Build failure for realview_pbx_a9_qemu_smp BSP
Thu Apr 14 07:12:27 UTC 2016
On 13/04/16 00:29, Darshit Shah wrote:
> make[6]: Entering directory
> '/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/testsuites/samples/hello'
Looks you build the atsamv BSP with --enable-smp. What is your configure
command line?
The realview_pbx_a9_qemu_smp is currently broken due to a problem of the
clock driver initialization on Qemu.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
