical data area as possible in a cache line.
>> + *  The placement of this macro in the declaration of the variables
>> + *  is based on the syntactically requirements of the GNU C
>> + *  "__attribute__" extension.  For example with GNU C, use
>> + *  the following to force a structures to a 32 byte boundary.
>> + *      __attribute__ ((aligned (32)))
>> + *  NOTE:  Currently only the Priority Bit Map table uses this feature.
>> + *         To benefit from using this, the data must be heavily
>> + *         used so it will stay in the cache and used frequently enough
>> + *         in the executive to justify turning this on.
>> +#define CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned (64)))
>> + *  Define what is required to specify how the network to host conversion
>> + *  routines are handled.
>> + *  This version of RTEMS is designed specifically to run with
>> + *  big endian architectures. If you want little endian, you'll
>> + *  have to make the appropriate adjustments here and write
>> + *  efficient routines for byte swapping. The epiphany architecture
>> + *  doesn't do this very well.
>> +#define CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES     FALSE
>> +#define CPU_BIG_ENDIAN                           FALSE
>> +#define CPU_LITTLE_ENDIAN                        TRUE
>> + *  The following defines the number of bits actually used in the
>> + *  interrupt field of the task mode.  How those bits map to the
>> + *  CPU interrupt levels is defined by the routine _CPU_ISR_Set_level().
>> +#define CPU_MODES_INTERRUPT_MASK   0x00000001
>> + *  Processor defined structures required for cpukit/score.
>> + * Contexts
>> + *  Generally there are 2 types of context to save.
>> + *     1. Interrupt registers to save
>> + *     2. Task level registers to save
>> + *  This means we have the following 3 context items:
>> + *     1. task level context stuff::  Context_Control
>> + *     2. floating point task stuff:: Context_Control_fp
>> + *     3. special interrupt level context :: Context_Control_interrupt
>> + *  On some processors, it is cost-effective to save only the callee
>> + *  preserved registers during a task context switch.  This means
>> + *  that the ISR code needs to save those registers which do not
>> + *  persist across function calls.  It is not mandatory to make this
>> + *  distinctions between the caller/callee saves registers for the
>> + *  purpose of minimizing context saved during task switch and on interrupts.
>> + *  If the cost of saving extra registers is minimal, simplicity is the
>> + *  choice.  Save the same context on interrupt entry as for tasks in
>> + *  this case.
>> + *  Additionally, if gdb is to be made aware of RTEMS tasks for this CPU, then
>> + *  care should be used in designing the context area.
>> + *  On some CPUs with hardware floating point support, the Context_Control_fp
>> + *  structure will not be used or it simply consist of an array of a
>> + *  fixed number of bytes.   This is done when the floating point context
>> + *  is dumped by a "FP save context" type instruction and the format
>> + *  is not really defined by the CPU.  In this case, there is no need
>> + *  to figure out the exact format -- only the size.  Of course, although
>> + *  this is enough information for RTEMS, it is probably not enough for
>> + *  a debugger such as gdb.  But that is another problem.
>> +#ifndef ASM
>> +typedef struct {
>> +  uint32_t  r[64];
>> +  uint32_t status;
>> +  uint32_t config;
>> +  uint32_t iret;
>> +#ifdef RTEMS_SMP
>> +     * @brief On SMP configurations the thread context must contain a boolean
>> +     * indicator to signal if this context is executing on a processor.
>> +     * This field must be updated during a context switch.  The context switch
>> +     * to the heir must wait until the heir context indicates that it is no
>> +     * longer executing on a processor.  The context switch must also check if
>> +     * a thread dispatch is necessary to honor updates of the heir thread for
>> +     * this processor.  This indicator must be updated using an atomic test and
>> +     * set operation to ensure that at most one processor uses the heir
>> +     * context at the same time.
>> +     * @code
>> +     * void _CPU_Context_switch(
>> +     *   Context_Control *executing,
>> +     *   Context_Control *heir
>> +     *   save( executing );
>> +     *   executing->is_executing = false;
>> +     *   memory_barrier();
>> +     *   if ( test_and_set( &heir->is_executing ) ) {
>> +     *     do {
>> +     *       Per_CPU_Control *cpu_self = _Per_CPU_Get_snapshot();
>> +     *       if ( cpu_self->dispatch_necessary ) {
>> +     *         heir = _Thread_Get_heir_and_make_it_executing( cpu_self );
>> +     *     } while ( test_and_set( &heir->is_executing ) );
>> +     *   restore( heir );
>> +     * @endcode
>> +    volatile bool is_executing;
>> +#endif
>> +} Context_Control;
>> +#define _CPU_Context_Get_SP( _context ) \
>> +  (_context)->r[13]
>> +typedef struct {
>> +  /** FPU registers are listed here */
>> +  double  some_float_register;
>> +} Context_Control_fp;
>> +typedef Context_Control CPU_Interrupt_frame;
>> + *  The size of the floating point context area.  On some CPUs this
>> + *  will not be a "sizeof" because the format of the floating point
>> + *  area is not defined -- only the size is.  This is usually on
>> + *  CPUs with a "floating point save context" instruction.
>> +#define CPU_CONTEXT_FP_SIZE  0
>> +SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
>> + *  Amount of extra stack (above minimum stack size) required by
>> + *  MPCI receive server thread.  Remember that in a multiprocessor
>> + *  system this thread must exist and be able to process all directives.
>> +#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
>> + *  Should be large enough to run all RTEMS tests.  This insures
>> + *  that a "reasonable" small application should not have any problems.
>> +#define CPU_STACK_MINIMUM_SIZE  4096
>> + *  CPU's worst alignment requirement for data types on a byte boundary.  This
>> + *  alignment does not take into account the requirements for the stack.
>> +#define CPU_ALIGNMENT 8
>> + *  This is defined if the port has a special way to report the ISR nesting
>> + *  level.  Most ports maintain the variable _ISR_Nest_level.
>> +#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
>> + *  This number corresponds to the byte alignment requirement for the
>> + *  heap handler.  This alignment requirement may be stricter than that
>> + *  for the data types alignment specified by CPU_ALIGNMENT.  It is
>> + *  common for the heap to follow the same alignment requirement as
>> + *  CPU_ALIGNMENT.  If the CPU_ALIGNMENT is strict enough for the heap,
>> + *  then this should be set to CPU_ALIGNMENT.
>> + *  NOTE:  This does not have to be a power of 2 although it should be
>> + *         a multiple of 2 greater than or equal to 2.  The requirement
>> + *         to be a multiple of 2 is because the heap uses the least
>> + *         significant field of the front and back flags to indicate
>> + *         that a block is in use or free.  So you do not want any odd
>> + *         length blocks really putting length data in that bit.
>> + *         On byte oriented architectures, CPU_HEAP_ALIGNMENT normally will
>> + *         have to be greater or equal to than CPU_ALIGNMENT to ensure that
>> + *         elements allocated from the heap meet all restrictions.
>> +#define CPU_HEAP_ALIGNMENT         CPU_ALIGNMENT
>> + *  This number corresponds to the byte alignment requirement for memory
>> + *  buffers allocated by the partition manager.  This alignment requirement
>> + *  may be stricter than that for the data types alignment specified by
>> + *  CPU_ALIGNMENT.  It is common for the partition to follow the same
>> + *  alignment requirement as CPU_ALIGNMENT.  If the CPU_ALIGNMENT is strict
>> + *  enough for the partition, then this should be set to CPU_ALIGNMENT.
>> + *  NOTE:  This does not have to be a power of 2.  It does have to
>> + *         be greater or equal to than CPU_ALIGNMENT.
>> +#define CPU_PARTITION_ALIGNMENT    CPU_ALIGNMENT
>> + *  stack.  This alignment requirement may be stricter than that for the
>> + *  data types alignment specified by CPU_ALIGNMENT.  If the CPU_ALIGNMENT
>> + *  is strict enough for the stack, then this should be set to 0.
>> + *  NOTE:  This must be a power of 2 either 0 or greater than CPU_ALIGNMENT.
>> +#define CPU_STACK_ALIGNMENT        8
>> +/* ISR handler macros */
>> + *  Support routine to initialize the RTEMS vector table after it is allocated.
>> + *  NO_CPU Specific Information:
>> + *  XXX document implementation including references if appropriate
>> +#define _CPU_Initialize_vectors()
>> + *  Disable all interrupts for an RTEMS critical section.  The previous
>> + *  level is returned in _level.
>> +static inline uint32_t epiphany_interrupt_disable( void )
>> +  uint32_t sr;
>> +  asm volatile ("movfs %[sr], status \n" : [sr] "=r" (sr):);
> __asm__
>> +  asm volatile("gid \n");
>> +  return sr;
>> +static inline void epiphany_interrupt_enable(uint32_t level)
>> +  asm volatile("gie \n");
>> +  asm volatile ("movts status, %[level] \n" :: [level] "r" (level):);
>> +#define _CPU_ISR_Disable( _level ) \
>> +    _level = epiphany_interrupt_disable()
>> + *  Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
>> + *  This indicates the end of an RTEMS critical section.  The parameter
>> + *  _level is not modified.
>> +#define _CPU_ISR_Enable( _level )  \
>> +  epiphany_interrupt_enable( _level )
>> + *  This temporarily restores the interrupt to _level before immediately
>> + *  disabling them again.  This is used to divide long RTEMS critical
>> + *  sections into two or more parts.  The parameter _level is not
>> + *  modified.
>> +#define _CPU_ISR_Flash( _level ) \
>> +  do{ \
>> +      if ( (_level & 0x2) != 0 ) \
>> +        _CPU_ISR_Enable( _level ); \
>> +      asm volatile("gid \n"); \
> Is it guaranteed the _level is correct still, or should you also use
> CPU_ISR_DISABLE()?
>> +    } while(0)
>> + *  Map interrupt level in task mode onto the hardware that the CPU
>> + *  actually provides.  Currently, interrupt levels which do not
>> + *  map onto the CPU in a generic fashion are undefined.  Someday,
>> + *  it would be nice if these were "mapped" by the application
>> + *  via a callout.  For example, m68k has 8 levels 0 - 7, levels
>> + *  8 - 255 would be available for bsp/application specific meaning.
>> + *  This could be used to manage a programmable interrupt controller
>> + *  via the rtems_task_mode directive.
>> + *  The get routine usually must be implemented as a subroutine.
>> +void _CPU_ISR_Set_level( uint32_t level );
>> +uint32_t _CPU_ISR_Get_level( void );
>> +/* end of ISR handler macros */
>> +/* Context handler macros */
>> + *  Initialize the context to a state suitable for starting a
>> + *  task after a context restore operation.  Generally, this
>> + *  involves:
>> + *     - setting a starting address
>> + *     - preparing the stack
>> + *     - preparing the stack and frame pointers
>> + *     - setting the proper interrupt level in the context
>> + *     - initializing the floating point context
>> + *  This routine generally does not set any unnecessary register
>> + *  in the context.  The state of the "general data" registers is
>> + *  undefined at task start time.
>> + *  NOTE: This is_fp parameter is TRUE if the thread is to be a floating
>> + *        point thread.  This is typically only used on CPUs where the
>> + *        FPU may be easily disabled by software such as on the SPARC
>> + *        where the PSR contains an enable FPU bit.
>> + * @brief Initializes the CPU context.
>> + * The following steps are performed:
>> + * @param[in] context points to the context area
>> + * @param[in] stack_area_begin is the low address of the allocated stack area
>> + * @param[in] stack_area_size is the size of the stack area in bytes
>> + * @param[in] new_level is the interrupt level for the task
>> + * @param[in] entry_point is the task's entry point
>> + * @param[in] is_fp is set to @c true if the task is a floating point task
>> + * @param[in] tls_area is the thread-local storage (TLS) area
>> +  bool is_fp,
>> +  void *tls_area
>> + *  This routine is responsible for somehow restarting the currently
>> + *  executing task.  If you are lucky, then all that is necessary
>> + *  is restoring the context.  Otherwise, there will need to be
>> + *  a special assembly routine which does something special in this
>> + *  case.  Context_Restore should work most of the time.  It will
>> + *  not work if restarting self conflicts with the stack frame
>> + *  assumptions of restoring a context.
>> +#define _CPU_Context_Restart_self( _the_context ) \
>> +   _CPU_Context_restore( (_the_context) );
>> + *  The purpose of this macro is to allow the initial pointer into
>> + *  a floating point context area (used to save the floating point
>> + *  context) to be at an arbitrary place in the floating point
>> + *  context area.
>> + *  This is necessary because some FP units are designed to have
>> + *  their context saved as a stack which grows into lower addresses.
>> + *  Other FP units can be saved by simply moving registers into offsets
>> + *  from the base of the context area.  Finally some FP units provide
>> + *  a "dump context" instruction which could fill in from high to low
>> + *  or low to high based on the whim of the CPU designers.
>> +#define _CPU_Context_Fp_start( _base, _offset ) \
>> +   ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
>> + *  This routine initializes the FP context area passed to it to.
>> + *  There are a few standard ways in which to initialize the
>> + *  floating point context.  The code included for this macro assumes
>> + *  that this is a CPU in which a "initial" FP context was saved into
>> + *  _CPU_Null_fp_context and it simply copies it to the destination
>> + *  context passed to it.
>> + *  Other models include (1) not doing anything, and (2) putting
>> + *  a "null FP status word" in the correct place in the FP context.
>> +#define _CPU_Context_Initialize_fp( _destination ) \
>> +   *(*(_destination)) = _CPU_Null_fp_context; \
>> +/* end of Context handler macros */
>> +/* Fatal Error manager macros */
>> + *  This routine copies _error into a known place -- typically a stack
>> + *  location or a register, optionally disables interrupts, and
>> + *  halts/stops the CPU.
>> +#define _CPU_Fatal_halt(_source, _error ) \
>> +        if(_error == RTEMS_FATAL_SOURCE_EXIT) { \
>> +          printk("\nApplication exits normally.!\n"); \
> Do we want to print here? I think it is up to an application developer
> to decide this.
>> +          asm volatile("": : :"memory"); \
>> +          asm volatile("gid; halt"); \
>> +        else {\
>> +          printk("Fatal Error %d.%d Halted\n",_source, _error); \
>> +          asm("trap 3" :: "r" (_error)); \
>> +/* end of Fatal Error manager macros */
>> +/* Bitfield handler macros */
>> + *  This routine sets _output to the bit number of the first bit
>> + *  set in _value.  _value is of CPU dependent type Priority_Bit_map_control.
>> + *  This type may be either 16 or 32 bits wide although only the 16
>> + *  least significant bits will be used.
>> + *  There are a number of variables in using a "find first bit" type
>> + *  instruction.
>> + *    (1) What happens when run on a value of zero?
>> + *    (2) Bits may be numbered from MSB to LSB or vice-versa.
>> + *    (3) The numbering may be zero or one based.
>> + *    (4) The "find first bit" instruction may search from MSB or LSB.
>> + *  RTEMS guarantees that (1) will never happen so it is not a concern.
>> + *  (2),(3), (4) are handled by the macros _CPU_Priority_mask() and
>> + *  _CPU_Priority_bits_index().  These three form a set of routines
>> + *  which must logically operate together.  Bits in the _value are
>> + *  set and cleared based on masks built by _CPU_Priority_mask().
>> + *  The basic major and minor values calculated by _Priority_Major()
>> + *  and _Priority_Minor() are "massaged" by _CPU_Priority_bits_index()
>> + *  to properly range between the values returned by the "find first bit"
>> + *  instruction.  This makes it possible for _Priority_Get_highest() to
>> + *  calculate the major and directly index into the minor table.
>> + *  This mapping is necessary to ensure that 0 (a high priority major/minor)
>> + *  is the first bit found.
>> + *  This entire "find first bit" and mapping process depends heavily
>> + *  on the manner in which a priority is broken into a major and minor
>> + *  components with the major being the 4 MSB of a priority and minor
>> + *  the 4 LSB.  Thus (0 << 4) + 0 corresponds to priority 0 -- the highest
>> + *  priority.  And (15 << 4) + 14 corresponds to priority 254 -- the next
>> + *  to the lowest priority.
>> + *  If your CPU does not have a "find first bit" instruction, then
>> + *  there are ways to make do without it.  Here are a handful of ways
>> + *  to implement this in software:
>> + *    - a series of 16 bit test instructions
>> + *    - a "binary search using if's"
>> + *    - _number = 0
>> + *      if _value > 0x00ff
>> + *        _value >>=8
>> + *        _number = 8;
>> + *      if _value > 0x0000f
>> + *        _value >=8
>> + *        _number += 4
>> + *      _number += bit_set_table[ _value ]
>> + *    where bit_set_table[ 16 ] has values which indicate the first
>> + *      bit set
>> +  /* #define CPU_USE_GENERIC_BITFIELD_CODE FALSE */
>> +#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
>> +#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
>> +#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
>> +#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
>> +    (_output) = 0;   /* do something to prevent warnings */ \
>> +#endif
>> +/* end of Bitfield handler macros */
>> + *  This routine builds the mask which corresponds to the bit fields
>> + *  as searched by _CPU_Bitfield_Find_first_bit().  See the discussion
>> + *  for that routine.
>> +#define _CPU_Priority_Mask( _bit_number ) \
>> +    (1 << _bit_number)
>> +#endif
>> + *  This routine translates the bit numbers returned by
>> + *  _CPU_Bitfield_Find_first_bit() into something suitable for use as
>> + *  a major or minor component of a priority.  See the discussion
>> +#define _CPU_Priority_bits_index( _priority ) \
>> +  (_priority)
>> +#endif
>> +#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC FALSE
>> +#define CPU_TIMESTAMP_USE_INT64 TRUE
>> +#define CPU_TIMESTAMP_USE_INT64_INLINE FALSE
>> +typedef struct {
>> +/* There is no CPU specific per-CPU state */
>> +} CPU_Per_CPU_control;
>> +#endif /* ASM */
>> + * Size of a pointer.
>> + * This must be an integer literal that can be used by the assembler.  This
>> + * value will be used to calculate offsets of structure members.  These
>> + * offsets will be used in assembler code.
>> +#define CPU_SIZEOF_POINTER 4
>> +#define CPU_PER_CPU_CONTROL_SIZE 0
>> +#ifndef ASM
>> +typedef uint16_t Priority_bit_map_Word;
>> +typedef struct {
>> +  uint32_t r[64];
>> +  uint32_t status;
>> +  uint32_t config;
>> +  uint32_t iret;
>> +} CPU_Exception_frame;
>> + * @brief Prints the exception frame via printk().
>> + * @see rtems_fatal() and RTEMS_FATAL_SOURCE_EXCEPTION.
>> +void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
>> +/* end of Priority handler macros */
>> +/* functions */
>> + *  _CPU_Initialize
>> + *  This routine performs CPU dependent initialization.
>> +  void
>> + *  _CPU_ISR_install_raw_handler
>> + *  This routine installs a "raw" interrupt handler directly into the
>> + *  processor's vector table.
>> +  uint32_t    vector,
>> + *  _CPU_ISR_install_vector
>> + *  This routine installs an interrupt vector.
>> +  uint32_t    vector,
>> + *  _CPU_Install_interrupt_stack
>> + *  This routine installs the hardware interrupt stack pointer.
>> + *  NOTE:  It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
>> + *         is TRUE.
>> +void _CPU_Install_interrupt_stack( void );
>> + *  This routine is the CPU dependent IDLE thread body.
>> + *  NOTE:  It need only be provided if CPU_PROVIDES_IDLE_THREAD_BODY
>> + *         is TRUE.
>> +void *_CPU_Thread_Idle_body( uintptr_t ignored );
>> + *  _CPU_Context_switch
>> + *  This routine switches from the run context to the heir context.
>> + *  Please see the comments in the .c file for a description of how
>> + *  this function works. There are several things to be aware of.
>> +void _CPU_Context_switch(
>> +  Context_Control  *run,
>> +  Context_Control  *heir
>> + *  _CPU_Context_restore
>> + *  This routine is generally used only to restart self in an
>> + *  efficient manner.  It may simply be a label in _CPU_Context_switch.
>> + *  NOTE: May be unnecessary to reload some registers.
>> +void _CPU_Context_restore(
>> +  Context_Control *new_context
>> + *  _CPU_Context_save_fp
>> + *  This routine saves the floating point context passed to it.
>> +void _CPU_Context_save_fp(
>> +  void **fp_context_ptr
>> + *  _CPU_Context_restore_fp
>> + *  This routine restores the floating point context passed to it.
>> +void _CPU_Context_restore_fp(
>> +/*  The following routine swaps the endian format of an unsigned int.
>> + *  It must be static because it is referenced indirectly.
>> + *  This version will work on any processor, but if there is a better
>> + *  way for your CPU PLEASE use it.  The most common way to do this is to:
>> + *     swap least significant two bytes with 16-bit rotate
>> + *     swap upper and lower 16-bits
>> + *     swap most significant two bytes with 16-bit rotate
>> + *  Some CPUs have special instructions which swap a 32-bit quantity in
>> + *  a single instruction (e.g. i486).  It is probably best to avoid
>> + *  an "endian swapping control bit" in the CPU.  One good reason is
>> + *  that interrupts would probably have to be disabled to insure that
>> + *  an interrupt does not try to access the same "chunk" with the wrong
>> + *  endian.  Another good reason is that on some CPUs, the endian bit
>> + *  endianness for ALL fetches -- both code and data -- so the code
>> + *  will be fetched incorrectly.
>> +static inline unsigned int CPU_swap_u32(
>> +  unsigned int value
>> +  uint32_t   byte1, byte2, byte3, byte4, swapped;
>> +  byte4 = (value >> 24) & 0xff;
>> +  byte3 = (value >> 16) & 0xff;
>> +  byte2 = (value >> 8)  & 0xff;
>> +  byte1 =  value        & 0xff;
>> +  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
>> +  return( swapped );
>> +#define CPU_swap_u16( value ) \
>> +  (((value&0xff) << 8) | ((value >> 8)&0xff))
>> +static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
>> +  /* TODO */
>> +static inline void _CPU_Context_validate( uintptr_t pattern )
>> +  while (1) {
>> +    /* TODO */
>> +typedef uint32_t CPU_Counter_ticks;
>> +CPU_Counter_ticks _CPU_Counter_read( void );
>> +static inline CPU_Counter_ticks _CPU_Counter_difference(
>> +  CPU_Counter_ticks second,
>> +  CPU_Counter_ticks first
>> +  return second - first;
>> +#ifdef RTEMS_SMP
>> +   * @brief Performs CPU specific SMP initialization in the context of the boot
>> +   * processor.
>> +   * This function is invoked on the boot processor during system
>> +   * initialization.  All interrupt stacks are allocated at this point in case
>> +   * the CPU port allocates the interrupt stacks.  This function is called
>> +   * before _CPU_SMP_Start_processor() or _CPU_SMP_Finalize_initialization() is
>> +   * used.
>> +   * @return The count of physically or virtually available processors.
>> +   * Depending on the configuration the application may use not all processors.
>> +  uint32_t _CPU_SMP_Initialize( void );
>> +   * @brief Starts a processor specified by its index.
>> +   * initialization.
>> +   * This function will be called after _CPU_SMP_Initialize().
>> +   * @param[in] cpu_index The processor index.
>> +   * @retval true Successful operation.
>> +   * @retval false Unable to start this processor.
>> +  bool _CPU_SMP_Start_processor( uint32_t cpu_index );
>> +   * @brief Performs final steps of CPU specific SMP initialization in the
>> +   * context of the boot processor.
>> +   * initialization.
>> +   * This function will be called after all processors requested by the
>> +   * application have been started.
>> +   * @param[in] cpu_count The minimum value of the count of processors
>> +   * requested by the application configuration and the count of physically or
>> +   * virtually available processors.
>> +  void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
>> +   * @brief Returns the index of the current processor.
>> +   * An architecture specific method must be used to obtain the index of the
>> +   * current processor in the system.  The set of processor indices is the
>> +   * range of integers starting with zero up to the processor count minus one.
>> +   uint32_t _CPU_SMP_Get_current_processor( void );
>> +   * @brief Sends an inter-processor interrupt to the specified target
>> +   * processor.
>> +   * This operation is undefined for target processor indices out of range.
>> +   * @param[in] target_processor_index The target processor index.
>> +  void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
>> +   * @brief Broadcasts a processor event.
>> +   * Some architectures provide a low-level synchronization primitive for
>> +   * processors in a multi-processor environment.  Processors waiting for this
>> +   * event may go into a low-power state and stop generating system bus
>> +   * transactions.  This function must ensure that preceding store operations
>> +   * can be observed by other processors.
>> +   * @see _CPU_SMP_Processor_event_receive().
>> +  void _CPU_SMP_Processor_event_broadcast( void );
>> +   * @brief Receives a processor event.
>> +   * This function will wait for the processor event and may wait forever if no
>> +   * such event arrives.
>> +   * @see _CPU_SMP_Processor_event_broadcast().
>> +  static inline void _CPU_SMP_Processor_event_receive( void )
>> +    __asm__ volatile ( "" : : : "memory" );
>> +   * @brief Gets the is executing indicator of the thread context.
>> +   * @param[in] context The context.
>> +  static inline bool _CPU_Context_Get_is_executing(
>> +    const Context_Control *context
>> +    return context->is_executing;
>> +   * @brief Sets the is executing indicator of the thread context.
>> +   * @param[in] is_executing The new value for the is executing indicator.
>> +  static inline void _CPU_Context_Set_is_executing(
>> +    bool is_executing
>> +    context->is_executing = is_executing;
>> +#endif /* RTEMS_SMP */
>> +#endif /* ASM */
>> +#ifdef __cplusplus
>> +#endif
>> +#endif
>> diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu_asm.h b/cpukit/score/cpu/epiphany/rtems/score/cpu_asm.h
>> index 0000000..cc091fa
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/rtems/score/cpu_asm.h
>> @@ -0,0 +1,74 @@
>> + * @file
>> + * @brief Epiphany Assembly File
>> + * Very loose template for an include file for the cpu_asm.? file
>> + * if it is implemented as a ".S" file (preprocessed by cpp) instead
>> + * of a ".s" file (preprocessed by gm4 or gasp).
>> +#ifndef _RTEMS_SCORE_CPU_ASM_H
>> +#define _RTEMS_SCORE_CPU_ASM_H
>> +/* pull in the generated offsets */
>> +#include <rtems/score/offsets.h>
>> + * Hardware General Registers
>> +/* put something here */
>> + * Hardware Floating Point Registers
>> + * Hardware Control Registers
>> + * Calling Convention
>> + * Temporary registers
>> + * Floating Point Registers - SW Conventions
>> + * Temporary floating point registers
>> +#endif
>> +/* end of file */
> What's the point of this file?
It exists for other ports as is, like with or1k.
>> diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpuatomic.h b/cpukit/score/cpu/epiphany/rtems/score/cpuatomic.h
>> index 0000000..598ee76
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/rtems/score/cpuatomic.h
>> @@ -0,0 +1,14 @@
>> + * COPYRIGHT (c) 2012-2013 Deng Hengyi.
>> +#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
>> +#define _RTEMS_SCORE_ATOMIC_CPU_H
>> +#include <rtems/score/cpustdatomic.h>
>> +#endif /* _RTEMS_SCORE_ATOMIC_CPU_H */
>> diff --git a/cpukit/score/cpu/epiphany/rtems/score/epiphany-utility.h b/cpukit/score/cpu/epiphany/rtems/score/epiphany-utility.h
>> index 0000000..53ebe87
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/rtems/score/epiphany-utility.h
>> @@ -0,0 +1,180 @@
>> +#ifndef _EPIPHANY_UTILITY_H
>> +#define _EPIPHANY_UTILITY_H
>> +/* eCore IRQs */
>> +typedef enum
>> +  START,
>> +  SW_EXCEPTION,
>> +  MEM_FAULT,
>> +  TIMER0,
>> +  TIMER1,
>> +  SMP_MESSAGE,
>> +  DMA0,
>> +  DMA1,
>> +  SER,
>> +} IRQ_PER_CORE_T;
> This should be prefixed for EPIPHANY or Epiphany.
>> +/*  Per-core IO mapped register addresses
>> + *  @see Epiphany architecture reference.
> It might be nicer to define the base address (0xF0000) and then add to
> it each offset.
>> +#define EPIPHANY_PER_CORE_REG_CONFIG      0xF0400
>> +#define EPIPHANY_PER_CORE_REG_STATUS      0xF0404
>> +#define EPIPHANY_PER_CORE_REG_PC          0xF0408
>> +#define EPIPHANY_PER_CORE_REG_DEBUGSTATUS 0xF040C
>> +#define EPIPHANY_PER_CORE_REG_LC          0xF0414
>> +#define EPIPHANY_PER_CORE_REG_LS          0xF0418
>> +#define EPIPHANY_PER_CORE_REG_LE          0xF041C
>> +#define EPIPHANY_PER_CORE_REG_IRET        0xF0420
>> +#define EPIPHANY_PER_CORE_REG_IMASK       0xF0424
>> +#define EPIPHANY_PER_CORE_REG_ILAT        0xF0428
>> +#define EPIPHANY_PER_CORE_REG_ILATST      0xF042C
>> +#define EPIPHANY_PER_CORE_REG_ILATCL      0xF0430
>> +#define EPIPHANY_PER_CORE_REG_IPEND       0xF0434
>> +#define EPIPHANY_PER_CORE_REG_FSTATUS     0xF0440
>> +#define EPIPHANY_PER_CORE_REG_DEBUGCMD    0xF0448
>> +#define EPIPHANY_PER_CORE_REG_RESETCORE   0xF070C
>> +/* Event timer registers */
>> +#define EPIPHANY_PER_CORE_REG_CTIMER0     0xF0438
>> +#define EPIPHANY_PER_CORE_REG_CTIMER1     0xF043C
>> +/* Processor control registers */
>> +#define EPIPHANY_PER_CORE_REG_MEMSTATUS   0xF0604
>> +#define EPIPHANY_PER_CORE_REG_MEMPROTECT  0xF0608
>> +/* DMA Registers */
>> +#define EPIPHANY_PER_CORE_REG_DMA0CONFIG  0xF0500
>> +#define EPIPHANY_PER_CORE_REG_DMA0STRIDE  0xF0504
>> +#define EPIPHANY_PER_CORE_REG_DMA0COUNT   0xF0508
>> +#define EPIPHANY_PER_CORE_REG_DMA0SRCADDR 0xF050C
>> +#define EPIPHANY_PER_CORE_REG_DMA0DSTADDR 0xF0510
>> +#define EPIPHANY_PER_CORE_REG_DMA0AUTO0   0xF0514
>> +#define EPIPHANY_PER_CORE_REG_DMA0AUTO1   0xF0518
>> +#define EPIPHANY_PER_CORE_REG_DMA0STATUS  0xF051C
>> +#define EPIPHANY_PER_CORE_REG_DMA1CONFIG  0xF0520
>> +#define EPIPHANY_PER_CORE_REG_DMA1STRIDE  0xF0524
>> +#define EPIPHANY_PER_CORE_REG_DMA1COUNT   0xF0528
>> +#define EPIPHANY_PER_CORE_REG_DMA1SRCADDR 0xF052C
>> +#define EPIPHANY_PER_CORE_REG_DMA1DSTADDR 0xF0530
>> +#define EPIPHANY_PER_CORE_REG_DMA1AUTO0   0xF0534
>> +#define EPIPHANY_PER_CORE_REG_DMA1AUTO1   0xF0538
>> +#define EPIPHANY_PER_CORE_REG_DMA1STATUS  0xF053C
>> +/* Mesh Node Control Registers */
>> +#define EPIPHANY_PER_CORE_REG_MESHCONFIG  0xF0700
>> +#define EPIPHANY_PER_CORE_REG_COREID      0xF0704
>> +#define EPIPHANY_PER_CORE_REG_MULTICAST   0xF0708
>> +#define EPIPHANY_PER_CORE_REG_CMESHROUTE  0xF0710
>> +#define EPIPHANY_PER_CORE_REG_XMESHROUTE  0xF0714
>> +#define EPIPHANY_PER_CORE_REG_RMESHROUTE  0xF0718
>> +/*  This macros constructs an address space of epiphany cores
>> + *  from their IDs.
>> +#define EPIPHANY_COREID_TO_MSB_ADDR(id) (id) << 20
> So each core gets a 1MB address space? Is this part of the architecture's TRM?
Yes.
>> +/*  Construct a complete/absolute IO mapped address register from
>> + *  core ID and register name
>> +#define EPIPHANY_GET_REG_ABSOLUTE_ADDR(coreid, reg) \
>> +        (EPIPHANY_COREID_TO_MSB_ADDR(coreid) | (reg))
>> +#define EPIPHANY_REG(reg) (uint32_t *) (reg)
>> +static inline uint32_t epiphany_coreid_to_rtems_map(uint32_t coreid);
> No need to forward declare this.
>> +/* Read register with its absolute address */
>> +static inline uint32_t read_epiphany_reg(volatile uint32_t reg_addr)
>> +  return *(EPIPHANY_REG(reg_addr));
>> +/* Write register with its abolute address */
>> +static inline void write_epiphany_reg(volatile uint32_t reg_addr, uint32_t val)
>> +  *(EPIPHANY_REG(reg_addr)) = val;
>> +/*  Epiphany uses 12 bits for defining core IDs, while RTEMS uses
>> + *  linear IDs. The following function converts RTEMS linear IDs to
>> + *  Epiphany correspodning ones
> typo: corresponding
>> +static inline uint32_t rtems_coreid_to_epiphany_map(uint32_t rtems_id)
>> +  switch(rtems_id)
>> +    case (0) : return 0x808;  /* (32, 8) */
>> +    case (1) : return 0x809;  /* (32, 9) */
>> +    case (2) : return 0x80A;  /* (32,10) */
>> +    case (3) : return 0x80B;  /* (32,11) */
>> +    case (4) : return 0x848;  /* (33, 8) */
>> +    case (5) : return 0x849;  /* (33, 9) */
>> +    case (6) : return 0x84A;  /* (33,10) */
>> +    case (7) : return 0x84B;  /* (33,11) */
>> +    case (8) : return 0x888;  /* (34, 8) */
>> +    case (9) : return 0x889;  /* (34, 9) */
>> +    case (10): return 0x88A;  /* (34,10) */
>> +    case (11): return 0x88B;  /* (34,11) */
>> +    case (12): return 0x8C8;  /* (35, 8) */
>> +    case (13): return 0x8C9;  /* (35, 9) */
>> +    case (14): return 0x8CA;  /* (35,10) */
>> +    case (15): return 0x8CB;  /* (35,11) */
>> +    default: return 0x1000;   /* Error */
>> +  return 0x1000; /* Error */
> This is dead code. I'd remove the return from default and let it
> fall-through to here.
> Also, the translation here is trivial to implement as a lookup in an array:
> uint32_t map[16] = {0x808, 0x809, 0x80A, 0x80B, 0x848 ...};
> return map[rtems_id];
>> + * linear IDs. The following function is used to map Epiphany IDs to
>> + * RTEMS linear IDs.
>> +inline uint32_t epiphany_coreid_to_rtems_map(uint32_t epiphany_id)
> static?
>> +  switch(epiphany_id)
>> +    case (0x808): return 0;  /* (32, 8) */
>> +    case (0x809): return 1;  /* (32, 9) */
>> +    case (0x80A): return 2;  /* (32,10) */
>> +    case (0x80B): return 3;  /* (32,11) */
>> +    case (0x848): return 4;  /* (33, 8) */
>> +    case (0x849): return 5;  /* (33, 9) */
>> +    case (0x84A): return 6;  /* (33,10) */
>> +    case (0x84B): return 7;  /* (33,11) */
>> +    case (0x888): return 8;  /* (34, 8) */
>> +    case (0x889): return 9;  /* (34, 9) */
>> +    case (0x88A): return 10; /* (34,10) */
>> +    case (0x88B): return 11; /* (34,11) */
>> +    case (0x8C8): return 12; /* (35, 8) */
>> +    case (0x8C9): return 13; /* (35, 9) */
>> +    case (0x8CA): return 14; /* (35,10) */
>> +    case (0x8CB): return 15; /* (35,11) */
> Ditto on the dead code.
> Since there are holes in the translation here, an array won't work
> nicely, but it might be more efficient to use arithmetic to calculate
> this translation, e.g.
> ((epiphany_id & 0xf0) >> 4) + ((epiphany_id & 0xf) - 8)
I've another assembly version that's very optmized, but thought it's
won't be easier to read. I'll add it to the next patch.
> This especially may produce smaller code, and probably makes a
> difference if # of cores increases. (assuming the math is right).
>> +static inline uint32_t _Epiphany_Get_Current_coreid()
> Should this be Epiphany_Get_current_processor()? Anyway, shouldn't
> have Current capitalized here.
>> +  uint32_t coreid;
>> +  asm volatile ("movfs %0, coreid" : "=r" (coreid): );
>> +  return epiphany_coreid_to_rtems_map(coreid);
>> +#endif  /* _EPIPHANY_UTILITY_H */
>> diff --git a/cpukit/score/cpu/epiphany/rtems/score/epiphany.h b/cpukit/score/cpu/epiphany/rtems/score/epiphany.h
>> new file mode 100644
>> index 0000000..3aeb6d9
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/rtems/score/epiphany.h
>> @@ -0,0 +1,50 @@
>> + * @file rtems/score/epiphany.h
>> + *  This file contains information pertaining to the Epiphany processor.
>> + *  Based on code with the following copyright...
>> + *  COPYRIGHT (c) 1989-1999, 2010.
>> +#ifndef _RTEMS_SCORE_EPIPHANY_H
>> +#define _RTEMS_SCORE_EPIPHANY_H
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif
>> + *  This file contains the information required to build
>> + *  RTEMS for a particular member of the Epiphany family.
>> + *  It does this by setting variables to indicate which
>> + *  implementation dependent features are present in a particular
>> + *  member of the family.
>> + *  This is a good place to list all the known CPU models
>> + *  that this port supports and which RTEMS CPU model they correspond
>> + *  to.
>> + *  Define the name of the CPU family and specific model.
>> +#define CPU_NAME "EPIPHANY"
>> +#define CPU_MODEL_NAME "EPIPHANY"
>> +#ifdef __cplusplus
>> +#endif
>> +#endif /* _RTEMS_SCORE_EPIPHANY_H */
>> diff --git a/cpukit/score/cpu/epiphany/rtems/score/types.h b/cpukit/score/cpu/epiphany/rtems/score/types.h
>> index 0000000..21c82a0
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/rtems/score/types.h
>> @@ -0,0 +1,55 @@
>> + * @file
>> + * @brief Epiphany Architecture Types API
>> + *  This include file contains type definitions pertaining to the
>> + *  COPYRIGHT (c) 2015 University of York.
>> + *  Hesham ALMatary <hmka501 at york.ac.uk>
>> + *  The license and distribution terms for this file may be
>> + *  found in the file LICENSE in this distribution or at
>> + #ifndef _RTEMS_SCORE_TYPES_H
>> +#define _RTEMS_SCORE_TYPES_H
>> +#include <rtems/score/basedefs.h>
>> +#ifndef ASM
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif
>> + * @addtogroup ScoreCPU
>> + *  This section defines the basic types for this processor.
>> +/** Type that can store a 32-bit integer or a pointer. */
>> +typedef uintptr_t CPU_Uint32ptr;
>> +typedef void epiphany_isr;
>> +typedef void ( *epiphany_isr_entry )( void );
>> +#ifdef __cplusplus
>> +#endif
>> +#endif  /* !ASM */
>> +#endif
>> 2.1.0
>> devel mailing list
>> devel at rtems.org
Hesham
